Odyssey PC535 Install in F800GS
Discussion in 'Parallel Universe' started by Y E T I, May 8, 2010.
  1. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,520
    San Diego
    My battery was starting to take a bit of effort to start my bike and I've been wanting to replace the stock battery with an Odyssey PC535 for a while so I decided to do it this morning. My battery was delivered last week for about $125.
    First thing was to make sure it was fully charged and do a size comparison. Here's the Odyssey side-by-side with the stock Exide.
    Measurements are:
    Stock: 146mm x 85mm x 145mm
    Odyssey: 167mm x 90mm x 153mm
    The top of the Odyssey:
    First you need to remove the "tank" cover by removing the six (or four in my case) T25 Torx bolts which hold it on. My mess then looked like this:
    First thing was to remove the stock battery. There are two T30 Torx bolts on either side of the battery which hold down the plate. You can barely see one of them on the right side, the other is covered by wires.
    Then unhook the battery connections and remove the battery. Easy.
    I removed the airbox cover to get a little more room, but it's not necessary. This is what the battery compartment looks like. I test fit the battery and realized that the fins on the batery fit nicely with the fins in the battery box so the only things I had to remove were the "fins" at the front of the battery box which I circled in red below:
    I used a carpenters chisel. It broke one of the corners off but I really don't care. Here's what the battery tray looks like with the corner tabs removed:
    Just as I finished I got a flyover by these guys. This is only a few of the planes. There were probably 30 total, with a bunch of them being bi-planes. Totally cool!! :devildog
    With the front fins removed the battery just dropped right in. I kept the brass connecter on the positive terminal since I couldn't bend the wires the right way, but removed it from the negative terminal and connected the wires directly. I also made a strap from an offical BMW tie-down strap. (Thanks for the idea Joel!) Looks like this installed.
    Then I just buttoned everything back together and fired her up. The bike fired right up and seems happy as a clam. I need to have the dealer re-set the service light :rolleyes but everything else is good to go. :ricky :ricky
    It took me about an hour and a half total but most of that time was spent trying to figure out how to remove the battery tray to cut the tabs off cleanly. I gave up and went with the "bigger hammer" method instead. :lol3
    It should have only taken me a half hour or so. :baldy
  2. RV8Pilot
    RV8Pilot Blue,Green,Blue,Gree.....
    Jun 16, 2004
    214
    Westco makes a direct drop in replacement battery for the stock battery without any mods to fit it. Just FYI
  3. JRWooden
    JRWooden Long timer
    Jul 5, 2008
    5,693
    The great state of confusion
    Maybe a dremmel tool with a cut-off wheel would do the trick? :evil
    Although, with my limited manual dexterity I might cut-off something else along with the tab... :lol3
  4. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,520
    San Diego
    I tried but I just couldn't get it in there. The battery box just isn't wide/deep enough to get the right angle. That's why I was trying to get the battery tray out. I was about to start pulling the airbox to get to it when my wife started doing the ":ddog I thought this was a half hour project . . ." :hide At that point I decided to just cut and run.
    And yes I was using the small attachment thingy, not trying to stuff the whole Dremel down in there. :lol3
  5. JRWooden
    JRWooden Long timer
    Jul 5, 2008
    5,693
    Yeah.............. it's not that big a box ....
    sigh.................
  6. David_S
    David_S Long timer
    Feb 8, 2003
    1,130
    Sullivan, Ohio
    :lurk
  7. JoelWisman
    JoelWisman Long timer
    Apr 22, 2009
    1,392
    STL, MO, USA
    The Odyssey is head and shoulders better then any other battery I am aware of.
    The only piece of the bike you need to modify is the battery tray. If you wish to do a clean job, a sharp wood chissel works, or you can remove the airbox and slide the battery tray out of it for easy access.
    If your worried about modifying any part of the bike, a new battery tray is really cheap.
    If your battery is failing because it is never getting fully charged, run down by excessive loads, or run flat by the CAN bus because you have hooked up something it doesent like, the odyssey will eventually fail as well.
    The odyssey is however a much tougher battery, and with more cranking amps as well.
  8. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,520
    San Diego
    Yup, what Joel said. Perfectly happy with my Odyssey so far. :lol3 Even started the 800 after I left it sitting over Sunday when I rode the 400. :evil
    #8
  9. David_S
    David_S Long timer
    Feb 8, 2003
    1,130
    Sullivan, Ohio
    Any idea of the life expectancy of the odyssey versus stock? My stocker is going on 1.5 years old and while it hasn't given me any problems I'm thinking about installing and odyssey rather than waiting to get stranded and having to settle for an off the shelf battery that is available at that time.
    #9
  10. johngil
    johngil Reseda, CA
    Jun 28, 2007
    3,817
    #10
  11. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,520
    San Diego
    I've never had a stock BMW battery last longer than 1 1/2 years. I commute just about every day and if the bike is going to sit more than a couple of days it goes on the tender, so I figure my batteries live easy lives. The problem is, they tend to die sudden and unexpected deaths rather than giving you any warning.
    #11
  12. RV8Pilot
    Jun 16, 2004
    214
    #12
  13. JRWooden
    JRWooden Long timer
    Jul 5, 2008
    5,693
    Free pitch for a fellow rider/shop owner (no affiliation):
    Rob over at F800Depot has the Westco for ~$90
    http://f800depot.com/westco-battery-svr14-p-492.html
    I'll either go with that or the Odyssey, if I can mod. the battery box without the desire to use plastic explosive :lol3
    #13
  14. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,520
    San Diego
    Had I known I think I would have gone with the Westco. Oh well . . .
    Oh, and I would have bought it from Rob, great guy with great service. :thumb
    #14
