Off Road Tire Pressure
Discussion in 'Pacific Northwet - Where it's green. And wet.' started by Chanesj, Jun 2, 2020.
  1. Chanesj
    Chanesj 2013 Triumph Tiger XC
    Aug 30, 2019
    99
    Black Diamond, WA
    I have Tiger 800 and plan on putting Shinko big block adv tires on it. Never tried to run at lower PSI on forest service roads, etc and kept it at stock. Reading about the benefits of lowering PSI and ppl are saying mid to low 20s on front and rear. Thoughts?
  2. AC09
    AC09 Been here awhile
    Jun 23, 2016
    136
    Western Warshington
    For cruising around forest service roads, I haven't found the time it takes to stop and air down/up is worth it.
    If you are going to tackle loose rock, sand or mud at low speeds then there is a definite benefit. Pinch flats become a issue at a certain point... on my Tiger 800, anything near or below 20 psi makes me nervous.
  3. Chanesj
    Aug 30, 2019
    99
    Black Diamond, WA
    Im doing the bdr in july so maybe ill hang in the mid 20s range
  4. tdewitt
    tdewitt gas'n it
    Feb 23, 2015
    1,167
    Barton Oregon
    If you ride like me 25 in the rear and 27-29 in the front. Your wheels will thank you. Even then be careful I pinched and new Shinko on the front of my V strom and it had 40psi. Had to replace the tire as it was cut in the bead. Be sure to carry front and rear tubes when ever running any BCDR. even if you are running tubeless.
  5. northbender
    northbender Adventurer
    Mar 31, 2012
    33
    My 990 behaves much better on loose stuff with 22-25 psi in the tires.
    (Tractionator rear and scorpion rally front)
  6. tomasv
    tomasv Check the Czech!
    Jun 14, 2006
    1,291
    Seattle area
    Just carry the front - you can stick it into the rear in the case of an emergency
  7. HellsAlien
    HellsAlien a has-been that never-was
    Nov 16, 2004
    4,126
    Baja Sur winter, Columbia City summer
    Chan, go out on street pressures, go down a few miles of 2-track on street psi, then drop to 24F, 26R hot , and go back on the track you went in on. Obviously, take a pump & gauge, or buddy with same.
    Then tell me if you feel any difference going in on the brakes & coming out on the gas.
    I've never ridden with you, so I don't know your style/where you're at on the performance riding pecking curve (and I don't really care/doesn't matter).
    But an 800 puts a lot of load on the ground vs a dirt bike, so I think you will notice a difference. You get to decide if its better.
    I ride a 950A into just about anything at above pressures, but it is 2X the weight of my 250, hence takes twice as much air
    Chanesj likes this.
  8. 12120
    12120 Unwittingly Domesticated
    Apr 23, 2012
    1,026
    Longview, WA
    More than this.... almost home to.
    #8
  9. Big Tall Bastard
    Big Tall Bastard Voice of Reason
    Jun 11, 2008
    1,204
    Bend, OR
    I run 25 rear and 26 front on my 1090 R with Motoz Adventures. I was doing a road ride last Sunday with 35 and 36 and did a short section of dirt. It was damn near unrideable compared to what I'm used to. If I'm doing mainly dirt I'll ride 50-100 miles at the lower pressure on the pavement and not bother to reinflate them. It feels fine and I don't really care about tire wear.
    #9
    Apple Jam and Reeds Moto like this.
  10. Ladybug
    Ladybug Bug Sister Supporter
    Nov 6, 2005
    16,583
    Spokane Valley, WA (the dry side of the mountains)
    This guy knows a bit about riding dirt and the first thing he addresses in this video is tire air pressure.
    #10
  11. BybeeKiwi
    BybeeKiwi Been here awhile
    Mar 5, 2015
    116
    Portland,Oregon
    I never drop tire pressure, and I spend lots of time in the dirt with my tiger.
    Pinch flats are a real thing, these bikes are heavy.
    What is stock air pressure? 33psi front and I think 36 in the rear. Tkc80 is a great front tire hard to beat. Back tire is where there are lots of options and opinions,
    Crap now I brought up tire brands this thread is off to hell in a handbasket now 20190715_103821.jpg
    #11
  12. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,117
    Beaverton, OR
    I use Mobil !
    #12
    TK-421 likes this.
  13. Big Tall Bastard
    Jun 11, 2008
    1,204
    Bend, OR
    That is a terrible combo with a Dunlop 908 front!
    #13
    TK-421 and BybeeKiwi like this.
  14. peterman
    peterman cop magnet
    Jan 2, 2006
    19,532
    Springfield,,,,like the Simpsons,,,orygun
    Ask Apple Jam about tire presshurz,,,he lets ALL the air outa his tires!:lol3
    Hiya Jeffy!:1drink
    #14
  15. Sparrowhawk
    Sparrowhawk Long timer Supporter
    Sep 26, 2005
    4,310
    Eastern Washington, USA
    Best advice yet on this thread. Instead of relying on what others write on Advrider or experts on YouTube, go find out for yourself. Keep in mind that you're not riding a light bike so don't overdo it.
    Not all Forest Service roads are the same. Some are really rough and rocky others are smooth dirt or deep gravel. Big sharp rocks need more air to prevent damage.
    Not all adventure tires are the same. Some have very stiff sidewalls and some are softer. Stiffer sidewalls can be aired down without harming the rim or tire better than soft ones.
    Experiment cautiously on terrain at the upper level of challenging that you are likely to ride and become your own expert for the way you ride your bike.
    #15
  16. deadflagblues
    deadflagblues I need more bikes
    Nov 2, 2014
    259
    Portland, OR
    Per Bret's advice, I never air down when I'm off-road. Well, as off-road as my R1200 GS gets. Which is WABDR and gravel in Oregon.
    #16
  17. b76
    b76 Need more adventures
    Sep 1, 2009
    140
    oregon
    I run street pressure offroad on the Africa twin.
    The tires are MotoZ rallys.
    I dent wheels on my yamaha dirt bike at anything under 15psi.
    #17
  18. travisn000
    travisn000 Adventurer
    Jan 1, 2013
    97
    Triumph's recomendations...
    #18
    Chanesj likes this.
  19. Chanesj
    Aug 30, 2019
    99
    Black Diamond, WA
    Thanks guys, all great info. I think i need to get out and do some test runs in the high 20s, obviously it will be different when i have my bags packed on our WABDR trip
    #19
  20. tdewitt
    tdewitt gas'n it
    Feb 23, 2015
    1,167
    Barton Oregon
    One other thing to do before your WABCDR trip, is to take a practice trip. Load your bike and go for a ride. You can't just hang everything on the rear and think your good to go. A light front end makes for a long day.
    #20
    Scott_PDX and deadflagblues like this.
