Oil sight glass replacement
Discussion in 'GS Boxers' started by Steptoe, Feb 28, 2008.
  1. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,408
    london, England
    For 1100/1150 models
    I read so much bollox on how to do this simple task.
    The pictures were taken with the oil drained during a service. But you don't need to drain the oil to replace the sight glass, just lean the bike over to the right and lean it against something, or have some support it.
    And another thing, the window isn't glass, it's plastic.
    So here it is in pictures, and it'll take you longer to read this than to do the job.
    Tools needed - old screw driver, hammer, seal puller or other hooked implement, 30mm socket and extention.
    You want a 30mm socket because it's the same diameter as the sight glass.
    New sight glass, front view.
    Rear view.
    Hit screwdriver into plastic face, not to hard, you just want to break it.
    Hook the seal puller, or other hooked implement into the edge of the sight glass .
    And lever out.
    What you have when the sight glass is removed.
    Carefully insert the new unit with your fingers just so it stays in place, then use the 30mm socket as a drift, tap the socket extention with the hammer to fully locate the new glass
    Job done in two minutes if your slow.
  2. John Harden
    John Harden Commuting Adventurer
    Jul 6, 2007
    1,032
    Southern California
    Excellent write up and pics. I'd vote to post this in a "How-To" section.
    Regards,
    John
  3. Bollocks
    Bollocks Farts with an Accentâ„¢
    Oct 14, 2005
    7,103
    Watauga lake, 10-E-C
    9.3 Seconds.:thumb
  4. Jahwan
    Jahwan :)
    Mar 20, 2006
    65
    This was informative, thanks!:clap
  5. supaparty
    supaparty Been here awhile
    Feb 19, 2007
    117
    Agoura Hills, CA
    Do the 1200's utilize a retaining ring? Do they have to be replaced as often due to leaking and/or falling out?
  6. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,346
    SE Mass
    Yes, they use a retaining ring. Even so, I carry a spare around.
    The part number for the oil sightglass itself is the same for the 1100 and 1200, though.
    Can't address replacement frequency. 38k miles on my 1200 and no sightglass issues.
  7. JimVonBaden
    Feb 11, 2005
    91,361
    Alexandria, VA
    Good point. It seems to be less of an issue with the 1200 so far. But it is probably a function of age, miles, and no retaining clip that has the 1100/1150 ones fail at a higher rate.
    Jim :brow
  8. dwf
    dwf 2007 R1200GS Adventure
    Oct 11, 2004
    741
    TEXAS!
    When breaking the plastic do you not run the risk of a piece droping into the engine?
    #8
  9. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,408
    london, England
    Look at picture three. Plus, as i said, your only breaking a section to enable you to get something hooked inside. How simple can it be. :cry
    #9
  10. marty hill
    marty hill The Energizer Bunny
    Nov 25, 2003
    4,606
    Earth
    How 'bout putting a screw into the plastic and then pulling it out. Very easy and has been done by several people.
    #10
  11. bluegroove
    bluegroove Motorcycle junkie
    Feb 24, 2008
    620
    Sacramento, CA
    sometimes the dirt guys cover the sight glass with a thin layer of clear silicone so rocks will bounce off. smooth it out with an icecube and you can still see thru it pretty well.
    #11
  12. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,408
    london, England
    First post , second line down :D :D
    #12
  13. Grok
    Grok Long timer
    Jan 17, 2003
    5,092
    California
    I got this idea from using a "Ding King" dent removal kit.
    Materials required:
    Hot glue gun
    bolt or screw with large head
    alcohol
    Engine cold:
    1. Clean sight glass and bolt head throughly with alcohol.
    2. Put a big blob of hot glue on the bolt head, apply to center of sight glass.
    Hold in place until set, let cool a few minutes.
    3. Pull out sight glass.
    4. Peel or pry hot glue from sight glass.
    #13
  14. STILLdKING
    STILLdKING Old Retired Guy...
    Oct 14, 2007
    1
    Where forty below keeps out the Riff-Raff, NoDak.
    Try heating a small nail, stabbing the plastic to make a melted hole, then run a small screw into the opening. This avoids anything falling into the engine (fragments from breaking plastic and/or shavings from drilling the hole). Use the screw to remove the defective sight-glass. Install new parts.
    Refill and enjoy the ride.
    JC
    #14
  15. dfwscotty
    dfwscotty Long timer
    Apr 9, 2006
    4,059
    Denton, TX
    You beat me to it! Was going to do a tech post on the change out on the sight glass on my 1100 pretty soon.
    Nice write up!
    #15
  16. Kongo
    Kongo Dog's best friend
    Apr 24, 2006
    537
    Longmont Colorado
    I just drilled a small hole, then put a wood-screw into the center. I pulled it out with pliers. No need to break the plastic into pieces. Easy.
    Carefully clean the rim around the hole it goes into before putting the new one in. Your are right about using a big socket to put the new one back in. And, using the socket extension like you did helps hold it straight and gives you a place to tap that spreads the force evenly around.
    #16
  17. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,408
    london, England
    You don't need to break the plastic into pieces. All you need is plastic cracked to enable a seal puller to lever against. Just how easy is that to do. And you can do it at the side of the road if it decides to leak while on tour.
    #17
  18. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,408
    london, England
    You don't need to break the plastic into pieces. All you need is the plastic cracked to enable a seal puller to lever against. Just how easy is that to do. And you can do it at the side of the road if it decides to leak while on tour.
    #18
  19. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,408
    london, England
    Very simple - And easily done at the side of the road while on a tour :clap :D
    #19
  20. JimVonBaden
    Feb 11, 2005
    91,361
    Alexandria, VA
    Do it anyhow. There are never enough How Too's on here, seriously!:deal
    Jim :brow
    #20
