Oil sight glass replacement
Discussion in 'GS Boxers' started by Steptoe, Feb 28, 2008.
  1. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,420
    london, England
    So are you saying that removing your gloves, undoing fillercap/dipstick, wiping it clean ( after finding something to wipe it with), re-inserting filler/dipstick, removing filler/dipstick, checking oil level, repeating it again just to double check, refitting oil/filler cap, disposing of the dipstick wipe - is easier than bending down and looking at the site glass ??? :D
    Plus if you have to top it up with oil, you can do the dipstick removel shuffle a couple more times to make sure you've topped it up enough with oil.
    #41
  2. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    The problem is: We don't like bending forward like that. It's not elegant.
    [TaSK]
    #42
  3. jigdog
    jigdog Been here awhile
    Mar 1, 2006
    813
    NJ
    Someday when science makes it possible for us to change bodies you can have mine for a test drive. :D
    #43
  4. dfwscotty
    dfwscotty Long timer
    Apr 9, 2006
    4,059
    Denton, TX
    Changed the sight glass on my '99 1100 GS(30,000 miles) when I changed my oil today. Went pretty straight forward, the sight glass was more brittle than I expected when I ran the screw through it. I used a hooked shape pick to pull the shards out until I had enough room to pull on the seal. It seemed to be fairly secure but appeared to be some oil around it every 1000 miles or so. Not really wet, just a dirty film. The new one went in fairly straight forward using the socket method with no leaks.
    With easy jobs come the hassles though, when removing the bash guard, one mount twisted in half at the rubber. The remaining piece came out fairly easy but that wasn't good enough. I had one in good shape that stayed with bike and when I tried to take it out, I tore it in half too. It is still in there. Messed with it for a couple of minutes but couldn't get a good grip at the time and got tired of counting how many times my hand hit the hot cat......oh well, I ride mostly pavement on it anyway.
    #44
  5. Partagas
    Partagas EarthFirst
    Apr 13, 2007
    327
    Dofflemeyer Point
    What I love about the sight glass is that at any given time you can get a different reading out of it. Park bike on side stand for one minute and put on center stand and oil level is half way up sight glass; park bike for 20 seconds on side stand and then on center stand and oil fills sight glass completely; park bike on center stand and never tip to side stand and no oil in sight glass.... I love the consistency!! Dip Sticks Rule!!!
    PS thanks for quick change tutorial on the sight glass.
    #45
  6. P B G
    P B G Long timer
    Mar 7, 2008
    10,001
    Greater Chicago
    Some sight glasses are better than others, but some with age can be really hard to see, and at night in a parking lot I cannot use a sight glass, I can still check the dipstick.
    Both seems like a logical solution...
    #46
    slime likes this.
  7. mike54
    mike54 You don't get me
    Mar 13, 2004
    15,212
    Before it falls out of course. As part of your routine maintanence you should check the stiffness of the rubber around the sight glass with your thumbnail. If it's not soft it's a good idea to replace the sight glass. Even so it's good preventative maintenance to replace the sight glass every 4 years or 40,000 miles. So I've been told.
    #47
  8. Whiskey Tango
    Whiskey Tango 1*
    Mar 16, 2008
    1,212
    Sight glasses have been used for a long time in/on construction equipment and marine machinery, along with sight tubes.
    One would think that with modern metallurgy and machining/manufacturing techniques, oil levels should remain consistant between service intervals in all but the the most severe operating conditions - absent a leak, of course.
    #48
    slime likes this.
  9. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,291
    The woods and mountains of Alabama
    Sure, a sensor could be added but it would cost too much. I simply add oil to my gas to insure that I always have engine lubrication...I use synthetic. Some added moly helps, as well.
    #49
  10. Trailing Jack
    Trailing Jack Dr. Acula
    Jun 1, 2004
    1,301
    Clearfield PA
    When I was about to replace mine I read a post by Paul Glaves (BMW wrench guru in the MOA) in the MOA website forum who advised against using any goop on the new one.
    He just recommended that the rim be cleaned first.
    BTW - it is as easy as everyone says. :thumb
    #50
  11. bg
    bg Monster
    Jul 21, 2004
    8,323
    Mayberry, WI
    Just changed out my sight glass easy as pie. Thanks for your help Steptoe.
    #51
  12. S2W
    S2W I said wax ON you idiot!
    Oct 2, 2005
    3,351
    Sydney, Australia
    Bump
    #52
  13. Peka
    Peka Long timer
    Nov 12, 2004
    2,013
    Brisbane, Australia
    I did mine on the weekend while doing the 140,000km service. Too easy. Tapped it lightly with a screwdriver, the plastic cracked. Grabbed one of the plastic bits with a set of pliers and it pulled straight out. I wouldn't worry too much about anything dropping into the engine. You only need to tap it lightly and it will crack, and the plastic is held where it's attached (glued?) to the rubber seal. I only replaced it because it was getting a film of oil around it, though not sure if it's the sight glass or oil pressure sensor. Will know soon enough, if the film comes back.
    P.S. An old bar end works well as a drift :lol3
    #53
  14. def
    Feb 28, 2004
    14,291
    After extensive collaboration and counsel with Al Gore, the EPA nixed the fuel/oil transfer system due to the possibility of oil contaminating the fuel and the engine behaving like the old 2-stroke engines now no longer allowed on the highways and byways of the USA....pity!
    #54
  15. JimVonBaden
    Feb 11, 2005
    91,764
    Alexandria, VA
    You actually read that monoparagraph?:huh
    :lol3
    Jim :brow
    #55
  16. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,223
    NJ exit 10
    Anyone heard of sight glasses on any other make bike popping/cracking/leaking/needing replacement?
    #56
  17. R.Markus
    R.Markus Damage Addict
    Feb 22, 2004
    1,289
    Northwest, IN
    I just replaced the one on my KTM LC4. It cracked, which made it loose and pushed in a bit. It wasn't the oil sight glass, it was the timing glass.
    #57
  18. tagesk
    tagesk Tuscan rider
    Jun 23, 2007
    3,230
    Tuscany, Italy
    What is the difference, if any, between the discontinued part 11117661648 and the new 11117703823 ?
    [TaSK]
    #58
  19. DaneelOlivaw
    DaneelOlivaw Irv Seaver BMW; Parts Mgr
    Jul 7, 2008
    439
    Orange, CA; USA
    The new part comes with a perimeter circlip in the package. Clip is used on a narrow range of R- & K-models, I believe. Clip will be otherwise useless and discarded. I've amassed a pile of them from my own technicians already. They make good in-shop missiles.
    Otherwise, no difference.
    #59
  20. yellow
    yellow Been here awhile
    Sep 13, 2005
    324
    Milwaukee, WI
    Riding into work, about 1 mile to go, turn and look, there is a huge plume of smoke behind me, what the hell, get off I94, and assess my situation......
    boot is covered in oil, bike smokin' like she had a 5 pack a day habit, and 4 blocks to work.....give it a little gas, turn the corner, shut her off and coast into work.
    MY SIGHT GLASS WAS GONE!!!!!! How the hell did that happen, anyway. Had an extra pushed her in at work, filled with oil and was good to go -
    Thank you ADVrider! and this Thread.
    #60
