Oil sight glass replacement
Discussion in 'GS Boxers' started by Steptoe, Feb 28, 2008.
  1. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,290
    The woods and mountains of Alabama
    Someone needs to engineer and build a remote sight glass CCTV system so we don't have to bend over.
    SmittyBlackstone likes this.
  2. MotorradMike
    MotorradMike MIL-TFD-41
    Aug 17, 2008
    1,150
    Mallorytown Ontario
    You can glue a small mirror to your left boot so you don't have to bend over.
    Not that there's anything wrong with that. :D
    slime and SmittyBlackstone like this.
  3. def
    Feb 28, 2004
    14,290
    We're you taught on cars or motorbikes back then?
    Most of my motorcycle learning was done on Meriden Triumphs, Greeves, Nortons, BSAs, the occasional Honda, Royal Enfields and a BMW R50.
    Did you ever meet or were you ever in the company of Hailwood, Minter, Agostini, McIntyre or any of the other IOM riders?
    I hope to attend IOM one day...I'm looking forward to the ferry ride from the UK to Douglas (hope they still have hydrofoils)....see you there.
  4. vagueout
    vagueout Long timer
    Mar 3, 2010
    4,483
    sydney, east
    This would be in good company with the Tyre Pressure Monitor system on the 1200's.:lol3
  5. DrWez
    DrWez Mad Scientist
    Jan 3, 2009
    144
    Cedar Grove, WI
    It's a retaining ring not a clip that circlip pliers will work on.
  6. Terry
    Terry Long timer Supporter
    Jun 19, 2002
    1,372
    Colorado Springs, Colorado
    I already have one! I just never thought of using it for that!
  7. JimVonBaden
    Feb 11, 2005
    91,404
    Alexandria, VA
    True, just use a small flat-blade screwdriver.:deal
  8. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,714
    Charlottesville, VA
    Yeah but then people will think you're some upskirt peeper weirdo.
  9. GSBruce
    GSBruce Been here awhile
    May 3, 2011
    341
    The Woodlands, Texas
    Do sight glasses need replaced if they are clear and there is no seepage at all?
    For instance, on an original-owner 2000 R1150Gs with 27,000 miles?
    slime likes this.
  10. JimVonBaden
    Feb 11, 2005
    91,404
    Alexandria, VA
    No, leave them be unless they are leaking.:deal
  11. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,346
    SE Mass
    Oh, hell, you're right! :baldy What was I thinking? I even took this shot of the sight glass on my 2005 some time back to show the snap ring. :lol3
    Like Jim said, a small screwdriver would work. I also like the little bent hooks that come in sets for this sort of thing.
  12. bwalsh
    bwalsh Long timer
    Jan 15, 2009
    27,089
    Helltown
    My 01 has 37,000 miles and was yellowed and difficult to see through so I decided to swap it out "in 90 seconds" like I've read...while changing the oil this evening. Over an hour later I said screw this and came in and made a strong drink. Just like others posted it is in there good!
    I broke the plastic and fished out the pieces, tried prying on the ends at 3 and 9 position, took a center punch to make a small hole in the center of the metal and screwed in a 3" lag bolt. It looked like it was going to come out until I realized what was moving was the metal. I got that out and stopped for the night where the outer ring is still in the block. I was thinking of buying a seal puller in the morning but I figure it would just bend and be useless. I started using a large cold chisel but need to find my small one. I think that may do the trick. If not I'll try the dremel.
    I'll deal with it tomorrow...
    slime likes this.
  13. diabolik37
    diabolik37 Deadly Gubba
    Jan 15, 2008
    2,937
    Down Under QLD
    I fix it for you
    Don't worry.. You still have plenty of time...
  14. bwalsh
    bwalsh Long timer
    Jan 15, 2009
    27,089
    Helltown
    :lol3
    I found my small chisel and got the last piece out. All fixed up now! :1drink
  15. diabolik37
    Jan 15, 2008
    2,937
    Down Under QLD
    See... with plenty of time to spare....
    I found that some do come out pretty easily, some other won't. But it seem that the easier one to replace are the one that have already started to leak...
  16. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,409
    london, England
    You read it took 90 seconds, using a seal puller.
    You've given me an idea for another oil glass removal/replacement thread.... "How to change it in 4+ hours using pointy bits of metal and hammers and then moan about how long it took".. :D
  17. Bobber
    Bobber n00b
    Feb 14, 2008
    1
    Unfortunately after trying all the tricks here, I gave up and trailered it to a dealer, which was almost 3 hours from here. The dealer did not have the special tools and it took 2 of them a good bit of time to get it out. All the hammering, etc. they did made me nervous, but they were able to finally get it all out. They replaced it with the one I had purchased earlier and brought with me. The new one had a glass sight glass instead of the plastic. Beware, they are not all as easy as described in this thread. This was on a 1200 RT.
    They charged me $95 for the labor, which was worth it, wish I would have gone to them first.
  18. JimVonBaden
    Feb 11, 2005
    91,404
    Alexandria, VA
    $7 from HF and no sight glass will win.
  19. bush pilot
    bush pilot Long timer
    Jun 23, 2006
    2,526
    Thailand
    I just carry a spare in my kit with a spare clutch cable and fogetaboutit.
    If it seeps a little never mind, just worry about if it pops out.
    I also usually carry a spare Hall sensor, as that will stand you certainly.
  20. ausfahrt
    ausfahrt mach schnell Supporter
    Apr 17, 2008
    3,326
    Vermont
    I am in the middle of an oil change and had planned on changing out my sight glass. It looks like it is weeping oil, not enough to drip on the ground, but enough to make a mess on my engine.
    I remembered this thread and looked it up but now it appears that Steptoe's pics are no longer available. I've heard and read the horror stories about these sight glasses and I have my replacement in the freezer right now but I am having second thoughts.
    Maybe I should just leave it alone and ride.
