OE Suzuki spoked V-Strom rims...
Discussion in 'Japanese polycylindered adventure bikes' started by svs, Nov 23, 2014.
  1. pjm204
    pjm204 Long timer
    Jan 28, 2010
    2,320
    Murphy, Idaho
    If I could get them for $1100, I'd probably do it.
    #21
  2. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,075
    Jefferson, GA
    2015 Pricing is set up on this website:
    https://www.rockymountainatvmc.com/oem-schematic/4
    Tag Part # Description Reg. Price Our Price Stock Status Qty Add?
    1 54111-11J00 HUB, FRONT $583.87 $566.35 Usually ships in 5-7 business days
    2 09180-17067 SPACER (17.5X25X88) $14.79 $13.02 1 In-Stock
    3 08133-62037 BEARING $19.04 $16.76 4 In-Stock
    4 09282-24004 OIL SEAL (24X40X7) $5.62 $4.95 2 In-Stock
    5 55311-11J00 RIM, FRONT WHEEL (19M/CXMT2.50) $782.18 $758.71 Usually ships in 5-7 business days
    6 55321-11J00 SPOKE, FRONT WHEEL INNER $5.85 $5.56 Usually ships in 5-7 business days
    7 55322-11J00 SPOKE, FRONT WHEEL OUTER $5.85 $5.56 Usually ships in 5-7 business days
    8 55326-11J00 NIPPLE, FRONT WHEEL $4.02 $3.82 Usually ships in 5-7 business days
    9 54162-27G00 RING, SPEED SENSOR FR (50T) $91.59 $80.60 Usually ships in 5-7 business days
    10 07130-0512A BOLT $1.67 $1.59 Usually ships in 5-7 business days
    11 43130-24A00 VALVE ASSY, WHEEL RIM (TR412) $7.16 $6.30 6 In-Stock
    12 54711-08F10 AXLE, FRONT $69.37 $61.05 Usually ships in 5-7 business days
    13 54750-31F00 SPACER, FRONT AXLE, LH $16.41 $15.10 Usually ships in 5-7 business days
    14 54751-10G01 SPACER, FRONT AXLE, RH $11.91 $10.96 Usually ships in 5-7 business days
    15 59210-44G11 DISC, FRONT BRAKE $276.87 $243.65 Usually ships in 5-7 business days
    16 09106-08160 BOLT (8X21) $2.88 $2.74 10+ In-Stock
    17 55110-06G11 TIRE, FRONT (110/80R19M/C 59H) | BRIDGESTONE $197.83 $174.09 Usually ships in 5-7 business days
    18 55411-11J00 WEIGHT, WHEEL BALANCE (5GRAM) $3.43 $3.26 Usually ships in 5-7 business days
    1 64111-11J00 HUB, REAR $333.61 $293.58 Usually ships in 5-7 business days
    2 65311-11J00 RIM, REAR WHEEL (17M/CXMT4.00) $469.47 $413.13 Usually ships in 5-7 business days
    3 65321-11J00 SPOKE, REAR WHEEL INNER $6.03 $5.73 Usually ships in 5-7 business days
    4 65322-11J00 SPOKE, REAR WHEEL OUTER $6.03 $5.73 Usually ships in 5-7 business days
    5 55326-11J00 NIPPLE, REAR WHEEL $4.02 $3.82 Usually ships in 5-7 business days
    6 69211-06G10 DISC, REAR BRAKE $208.19 $183.21 Usually ships in 5-7 business days
    7 09106-08160 BOLT (8X21) $2.88 $2.74 10+ In-Stock
    8 64741-10F00 SPACER, REAR AXLE RH $16.25 $14.95 Usually ships in 5-7 business days
    9 64610-35F40 DRUM, REAR SPROCKET $207.23 $182.36 Usually ships in 5-7 business days
    10 64651-35F10 ABSORBER, REAR HUB SHOCK $9.57 $8.42 10+ In-Stock
    11 54162-27G00 RING, SPEED SENSOR FR (50T) $91.59 $80.60 Usually ships in 5-7 business days
    12 07130-0512A BOLT $1.67 $1.59 Usually ships in 5-7 business days
    13 64711-03F00 AXLE, REAR $93.72 $82.47 Usually ships in 5-7 business days
    14 64733-06G00 RETAINER, REAR SPROCKET DRUM $21.58 $19.85 Usually ships in 5-7 business days
    15 64751-27G00 SPACER, REAR AXLE LH $20.06 $18.46 Usually ships in 5-7 business days
    16 08319-3118A NUT $16.25 $14.95 1 In-Stock
    17 09180-20112 SPACER (20.8X27.2X124) $23.14 $21.29 Usually ships in 5-7 business days
    18 09262-32022 BEARING (32X65X17) $37.49 $32.99 4 In-Stock
    19 09285-39001 OIL SEAL (39X65X7) $8.31 $7.31 4 In-Stock
    20 08123-62047 BEARING $18.24 $16.05 5 In-Stock
    21 09285-28001 OIL SEAL (28X47X7) $5.12 $4.51 3 In-Stock
    22 64511-27G00 SPROCKET, REAR (NT:44) $57.69 $49.04 2 In-Stock
    23 08319-3110A NUT $2.09 $1.99 7 In-Stock
    24 65110-06G11 TIRE, REAR (150/70R17M/C 69H) $242.63 $213.51 Usually ships in 5-7 business days
    25 43130-24A00 VALVE ASSY, WHEEL RIM (TR412) $7.16 $6.30 6 In-Stock
    26 55411-11J00 WEIGHT, WHEEL BALANCE (5GRAM) $3.43 $3.26 Usually ships in 5-7 business days
    #22
  3. Starchamp
    Starchamp Rebel Scum
    Apr 9, 2009
    1,487
    Out there
    So, about $2800 + S&H (+ assembly, truing, mounting, balancing if you don't DIY), assuming you can re-use the tires, spacers, sprocket and carrier, rotors, ABS rings, hardware etc. from the cast wheels.
    #23
  4. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    7,842
    They are not abs compatible, right?
    Sent from my K01A using Tapatalk
    #24
  5. eakins
    eakins Butler Maps
    May 29, 2002
    36,153
    Fort Collins, Colorado
    So has ANYONE gone and bought XT wheels for their 2012+ 650 and resold their 3 spokes and can say what the end upgrade price costs???
    I'm guessing it's easier to pull all your mods, sell your bike and pick up a used or closeout XT instead. Especially now since the 15-16 XT is about to become an old model.
    #25
  6. cyclopathic
    Dec 23, 2007
    7,842
    I've looked at part prices and it is ridiculous, especially when you can get a pair of dirt bike hoops for <$300.
    Does anyone know if RAD ABS issue is limited to front hub only?
    #26
  7. Bucket Boy
    Bucket Boy The other mechanic
    Sep 16, 2006
    664
    Ridgway, CO
    Just to clarify for everybody. You can put the OEM spoke wheels on all prior year DL650s. I have no idea about the 1000 as I’ve never owned one. But I’m on number 13 650.
    #27
  8. Lewilewi
    Lewilewi Ride it like you stole it......
    Oct 22, 2017
    2,890
    Europe
    ? What...
    You have 13, dr650s
    Or you have had 13 650s
    #28
  9. jfman
    jfman Long timer
    Mar 10, 2012
    3,093
    Montreal (traveling Americas June '17 to May '18)
    I have sold rear vstrom wheels twice(first gen) and they dont fetch good money at all. 100$ a piece. Front wheels are very easy to sell for 250 - 350 depending on how lycky you are.
    The cast wheels on both the 650 and 1000 vstrom are tough, very tough. I put my wee strom 650 thru hell (two up, packed like a mule thru South America on mostly back roads) and they fared beautifully.
    #29
  10. Bucket Boy
    Sep 16, 2006
    664
    Ridgway, CO
    Only have 3 now.
    #30
  11. Bucket Boy
    Sep 16, 2006
    664
    Ridgway, CO
    0AE4ED2E-BEF8-4896-895B-9736E41BFEA1.jpeg If you’re using the strom for its intended use then cast wheels are great! But if you heavily modify your bike and ride aggressively then they don’t last long.
    I’ve personally bent 3 fronts and 2 rears over the last 200k miles. Now I only run XT wheels without issues, jumping it is common. (My Stroms weigh 420lbs)
    #31
    Argus16, Motor7 and tjzondrz like this.
  12. rickh123
    rickh123 Been here awhile
    Aug 15, 2010
    434
    ON, Canada
    Interesting. I just got my #13 V Strom last week (2017) but in my case 2x1000, then 5xWee, 5xWee2 and finally first Wee3 (XT). Even more interesting that I own 3 650 right now. One is a parts bike though so it doesn't count. (That would be 14). It is 2012 -16 model with only 8000 miles on it. It starts and runs great. Clean title so if anybody needs a frame, engine or any other parts just ask. I might have it.
    #32
