No drive after engine swap?
Discussion in 'Dakar champion (950/990)' started by mountaincadre, Jun 18, 2019.
  1. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    Just done an engine swap on my 950A,(990 smt in now) engine is running fine but when you put it in gear there's Nothing, master and slave are working fine- when it's in gear with engine running the neutral light goes out but there is no drive? I left the original clutch in thinking it looked okay,( no burnt looking plates but strangely enough I've never had to replace one in any bike I've ever had so limited knowledge) with bike running or not you can put it in gear and still push it about,( there feels like there's a little resistance) when I swapped over the pick up wheel from the 950 engine to the 990 engine you have to take off the nut that holds the clutch basket on and slide the basket forward about a half inch to get the old wheel off and the new one in, obviously the pressure plate has to be removed, when i but the pressure plate back on i tightned all the bolts up to there stops then gave them 10nm- is that correct? My feeling is either I've retightened clutch wrongly or the clutch pack from the new engine was worn out- anyone any idea's?
  2. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,433
    Finally made it to Fruita!
    Sounds like you've cocked something up, mate. Better pop the clutch cover off, so we can all take a look.
  3. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    I'm on my way back home from the workshop mate,( workshop in Edinburgh and I live in West lothian) no dodgy noises or anything like that just no drive:(
  4. NKL
    NKL Been here awhile
    Oct 25, 2011
    387
    Kent, England
    Sounds like you haven't lined up the outer pressure plate
    mountaincadre likes this.
  5. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    NKL could you give me a bit more detail please, I just put it on, not in any particular way,( just on with holes for springs and bolts to line up).mmmm
  6. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,351
    SWEDEN, Norsjö
    And it would still engage. Sure the manual says to move that outer most plate.
    But how would the CJ basket that does not even have that cutout work?
    Any chance you lost a plate?
    And the outer most plate has beefier friction pads would guess it has to do with it being in contact the aluminum pressure plate.
    /Johan
    Boatman and MotoActionADV like this.
  7. NKL
    Oct 25, 2011
    387
    Kent, England
    Cant remember if there are arrows to line up or you just need to line up the notches in the outer plate with the corresponding notches on the basket
  8. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    Didn't even take plates our Johan as there was no need, I just moved the whole lot forward about half an inch then back again making sure that the cog behind re-engaged with other one.
    #8
  9. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    There is an arrow nkl also 2 other markings on the pressure plate.
    #9
  10. NKL
    Oct 25, 2011
    387
    Kent, England
    It's been a while since I had my clutch apart I'm afraid, trying to find a photo
    #10
  11. NKL
    Oct 25, 2011
    387
    Kent, England
    #11
  12. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    Thanks nkl I know for fact I HAV'NT got it mounted that way, I have the arrow to the right,( it was only a couple of days ago I did it) hopefully I can just lean her over and take of just the 1st half of the casing,( not the other part with water pump housing.
    #12
  13. zimtim
    zimtim Been here awhile
    Aug 15, 2012
    118
    UK
    Did you swap over slave cylinder.
    If so did you replace the the small pin that goes through the long rod and line it up with the groove in the slave cylinder.
    #13
  14. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    No, I have an Oberon fitted and yes I remembered the pin, I thought the same thing- has the ball bearing fell out? Is it lined up, there was a lot of profanity this afternoon.
    #14
  15. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,351
    SWEDEN, Norsjö
    Still think it would work fine without the pin.
    Maybe excess wear if it starts spinning.
    And loosing the ball would cause clutch to not dissengange.
    Maybe 2 balls or forgetting something in the spacing of the clutch slave would cause it to be bolted in far enough that it's constantly disengaging?
    /Johan
    #15
  16. Dusty
    Dusty Long timer
    Jun 15, 2007
    1,557
    Bismarck
    That's what it sounds like to me also always disengaged, somethings cocked up. Remove the clutch cover and see if the stack moves with lever action.
    #16
  17. Allucaneat
    Allucaneat When do we stop to eat? Supporter
    Apr 25, 2014
    1,063
    Fayetteville, GA
    Start with the simple things.
    A few years ago I bought my daughter a used TT-R90 that was cosmetically rough, but ran well. I took some things apart and cleaned it good, and then a couple of weeks went by before I tried running it again. I started it and put it in gear - the engine rev'd but the bike didn't move. I looked down and realized I had never reinstalled the chain after soaking it! :scratch :fpalm
    #17
  18. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,877
    Maine
    Yes you should be able to lay it over and pull just the clutch cover.
    #18
  19. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,351
    SWEDEN, Norsjö
    No need to lay it down for that. Even on the sidestand you will hardly loose any oil.
    But to be safe I roll bike up on a wooden board to get it to lean over a little extra.
    /Johan
    #19
  20. mountaincadre
    Jul 18, 2012
    1,975
    Mid Calder,Scotland
    So just popped the cover off of the clutch and yes the pressure plate was not on correctly, I've put it on now and the slave to check function, operating the lever I can see the pressure plate going in and out, now the bolts for the springs are to be 10nm of torque, I've turned them in till they've stopped, I am right in thinking it's now they get torqued up to 10nm?
    #20
