No ASC Indicators
Discussion in 'GS Boxers' started by FishDiver, Aug 1, 2020.
  1. FishDiver
    FishDiver Adventurer
    May 27, 2016
    46
    Sacramento, CA
    I have a new to me 2008 1200GS without ESA or tire pressure sensors. After reading this (https://gadgeteer.co.za/mybike/bmw-r1200gs-tips) I was able to deactivate the ABS. My issue now is I can't set the ASC because the indicators on the multi-function screen never turn on.
    When the ignition is on before the engine is started the top line error light cycles through the red and yellow triangle and then dims off. I have read all the cryptic instructions in the user manual and they are more confusing then helpful.
    Anyone have ideas?
  2. Welshman
    Welshman B.U.F.F.
    Feb 21, 2005
    1,642
    Jo,burg dry and dirty.
    What is ASC?
  3. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    It's not clear from your post as to what your goal is and what you're trying to do after you deactivated ABS?! :hmmmmm
    Rather than using someone's tips how to operate bike, it may be more beneficial to download owner's manual (it's free and legal) and read through it - there are situations described in details with warning lights etc in the manual telling you what means what...
    If you're trying to set ASC while ABS is off, that may not happen as ASC uses same sensors as ABS...
    Callisto224 likes this.
  4. Lead Wrist
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    ASC is traction control ie. Auto Stability Control
  5. FishDiver
    May 27, 2016
    46
    Sacramento, CA
    ASC is the BMW acronym for traction control. Problem solved, I called the dealer and they looked up my VIN. The bike doesn't have ASC! I thought it was standard that model year.
  6. Lead Wrist
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    ^ No wonder you couldn't set it... :D
    If you don't have ABS/ASC labeled button on LH switch gear, there'd be no ASC...
  7. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,707
    DC metro
    Antiskid, maybe. Regardless, definitely not std.
    It can be added with a software upgrade, and maybe a switch. The parts are probably still listed in online fiche. Labor is likely an hour or two.
    Just glanced at Max's. Full retail is a bit over $450 for the necessary parts, mostly the new switch. Add labor & programming time to that.
  8. Callisto224
    Callisto224 Long timer Supporter
    Jan 5, 2010
    7,103
    GA
    ^^^this.
    Go here to download the Riders Manual for your bike.
    https://www.bmw-motorrad.com/en/service/manuals/rider-manual.html
    #8
