no splice option for switched power - R1200GS
Discussion in 'GS Boxers' started by AngryScot, Jul 23, 2008.
  1. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    After I did my lights I got a few questions on the switched power connector. This options allows you to get the switched power from the diagnostic plug without having to cut into any wires.
    The part is from Molex part#1292prt (got mine at Radio Shack)
    you of course only need one of the plugs so for $2.69 it is not the cheapest but you can share with buddies when they gawk at your clean set up :lol3
    Here is what it looks like crimped and with heat shrink tubing.
    I drilled a small hole in the plug cover and used a small rubber grommet (sorry don't know the sizes on those parts.
    installed test fit, I know the other bit of shrink tube isn't done yet.
    Close up
    Works great, had it installed for 7 months now and no issues. Easy when going for warranty work, they just pull the plug and pull the connector for the diagnostic system, then plug back in and done.
    I am not against splicing and tapping into the stock wiring, this is just a different option.
    Hope it is useful!
    :thumb
  2. kindofblue
    kindofblue Ride it like you stole it
    Mar 19, 2007
    822
    Albuquerque NM
    GS newbie question here:
    Does it make a difference which male plug your female Molex adapter plugs into? Thanks.
  3. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    yes, you want the diagnostic wire blue/green
  4. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    bump for the guy looking for this thread....... :D
  5. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    21,122
    Villa Maria Sanitarium, Claremont, CA. USA
    Is that hot all the time or only when IGN is on?
  6. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    Only when ignition is on
  7. arrcrussell
    arrcrussell Gimme Dirt
    Sep 8, 2005
    1,204
    NE OH, USA
    Sheesh - why didn't I think of that! Nice job!!
  8. mwhite5471
    mwhite5471 Been here awhile
    Dec 19, 2013
    207
    AZ
    Awesome great post...whats the Amp rating of that connection?
    #8
  9. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    maybe someone knows, I have no clue :norton
    #9
  10. hammick
    hammick Long timer
    Dec 2, 2007
    4,704
    Kansas City, Missouri
    Any idea if any of those wires in the diagnostic plug are only hot when the bike is started?
    The new RT will not allow an HID or HID relay to be triggered from the low beam circuit. The Linbus dims the low beam when the high beam switch is activated.
    I had to trigger the relay from the 7.5a fuse feed wire under the seat. Now my headlight is on whenever the key is on and stays on for about 40 seconds after the bike is turned off. I kind of like the 40 second pathway lighting option I have now but I cannot turn on the bike to listen to the stereo in the garage without the headlight being on.
    #10
  11. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    One of them is, but i dont recal which, after a service the guy plugged it into a different one and it was hot all the time. Swapped it back and didnt look which sorry.
    #11
  12. EScott
    EScott Adventurer
    Sep 12, 2011
    64
    Denver CO
    seems fairly brilliant! thanks for sharing.. :clap
    #12
  13. Chat Lunatique
    Chat Lunatique aka El Gato Loco
    May 9, 2011
    1,474
    Niagara, Canada
    Doesn't matter, it's more than enough to power a relay. You only draw a few milliamps to power a trigger relay and should not use this connection point for anything else.
    #13
  14. LaurelPerryOnLand
    LaurelPerryOnLand Long timer
    Jun 9, 2009
    3,482
    Denver, CO
    Trigger a relay. OK.
    Power something else: NEVER DO IT.
    I won't ask you to read my thread about replacing a BATTERY and ALTERNATOR only to discover I didn't need to do.:huh
    I tried to POWER Hyperlites from the diagnostic plug...that set off a chain of events starting with a BATTERY WARNING LIGHT coming on. JVB got me back on the straight and narrow! :clap
    NEVER DO IT.
    #14
  15. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,241
    Big Sky Country
    You are brilliant ... why didn't we (collectively) come up with that idea?
    Kudos to Angry Scot!
    #15
  16. hammick
    hammick Long timer
    Dec 2, 2007
    4,704
    I put a test light on the wires in the diagnostic on my '14 R1200RTW. There are only four wires.
    One is ground, one is hot even with ignition off, and two do not carry power. No switched power in there.
    #16
  17. AngryScot
    AngryScot .
    Aug 1, 2006
    18,439
    ☼ Ca ☼
    Mine powers a relay not a light :dunno
    #17
  18. JurgenB
    JurgenB daily rider
    Mar 11, 2007
    509
    Coloradio
    Minimal. All you can use it for is a line to power a relay. Also, the wire is not fused so if you overload it you will burn up the harnes $$$
    #18
  19. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    16,607
    SF Bay Area
    The hexhead and the wethead use the same connector, but that's about all. Thats one of the reasons you cant use the GS-911 on a wethead.
    #19
  20. CVAN
    CVAN Polite as Fuck
    Nov 22, 2009
    1,469
    Reno,NV
    #20
