    Dismiss Notice
NX250 Thread -- official ADV owners manual
Discussion in 'Thumpers' started by valvecrusher, Mar 17, 2008.
  1. Kolb Driver
    Kolb Driver Been here awhile
    Oct 21, 2016
    186
    Kingsport, TN
    Does anybody know of a source to replace the turn signal indicator bulbs with something a lot brighter? On a couple of occasions lately, I have failed to click off my turn signals after completing a turn, and the stock indicators are not bright enough to catch your attention. So then I go for miles like the typical doddering old oaf, blinking away...
    I thought about adding a couple indicators on the sides of the windscreen or up on the turn signals, more in my line of sight, but if I could simply replace the stock bulbs with something much brighter, I would like to try that first. Suggestions?
  2. adilmon
    adilmon Been here awhile
    Oct 1, 2010
    159
    While waiting for a new accelerator pump diaphragm I just ordered and aftermarket LCD dash for the AX1. I looked around to get one that replaced the mechanical speedo with an electric one (one less cable to oil).
    Not sure how I'm going to set up the gear position selector and the fuel level light is redundant, but will enjoy trying stuff out. May even wire it up to make it a quick change to revert to stock if i decide to sell it.
    Why?: I do appreciate an LCD dash. The suzuki freewind and suzuki djebel clocks swap was an option, but they are small, rare and the stock analogue KPH speedo with an mph converter isn't the easiest to read.
    dvgeek and PTC like this.
  3. Bunce1260
    Bunce1260 Been here awhile
    Feb 16, 2017
    165
    Oregon
    FYI - 20% off on ebay today with a code. PICKDADSGIFT
    I just picked up a GSF600S shock.
  4. Bunce1260
    Feb 16, 2017
    165
    Oregon
    Regarding lights - Thanks Spurlock, just the tip I was looking for. My tail light is LED so current draw of a 20W (so that's about 1.7 amps?) LED light should be ok, right?
  5. PTC
    PTC Turd polisher
    Nov 20, 2008
    869
    masshole mofo
    I just installed a round digital gauge so if you need a hand with the wiring let me know. Mine uses a Hall effect sensor/ magnets for the speedo. I haven’t hooked it up yet due to needing to fab up a tricky bracket.
    I’m interested in that one though!
    Let me know if it fits properly? It would be a lot easier for sure
    adilmon likes this.
  6. scrambler66
    scrambler66 Been here awhile
    Oct 5, 2011
    743
    Germany
    a new source for shindengen CDIs popped up :D Actually they were around for a couple of years, but since they were sold under the label "sun" nobody noticed. The sun cdi looks exactly like the original, with all the right markings in the right place (KW3H etc.).
    Only difference: where the OEM CDI got shindengen engraved the sun has a sticker
    But under the label is :clap
    It turns out that sun gets this CDI from shindengen but sells it under their own label. Those cdis are also sold by Tourmax. And some years ago someone already bought a sun CDI and measured the ignition advance - which were just like stock.
    Downside is that the only source of SUN cdis I know does not deliver to the US https://www.ebay.de/itm/CDI-Steuerg...721804?hash=item1c1c68e94c:g:ANUAAOSwGIRXatG~
    spychic, dvgeek, Spurlock and 2 others like this.
  7. ski-line900
    ski-line900 Been here awhile Supporter
    Nov 20, 2012
    618
    Seattle
    So you're going to be the middle man to North America? :)
  8. valvecrusher
    valvecrusher tractus pro pensio™
    Feb 15, 2007
    2,152
    Dos Circlos
    @Kolb Driver
    I would use LED lamps of the highest spec i could find, MUCH brighter than the OEM 30yo bulbs.
    Someone used to post here, letting us know WHICH LEDs could be trusted........
    (I bought some LEDs off E.blech-(bay) and they were super dim, much dimmer than stock........were supposed to be brighter....)
    But my buddy gave me some he got off Ebay and they are crazy bright......I would ask him, but i don't know what happened to the guy
    Kolb Driver likes this.
  9. Kolb Driver
    Oct 21, 2016
    186
    Kingsport, TN
    I have used this company before, and their bulbs are really good. https://www.superbrightleds.com/cat/instrument-cluster-gauge/
    What I don't know is - what is the part number of the original equipment turn signal indicator bulb, so I can order it using the super bright LED replacement?
  10. Spurlock
    Spurlock Long timer
    May 5, 2015
    1,996
    Vacaville, N. California
    Hi Kolb Driver,
    I listed the various types of instrument bulbs in a post here. Turn signal indicator bulbs are wedge base 12V 3 watt, part # 34908-KM1-671. I'm not sure anything brighter is available in either LED or regular. How about wiring a helmet buzzer into the turn signal circuit? Ha ha. I need that sometimes.
    -Bill
    adilmon and valvecrusher like this.
  11. valvecrusher
    Feb 15, 2007
    2,152
    Dos Circlos
    you need a T6.5 bulb, a MINI-wedge base(or Full Wedge -T10/194/168)
    There are two sizes, and a few different wattages, iirc
    They are both 'blade type' lamps....
    One size, is the T10(also known as 194, 168)
    The other size is T6.5 Wedge(mini-Wedge)
    I have not pulled my cluster, but it seems like there were two sizes,:hmmmmm
    three styles(wattages)total, and then turns were the small ones?
    Wedge --- T10 (194/168)
    mini-wedge --- T6.5
  12. Bunce1260
    Feb 16, 2017
    165
    Oregon
    I have to ride for about an hour to get to the mountain roads, there doesn't seem to be many options to keep the wind off.
    In the interest of fitting a decent generic handlebar mount windshield, I'm considering swapping to a dirt bike style headlight setup that's mounted to the forks. For those that have done this, how did it work out for you and what did you do with the guages etc.?
  13. PTC
    PTC Turd polisher
    Nov 20, 2008
    869
    masshole mofo
    If you do this, you leave the tank fairings vulnerable and unsupported.
    Search” trash can windshield “
    I did this headlight swap and it was a big job as there is ALOT of wiring to hide. I think the trash can is a great easy to remove mod and I’ve heard great things about them.
    valvecrusher likes this.
  14. Bunce1260
    Feb 16, 2017
    165
    Oregon
    That looks pretty good.
    Have you, or anyone else tried one on the NX?
  15. PTC
    PTC Turd polisher
    Nov 20, 2008
    869
    masshole mofo
    I haven’t, but you can make them for just a few bucks, so it’s worth experimenting. Check YouTube, the guy credited to them has a few how to videos with measurements
  16. Bunce1260
    Feb 16, 2017
    165
    Oregon
    Yeah I watched the videos, I was just wondering if someone had the measurement to fit the NX cowl.
  17. SaDoW
    SaDoW Adventurer
    Feb 13, 2011
    85
    hi !!!! is there a chain slider replacement????? does anyone know???
  18. Bunce1260
    Feb 16, 2017
    165
    Oregon
    Does anyone happen to have a Suzuki DR as well as an NX and can compare sizes of the headlight cowl for making a fairing?
  19. PTC
    PTC Turd polisher
    Nov 20, 2008
    869
    masshole mofo
    Try making out of cardboard with the YouTube measurements and modify from there @Bunce1260
  20. scrambler66
    Oct 5, 2011
    743
    Germany
    apparently at least local machine knows an US source for the SUN CDI (see below)
    adilmon likes this.
