Next repair... fork seal
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by Barekat, Apr 14, 2016.
  1. Barekat
    Barekat Looking to get dirty Supporter
    Jul 28, 2013
    3,348
    North of Toronto
    DOH!
    I was puttering around in the garage after work and noticed this...:( fork leak.jpg
  2. SURFINASPHALT
    SURFINASPHALT "Zen Rider"
    Aug 7, 2015
    788
    Norman, OK.
    Oopsie.
    You gonna try to clean it before trying to warranty it?:D
  3. Barekat
    Jul 28, 2013
    3,348
    North of Toronto
    Nop. This was tarmac trauma prior to the leak.
    I'm glad it leaked now and not next month when I'm on a road trip with the rondel crowd. Six bimmers and only two KTM.
    SURFINASPHALT likes this.
  4. paidoutcomes
    paidoutcomes Long timer
    Jul 30, 2014
    1,396
    Fargo, ND
    My 1290 fork leaked. Dealer check into it and ktm replaced under warranty. I hear tell of stickers being left on the forks or seals, causing the degradation.
  5. SURFINASPHALT
    Aug 7, 2015
    788
    Norman, OK.
    Yep Gotta Represent.
    Good On Ya M8!:beer
  6. MX Engineer
    MX Engineer MX Racer
    Dec 22, 2015
    1,348
    Ann Arbor, MI; Lake Havasu City, AZ
    Try the "Seal Doctor" before you go to the dealer.
  7. Barekat
    Jul 28, 2013
    3,348
    North of Toronto
    So I made my own seal cleaner tonight from an old windshield wash jug.
    After cleaning both the dust shield and the fork seal the leak seams to have stopped... at least long enough to grab a bit to eat... nothing dripping.
    I went for a very short ride and the fork looks dry. I'll ride to work tomorrow and check again.
    Anyway, I dropped an email to the dealer for an appointment which I can cancel if "cleaning the crud" fixed things.
    A couple action shots. ;)
    p.s. thanks MX Engineer... you sent me in the right directions. IMG_20160414_212627.jpg IMG_20160414_212914.jpg IMG_20160414_223640.jpg IMG_20160414_224334.jpg fixed 'er.
    oldfuddy, edge2edge, Gimme 2 and 3 others like this.
  8. SURFINASPHALT
    Aug 7, 2015
    788
    Norman, OK.
    Hooray! Another Win for General Maintenance!:clap
    Nice Fabricating idea Kat!:thumb
    #8
  9. manxkipper
    manxkipper Fishpistel
    Jan 11, 2006
    1,056
    Cape Town
    Remember to release the air that builds up in the fork over time. There is a small phillips head bleed screw on the top of each fork that you undo and let out the air.
    #9
  10. KTM 1190advR
    KTM 1190advR Enema of the state Supporter
    Aug 2, 2015
    2,432
    Somewhere in Norway
    Speedbleeders..., got mine from Slavens:thumb
    Even the PP's ones are reasonably priced.
    #10
    breakfastbuddy likes this.
  11. manxkipper
    Jan 11, 2006
    1,056
    Cape Town
    I must get a set of those.
    #11
    KTM 1190advR likes this.
  12. Barekat
    Jul 28, 2013
    3,348
    North of Toronto
    Thanks Surf.
    I stole the idea from someone else online.
    There was a tiny bit of oil on the fork when I got to work so it looks like I might have to take her in after all. :uhoh
    It's suppose to be 20c this weekend too. :kurt
    #12
  13. PS-RagE
    PS-RagE Long timer
    Oct 30, 2009
    1,113
    Land of Ice and Snow
    Yeah, I had the seal on the compression fork start leaking pretty bad in the middle of a 1400km offroad ride last year. Was pretty much dry by the end of the tour.
    #13
  14. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    5,313
    NW Sydney, Australia
    My compression leg started leaking at about 1000k's, I use the "old feeler gauge trick" and it hasnt leaked again in another 5000.
    I always fill the cavity between the dust seal and the oil seal with waterproof grease, works for me :-)
    Leaking comp side seems very common for some reason!
    #14
  15. Barekat
    Jul 28, 2013
    3,348
    North of Toronto
    I bought a seal doctor on the weekend and tried to clean the seal again... No luck. Still a very slight leak. I didn't realize how delicate the WP suspension was?? :hmmmmm
    #15
  16. 1coolbanana
    Aug 25, 2009
    5,313
    They never used to be!
    #16
  17. jeremy_283
    jeremy_283 Been here awhile
    Jan 25, 2012
    745
    For as rare is bleeding is actually required, the fact that the front end has to be lifted, and I've seen too many reviews of speed bleeders leaking >>> I decided to just stick with the Phillips screws
    #17
  18. dewaynehasty
    dewaynehasty Been here awhile
    Sep 30, 2013
    187
    My left fork leaded during my CO BDR ride. When I got home I had it fixed. 300 miles later it is leaking again :( WTF!
    I'll try that waterproof grease idea..thanks.
    #18
  19. 1coolbanana
    Aug 25, 2009
    5,313
    I would do the seal saver or feeler trick first then fill with grease.
    Mines been good for 3k since doing it.
    #19
  20. Newbusa
    Newbusa Long timer
    Aug 21, 2006
    1,227
    Qualicum Beach
    I had the same problem, had to use the seal tool at least 3 times before it stopped leaking.
    #20
