Oil Usage
Discussion in 'Dakar champion (950/990)' started by kalexu, May 30, 2019.
  1. kalexu
    kalexu Adventurer
    Jul 22, 2018
    24
    Romania
    Hi Guys,
    I'm wondering how much oil does your bikes use between oil changes ? I don't know if im checking the oil correctly or mine is actually using/loosing alot of oil. But i think i might go to up to 300ml of oil / 1000km or so somtimes even more. I use 100% Synthetic 20w50 Motul 7100 Maybe it's the oil fault. Any thoughts ? ( bikes @ 75.000 km )
  2. NKL
    NKL Been here awhile
    Oct 25, 2011
    391
    Kent, England
    Mine at 70,000 miles hardly uses any, always check the level the same way. i.e warm, just after at least a 20 minute run, all the oil will then be scavenged from the sump and in the tank.
    If you don't do the same thing each time the difference on the dipstick can be massive.
    1coolbanana likes this.
  3. Pedec
    Pedec Been here awhile
    Jul 28, 2018
    169
    Canada
    Ya need to ride bike for good ride before checking. Just starting and warming up bike is not enough to get accurate reading.
    Boatman and 1coolbanana like this.
  4. Wastedavid
    Wastedavid Been here awhile
    Oct 27, 2013
    194
    Colombia, Cofee paradise
    Hummm, actually I do like they say in the manual (power up, let run for some time until it reaches the 6th line, power off, check, on the central stand). I've been adding almost one quarter or something around from change to change, but it's been like that since I got it from new, all this time I've been checking the level the same way, sooo... don't know, I guess it's normal.
