1. eNewsletter Sign Up
Nwgs Jeep'n Thread
Discussion in 'Shiny Things' started by nwgs, May 20, 2007.
  1. TheOtherBart
    TheOtherBart Long timer
    Jan 16, 2006
    3,546
    DeKalb County, Illinois
    P0303 cylinder #3 misfire, so plugs are still in the running as the potential problem. Hopefully I can get them swapped this afternoon after work.
  2. WVhillbilly
    WVhillbilly Long timer
    Oct 20, 2010
    38,849
    WV
    Coil pack?
  3. TheOtherBart
    Jan 16, 2006
    3,546
    Could be that too. Or wires. Or, less likely, an injector problem. I'll give it fresh plugs because it needs them regardless and go from there.
  4. WVhillbilly
    Oct 20, 2010
    38,849
    WV
    DyrWolf and mazeppa like this.
  5. poppawheelie
    poppawheelie Long timer
    Jul 16, 2003
    1,015
    Central Pennsylvania
    Thanks. Didn't know that.
    Kevm likes this.
  6. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,117
    West of the West, Oregon
    Never torqued a spark plug. Just crushed the washer and stopped when the torque spiked. Lube or no lube didn't matter.
  7. WVhillbilly
    Oct 20, 2010
    38,849
    WV
    Aluminum heads, better make sure the torque is right or a miss will be the least of your problems.
    Barry likes this.
  8. Zuber
    Sep 28, 2004
    6,117
    Been a Mechanic for 45 years, hasn't been a problem so far.
  9. soyanarchisto
    soyanarchisto Long timer Supporter
    Sep 1, 2005
    6,421
    Sunny PDX
    Recommendations for a new jack? The piece of shit that came with my JKU went tits up today while doing a lift kit.
  10. WVhillbilly
    Oct 20, 2010
    38,849
    WV
    Floor or trail?
    The new ARB is expensive, but works really well.
  11. UtahGuido
    UtahGuido Long timer Supporter
    Nov 29, 2007
    10,774
    Spine 'O the Wasatch
    Airing down* in Moab last week. Dog on guard:
    *I’ve got to get more adventurous with airing down. On the road I’m up around 45 psi and when I “air down” I only go down to around 30 psi, which soften the ride a bit but I think sort of misses the point. Next time I’m going to get bold and go down to 20 psi. From what I’ve read you can drop into the single digits before you have to worry about popping a bead. These tires are 235/85/16s for reference.
    DyrWolf likes this.
  12. WVhillbilly
    Oct 20, 2010
    38,849
    WV
    Run 34 on the road and 18-20 off.
    Why are you at 40 on road? That has to ride and handle like shit.
    Dealer tech set my wife's tires at 45 ish once, it was sliding in the rain on curves.
    OConnor likes this.
  13. Daniii
    Daniii geezer Super Supporter
    Sep 29, 2005
    39,506
    Plano Tx
    The tires on my jeep are so big and my compressor so small, that I'd be more than an hour refilling the tires. :bluduh Think I need a portable high volume compressor.
  14. Stravoxylo
    Stravoxylo Been here awhile
    Nov 21, 2008
    429
    LI NY
    Reason #47 for unpainted fenders. When your 3yo wants to store her rocks for her playhouse:rofl
    zookster likes this.
  15. soyanarchisto
    Sep 1, 2005
    6,421
    Sunny PDX
    Responding to my own post. I needed something in a hurry so went to harbor freight and bought another scissor jack which also failed on me. WTF? My luck I will get my first ever flat.
    Import likes this.
  16. UtahGuido
    Nov 29, 2007
    10,774
    A man like you needs a good pump. I’ve got a Viair 300P which does the job on my tires with capacity to spare. They make one, the 450P, that has a 100% duty cycle so you could use it to inflate a blimp.
  17. Daniii
    Sep 29, 2005
    39,506
    Plano Tx
    Thanks. I'll likely be looking into that.
  18. UtahGuido
    Nov 29, 2007
    10,774
    Yeah, the kit comes in a nice little bag with the pump, long leads to clamp to a battery, and a nice air hose/chuck.
    I like the idea of inflating a blimp. Be a good advertisement.
    Daniii likes this.
  19. DyrWolf
    DyrWolf Long timer Supporter
    Jan 21, 2012
    2,502
    RICHMOND VA
    Mine are at 40 also Think I will drop and check millage next trip
  20. WVhillbilly
    Oct 20, 2010
    38,849
    WV
