Oil leak from gear position sensor?
Discussion in 'Dakar champion (950/990)' started by derm75, Mar 16, 2011.
  1. derm75
    derm75 I'm a brother shamus...
    Sep 14, 2007
    460
    Denver, CO
    I've got a new to me 2006 950 Adventure S that appears to be leaking a bit of oil from the gear position sensor. The parts manual for the engine shows an o-ring behind the sensor. Is this something that could be replaced pretty easily during an oil change by pulling the sensor out and putting in a new o-ring? Is the sensor plugged into or attached to anything in the transmission? How does it "sense" gear position? Magnetic? Electronic? Optical?:ear
  2. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    You can easily replace the o-ring during an oil change or by leaning the bike over on its right side. It is and electro-mechanical switch with a roller on the end of a spring senses different depth detents for neutral, 2nd, and 3rd gears. It's not plugged into/attached to anything in the trans, but the spring and roller are loose.
  3. Dogtown
    Dogtown Been here awhile
    Apr 4, 2008
    433
    Marin County
    Mine was leaking too about a year ago. You can pull the sensor and put in a fresh gasket anytime. You dont need to wait for an oil change. It only holds back a tiny bit of oil. the gasket is 50 cents and it takes 5 mins to swap out. Not sure why these things leak but its a common problem. Always nice to find out its that gasket and not a case crack from the side stand being overloaded!
    Cheers!
  4. derm75
    Sep 14, 2007
    460
    Denver, CO
    Thanks guys! Time to order a gasket. I keep triple-checking that it isn't an engine case. I just received my Black Dog sidestand mount so maybe I can do the o-ring while installing it.
  5. EastSideSM
    EastSideSM Isn't that dangerous?
    Mar 30, 2008
    1,491
    Providence, RI
    Had same thing on my SM. Replace o-ring, good to go. Easy fix.
  6. TA-Zappa
    TA-Zappa Been here awhile
    Nov 9, 2004
    173
    Ängelholm, Scania, Sweden
    Had a leaking switch to, tried to find a o-ring (the dealer didn't have in stock) that would fit and while unmounting the switch realize that the torque of the bolts are just finger tight. Pull the switch out, clean the o-ring and mount it again. While mounting the switch try to press on the switch while mounting the bolts fingertight and then torque them up.
    I don't have any leaks after that... :)
    If you look at how the bolt holes are threaded I guess you will see the reason, they are only threaded about halfway down... This means that the bolt only have a few threads to grab and the rest is locktite....
    Next time I got a leak I will replace them with helicoil and threaded all the way to the bottom.
    Cheers,
    Zappa
  7. kzahel
    kzahel Adventurer
    Jan 15, 2011
    64
    San Francisco, CA
    Found this leak on my '05 950. Going to try and find a gasket and replace without doing oil change...
  8. sonoran
    sonoran bigly Supporter
    Sep 28, 2009
    49,746
    33°05'38.7"N 111°40'57.2"W
    No need to drain oil. I replaced my o-ring and it still leaked. A little hi-temp RTV sealed it up nicely.
    #8
    bananu7 likes this.
  9. gozirra
    gozirra Spam?
    Oct 6, 2011
    167
    tx
    I had the leak, and stripped bolt(s).
    Center stand, remove sensor, plug the sensor hole with shop towels, Heli-coiled, new o-ring, motoseal, win.
    no new leaking.:clap
    #9
  10. Black Hills
    Black Hills Long timer
    Apr 7, 2011
    1,871
    Western South Dakota
    had the same issue on my 990. replaced the O-ring and it was fine.
    #10
  11. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,153
    Indiana
    I replaced the oring and it still leaked. Turns out the epoxy seal and had cracked on the back of the sensor. A little JB Weld and I've been good to go ever since. The epoxy was visibly cracked.
    #11
  12. wsmc99
    wsmc99 Been here awhile
    Jan 9, 2004
    564
    SD, CA.
    Yep same on my SMT.
    Order 2 so you have a spare.
    Quick fix, no draining of oil needed.
    #12
  13. Chuckracer
    Chuckracer Jerkus Maximus
    Aug 26, 2007
    10,331
    Dexter, NY
    It's a dry sump motor.
    #13
  14. Questor
    Questor More Undestructable
    Oct 8, 2005
    4,775
    Thousand Oaks, CA.
    I had a leaking O-ring.
    Tried to "just tighten it a bit" and stripped the threads. :becca
    Put in two helicoils and a new factory O-ring and it's better than new.
    I still love these 950's..
    Q~
    #14
  15. snarley
    snarley Long timer
    May 24, 2008
    1,037
    can anyone chime in here as to how to do the replacement, whats involved ?
    gotta do it soon
    tks
    #15
  16. tomdubz
    tomdubz getting there Supporter
    Jun 29, 2010
    1,270
    4 Cornerstan
    Real simple. Takes more time to remove/replace side-stand and clutch pedal. You'll want locktite on hand for reinstall of those.
    Otherwise:
    -Get to the sensor
    -Remove the sensor
    -Remove/Replace the o-ring
    -Replace the sensor (don't over-torque the small bolts)
    #16
    snarley, Jeff Sichoe and mroddis like this.
  17. RoundOz
    RoundOz Plenty of seasoning
    Jun 10, 2009
    2,154
    West Nebraska
    My first fix involved a new o-ring plus some oil-proof gasket compound. This lasted maybe 10,000 miles. My second fix necessitated replacing the sensor itself. It appeared to be leaking oil through the wires. Oil was coming out of the plastic sleeve after I cleaned everything up with solvent. I have seen oil migrate through wires many times in the past.
    It was not expensive and made me feel better about a permanent fix.
    This time I used Permatex Permashield (orange tube, not usually sold at auto parts stores so I had to order it in at NAPA) which I bought to try out on my fuel pump in my Safari tank. My last pump install used a different Permatex gasket maker which had mostly dissolved after 10,000 miles.
    In a perfect world you shouldn’t need a sealant for either of these tasks, but my world is far from perfect.
    #17
    nk14zp likes this.
  18. Creekside
    Creekside Been here awhile
    Jun 12, 2013
    435
    Yep it’s easy. Have to do one every 20000 miles it seems
    Sent from my iPad using Tapatalk
    #18
  19. hennessyktm
    hennessyktm Still here...
    Apr 9, 2009
    224
    Bydgoszcz, Poland
    Get it fixed? How'd it go?
    Perfect timing with this thread. Mine just started leaking a few days ago. New o-rings ordered.
    #19
  20. bananu7
    bananu7 Been here awhile
    May 14, 2018
    138
    Gdynia, Poland
    If you want to buy a new O-ring before disassembly, it's 27.5mm x 2.5mm NBR, part number 0770275025.
    The "NBR" material is apparently only good to 100 degrees Celsius. Maybe using something more durable would help for a longer-term fix? Gonna do mine over the weekend.
    #20
