Odyssey PC-680 in 1150GSA
Discussion in 'GS Boxers' started by PaulBarton, Jul 22, 2020.
  1. Francistor83
    Francistor83 Been here awhile
    Feb 26, 2015
    155
    Paris
    Yep. It's the same story as the voltage regulator mod, these batteries may not last if not charged according to specs (logical, would you say.... :hmmmmm) Amperage seems critical. The PDF also helped me after I "killed" the first battery.
    #21
  2. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    1,838
    Southwest Washington
    ’01 R1150GS, key out, if I remember correctly I have and almost 3.0 amp draw. Pulled two fuses, 0.0 amp draw. Now if the bike is going to sit for any length of time I pull the two fuses. My2cts.
    #22
  3. darklight79
    darklight79 drink it , ride it , nail it
    Jun 2, 2010
    1,444
    Eureka ,Calif
    Which 2 fuses did you pull?
    #23
  4. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,703
    DC metro
    Fuse #3 for the RID is the primary parasitic draw, and #5 for the Motronic is usu. a minor draw. The reason to pull that pair (2) of fuses is that they are always hot. A Kisan Signal Minder, if present, introduces still another parasitic draw.
    There may be one more, can't recall, but these are the big ones. Pulling the fuse for the RID alone is what I gen. do for storage periods measured in weeks. If months I often just disconnect the neg. (-) battery lead. YMMV.
    #24
    rg sw wa. and Francistor83 like this.
  5. rg sw wa.
    Feb 9, 2011
    1,838
    What lewis said, # 3 and #5 fuse.
    #25
