Official Yamaha DT200 thread
Discussion in '2 smokers' started by jfman, Jul 12, 2013.
  1. gbiddy
    gbiddy n00b
    Dec 13, 2019
    5
    BC / Canada / Van Isle
    So, just pulled the trigger and picked up this little '90 DT200. $2500 CDN pesos.
    Odo says 20k kms, a couple POs, paints been touched up all over, new decals, but looks to have been very nicely taken care of. Runs, shifts, stops better than my newer bikes.
    FRIGGEN STREET LEGAL 2-SMOKE!!
    #61
    bcbullet, Dauer and sidetrack one like this.
  2. sidetrack one
    sidetrack one Chief Tiddler Supporter
    Jul 2, 2006
    10,722
    hole shaven area
    Beautiful!!!:clap
    #62
  3. gearhead86
    gearhead86 Adventurer
    Mar 7, 2010
    25
    Winnipeg, MB
    Sweet!!
    also, "Nice Rack"
    You don't see many in Canada with racks.
    #63
  4. JoSiMo
    JoSiMo n00b
    May 8, 2020
    7
    Borneo
    very nice looking bike you got there
    #64
  5. mrmarkfr
    mrmarkfr Adventurer
    Mar 22, 2013
    11
    has anyone seen case savers or engine guards/bash plates for the dt200? Looking for some for my 91
    #65
  6. sidetrack one
    Jul 2, 2006
    10,722
    hole shaven area
    My 85 DT200, fairly rare now here in Australia,its a very clean original survivor,not going ATM, but will one day!
    #66
    Pezz_gs, trokel and tommyg like this.
  7. -Z-
    -Z- Been here awhile
    Sep 30, 2012
    110
    Aix en Provence, France
    here's my 1991 DT200R
    still a few more stuff to do before she gets adv ready, but a real pleasure on the dirt.
    Went with 2 friends to do a loop in the french alps, parts of the Trans Euro Trail, but the carb having issue fucked it all up, so I had to get back home...
    IMG_20200520_001833.jpg IMG_20200520_093625.jpg IMG_20200520_104456.jpg IMG_20200521_092231.jpg
    #67
    tommyg and sidetrack one like this.
  8. berock
    berock n00b
    May 28, 2020
    3
    Marron Valley, BC
    Hi All!
    Long-time lurker here -- and I'm grateful to find this thread. I have a 4800km (off road) white and purple (!) '96 that I'm pretty much in love with. It has a mean stumble-and-die off idle that I've been fighting. It'll run on choke just fine -- which is the classic symptom of a clogged idle/pilot circuit. The carb, however, is spectacularly clean and ALL jets and passages are clear and flow unrestricted (I ultrasonically cleaned it and everything is perfect). The slide fits tight and leaks very little air. The choke doesn't leak. My next step is to chase a case air leak, so I'll make up a pressure tester and test it with the covers off. I'll report back.
    All this for a simple question.... Removing and replacing the carb is brutal. Is there an easy way that I'm missing? I fear damaging the 24 year old airbox boot.
    Posts are better with pics, so here: (weirdly, it has a Pro Circuit '89 YZ pipe modified with a stock DT clamp-on flange -- that'll get its dents fixed soon).
    #68
    enduro16, -Z- and sidetrack one like this.
  9. -Z-
    Sep 30, 2012
    110
    nice one !
    Is that an original color ? Haven't heard of any DT200 purple.. maybe some specific paint for the US market
    Yea the carb is a bit of a pain in the ass... the airbox boot is made from soft plastic so it shouldn't be an issue, I used to remove the whole airbox before, but it just take too much time, and a few screw are pretty hard to get any access...
    Don't forget to check any leak coming from the ignition case also ( that's the issue I had with my 1991 a few weeks ago )
    #69
  10. berock
    berock n00b
    May 28, 2020
    3
    Marron Valley, BC
    Purple frame, seat and shock boots are original 1996 Canadian market colours. It might look bluish-purple, but it's actually purple-purple. At first it turned me off, but it's grown on me and I like how wacky it is (the pink and orange Japanese market WR200 is a sight to behold too).
    Thanks for the leak advise.
    #70
  11. -Z-
    Sep 30, 2012
    110
    Some 600TT & 250TTR from '96 period had the same color setup too
    That was back then when the Japanese did some awesome looking colors on bike!
    the WR with the turquoise/pink color scheme is just gorgeous!
    I almost bought one, but they are extremely rare...
    #71
  12. jesse780
    jesse780 n00b
    Jun 1, 2020
    4
    Canada
    I Just picked up a 94 DT 200r 3ET for 4 hundred bucks! It,s untouched on its original build with less then 4000 kms on it boys, The topend is cooked and needs bored and the bike was dirty as hell and the plastics are ruff and painted, I ordered all new plastics from portugal, Thanks for the info on parts as well Ttrider I have to order a 66.25 piston either a cast prox or wiseco forged, The crank has a little side to side play and spins freely so the bottom end is fine, I took the clutch cover off to check it out for the first time ever and the basket looks brand new still! Unbelievable! The seals are bad obviously because there 26 years old but I have set coming. I Wonder if blaster crank seals are the same because I own a 06 se Blaster and i have new crank seals already, I,ll post some pics of the bike
    #72
  13. berock
    berock n00b
    May 28, 2020
    3
    Marron Valley, BC
    Good deal. I would go cast Yamaha OE (likely Ebay) or ProX (the best shop on our West Coast [Mongoose] likes ProX).... Forged pistons are for race engines that need a strong piston -- and they need looser tolerance because they have a greater coefficient of expansion than a cast piston. It's relatively easy to get piston slap from a forged piston in a cold engine, and you're almost guaranteed to get more scuffing wear on the skirts.
    The Blaster crank (and entire bottom end) is the same for early the DT200. DT200R is a bit different (both crank bearings are the same on DT200R where they are different side to side on DT200).
    With only 4000 kms and a damaged top end, I suspect the oil pump doesn't pump. Since you're a blaster guy, you probably know all about that... but it is easy to check pump function by turning the engine over with the kicker.
    #73
  14. jesse780
    jesse780 n00b
    Jun 1, 2020
    4
    Canada
    When I loosened the case bolts to split the motor you could pull the cases apart without even trying! There was no gasket maker left and the seals were rotten basically, There only 26 years old! lol, That might be why it run lean and blew up or like you said the oil pump, the vin sticker is dated 11 94 so its a 95. It has the purple frame and white plastics, I will post some pics of it off my phone, I took a whack of pictures and labelled everything so I can put it back together, I labelled and bagged every bolt and labelled the wiring as well just to be on the safe side
    #74
  15. nick1211
    nick1211 n00b
    Aug 14, 2020
    2
    greece
    #75
  16. nick1211
    nick1211 n00b
    Aug 14, 2020
    2
    greece
    There you go! I had templates made, as soon as I find them, I will upload them here.
    Anyone has a 1987 DT200R 2LR (not 37F) spare parts and/or service manual? I have the service manual for the Brazilian one (in Portuguese) better than nothing... In case you are lazy/desperate I can scan the 1984 in english and post it to anyone interested.
    #76
    trokel likes this.
  17. dpforth
    dpforth no inline fours
    Oct 22, 2010
    1,111
    YQQ
    #77
  18. J252
    J252 n00b
    Aug 17, 2009
    1
    Newly acquired 1990 DT200.
    Mostly stock / original expect the taillight plate assembly and some unknown aftermarket expansion chamber / silencer. (Actually mine looks a lot like berock's pipe/silencer a few posts up ^^).
    Runs good, but will need a going through before hitting the trails and road this spring.
    Tires, brakes and clutch will be the first jobs. Will be looking for proper dual sport (dirt mostly) knobbies.
    The current exhaust setup is way too loud for my neighbourhood. Before I start riding it too much I'd like to quiet it down a bit.
    Any advise on exhaust setups? Would car-exhaust header wrap around the expansion chamber tone down the ting ting a bit?
    How about if I find a quieter silencer without changing the expansion chamber to match? I suppose I should start by checking if it needs a silencer repacking first.
    In the spirit of wanting it all, I also don't want to kill off the power.
    #78
  19. ejfranz
    ejfranz n00b
    Dec 19, 2018
    6
    Maple Ridge, BC, Canada
    Stock exhaust is very quiet. The only modification to my 96DT200R is changing the sprockets. 50 on the rear with 12 in front for nasty steep single track, 13 for exploring and 14 for FSRs and roads.
    #79
  20. jesse780
    jesse780 n00b
    Jun 1, 2020
    4
    Canada
    #80
