    Dismiss Notice
NX250 Thread -- official ADV owners manual
Discussion in 'Thumpers' started by valvecrusher, Mar 17, 2008.
  1. CORNATO
    CORNATO n00b
    Oct 7, 2019
    8
    LOUISIANA
    Ok, so the bike is in layup right now. It's been some pretty nasty weather and wife had emergency surgery last week so it went to the back burner. But I think I figured out why it was running rough all of the sudden. I left the choke on half way. *facepalm* But now the carb is leaking, so I figured I'm gonna do a total maintenance check.
    I plan on changing oil and filter, cleaning oil screen, pulling carb and cleaning it, check AP adjustment, checking and setting valve clearances, clean and lube chain, check timing chain, and whatever else I can. Since I don't really know the history of the bike I'd like to set a benchmark and do all the stuff now so I know the condition and it gets done.
    I put the generic MadDog seat cover on and man what a game-changer. Love it. In the process of making a windshield, I have it cut just need to shape it. And got some decals on it too, not original but cool I think. I got some bar risers too, but am having issues. The hydraulic brake line wont budge, it's pretty m uch at its max.
    Is there another bike's hydraulic line that fits? Can I order just a longer length, or make one? I'm sure someone here has done this before, but I searched the forum and no one has mentioned what they did for the brake. Just that they put bar risers, and what clutch cable to get.
    valvecrusher likes this.
  2. helloish12321
    helloish12321 Adventurer
    Oct 20, 2019
    14
    Charleston, SC
    I have been tearing down my bike over the past week after seeing some wiring harness damage and quite a bit of missing paint and rust.
    It was definitely unnecessary. I was going to spot paint it with a spray can and leave it but I figured I might as well go all the way and have some fun with it.
    First, I chose to get a Rick's hot shot CDI to replace the more than likely faulty OEM unit. Here is what comes in the box for anyone interested.
    I wanted to repaint the frame with single stage automotive paint for durability. I stripped the paint off then wire brushed and sanded the frame. I couldn't find the factory frame paint code so I settled with going for a simple semi gloss black. I think the black I used was "Black Onyx" which is an OEM toyota color.
    Here it is after wet sanding, after priming and the first coat of paint, and after 2 coats and 24 hours to cure. I was told to use a 25% mix of flattening agent to get a semi gloss out of my single stage paint. I used closer to 30% but it came out very glossy. I'm not upset about it, I think it turned out fantastic. It is a very deep smooth color. I can tell just from handling it that the paint is thicker than the factory paint. time will tell if its more durable (I think it will be) but its certainly more durable than spray can paint and that's what I wanted.
    Now I can start to reassemble the bike and finally start riding it :thumb.
  3. helloish12321
    Oct 20, 2019
    14
    Charleston, SC
    I found this from 2018. Its on page 657.
  4. Kolb Driver
    Kolb Driver Been here awhile
    Oct 21, 2016
    186
    Kingsport, TN
    Thank you!
  5. ichallein
    ichallein Been here awhile
    Aug 10, 2007
    155
    16 kilómetros al norte de África
  6. DietcokeAni
    DietcokeAni Annette
    Oct 6, 2013
    39
    Georgia, US
    [QUOTE="
    .[/QUOTE]
    How much did you pay for that CDI?
  7. arescec
    arescec Been here awhile
    Sep 27, 2018
    230
    Croatia
    Deleted that post, wrong forum. Ups.
    But yeah I might have purchased 1998 Trabsalp 600. Heaps of power and torque compared to NX but also quite heavy and vibey.
  8. Dsgb031
    Dsgb031 The older I get, the faster I was
    Oct 4, 2016
    393
    D-port IA
    That is a VERY well done build. My hat goes off to you sir
    DietcokeAni likes this.
  9. DietcokeAni
    DietcokeAni Annette
    Oct 6, 2013
    39
    Georgia, US
    I have the same question about the brake line.
    I don't know if you've seen the info about the front sprocket, but when you check it, look to see that it has the raised part on the back side. If it doesn't, you'll be able to see wear on the teeth from the wobble. Neither of my 88's had the correct one - and one (24K miles) had wiggled one of the two bolts off! The other one (6K miles) had a sprocket that looked like it was on a racebike for 10 years.
    I'm now waiting on parts to replace the CDI, spark plug and clean the carb on The Ratbike. (24K m)
  10. helloish12321
    Oct 20, 2019
    14
    Charleston, SC
    How much did you pay for that CDI?[/QUOTE]
    I ordered it directly from their website. paid about $130. Not cheap but its really the only option in the US it seems.
  11. helloish12321
    Oct 20, 2019
    14
    Charleston, SC
    I just got my bike running tonight after having it stripped down to repaint the frame. It runs well but I'm having some confusing problems with my clutch. I only rode it once to get it home so I cant say if its a new problem or if I am just now noticing.
    Now that the bike runs I can tell that the clutch does not fully disengage. It has resistance rolling while the engine is off in 1st gear and clutch pulled in. If it is placed in gear with the engine running it will want to roll forward. If I hold it back the bike stalls.
    I have already changed both of the cable adjustments to as tight as they can be and it still cant pull the clutch in far enough. I'm not sure where to go from here.
    I mentioned earlier that the clutch lever in the right engine cover has some wiggle in it, you can see it move a bit as you pull the clutch, and feel it tap on either side of its bore when you move it with your finger. I don't know if it is related but I'm sure it doesn't help.
    Does anybody have suggestions on what to look at before I pull the side cover off and start poking around?
  12. PTC
    PTC Turd polisher
    Nov 20, 2008
    868
    masshole mofo
    Put it in third while running, roll backwards while slipping the clutch a bit. Repeat 5-10 times. If the plates are stuck this will sometimes free them up.
    #2 Look in the oil fill hole while pulling In The lever to see if the plates move properly.
    #3 pull and measure the cable. Perhaps it is stretched and not pulling enough.
    Then, tear into into it. But order a gasket and a stake nut first as you’ll need to replace those it you do surgery.
  13. helloish12321
    Oct 20, 2019
    14
    Charleston, SC
    I went outside to check the clutch again.
    I pulled the cable and measured along the entire length (including the curve) at about 108cm. I couldn't find a spec for the original length, but a listing on ebay shows 103cm.
    Looking through the fill hole, I can see that all of the plates come loose (or at least aren't stuck together) when the lever is pulled.
    After checking that, I assumed the cable was simply worn out and too long. I had somebody carefully pull the lever with a screwdriver to the end of its travel (past where the cable can pull it to.) While the bike was on I placed it in 1st. The bike lurched and wanted to pull forward.
    Given this, should I assume the problem is internal and plan on removing the cover?
  14. Spurlock
    Spurlock Long timer
    May 5, 2015
    1,996
    Vacaville, N. California
    Sounds like the clutch is not disengaging enough. Since you say the shaft going into the case wobbles side to side, not all of the cable travel is actually separating the clutch discs. Time to pull the case and the clutch lifter shaft and see what the problem is. Most models have a needle bearing there. Possibly the bearing is missing?
    -Bill
  15. Kolb Driver
    Oct 21, 2016
    186
    Kingsport, TN
  16. PTC
    PTC Turd polisher
    Nov 20, 2008
    868
    masshole mofo
  17. Too Old for This
    Too Old for This Adventurer
    Apr 8, 2019
    85
    Massachusetts
    Someone stole it it's gone
    PTC likes this.
  18. valvecrusher
    valvecrusher tractus pro pensio™
    Feb 15, 2007
    2,152
    Dos Circlos
    travial, DietcokeAni and PTC like this.
  19. RebelYell
    RebelYell Been here awhile
    Jan 2, 2012
    975
    somerset nj
    I'm looking for knobby tires but can't seem to find anything other then the trailewings..
  20. scrambler66
    scrambler66 Been here awhile
    Oct 5, 2011
    743
    Germany
    patience - the new Bridgestone AX41 is coming in Jan 2020 :-)
    PTC likes this.
