Old Kendon vs. New Kendon (cargo capacity of a swallow?)
Discussion in 'The Garage' started by Catatafish, Mar 12, 2018.
  1. Catatafish
    Catatafish Adventurer
    Oct 30, 2017
    45
    Memphis, TN
    I've been used Kendon shopping for quite awhile now and finally found one I like nearby. It's a 2005, 3 rail sport/dirt bike version. Seller tells me it will only take 1000 lbs. The newer ones take 1500 lbs according to Kendon website.
    I've emailed Kendon to ask but no responses yet and I'd like to get this deal done soon if I know there is a way to get that upper 1500 limit via replacement wheels/tires/axle, etc.
    Anyone know what they did to kick up that weight rating?
    TIA!
  2. ydarg
    ydarg Miscreant
    Nov 11, 2015
    1,394
    Above the Equator
    I have a 2001 single bike stand up that has a 1,000 pound rating. Dexter torsion axle, 13" wheels, etc.
    That doesn't seem right for a three bike.
  3. darkstarmoto
    darkstarmoto Am I evil? Yes I am
    May 24, 2009
    725
    SEPA
  4. Catatafish
    Oct 30, 2017
    45
    Memphis, TN
    Thanks guys. Darkstar that's a great link, thanks! What I'm still wondering is which replaceable part will bump that '05 to 1500 pounds? I'm hoping it's a simple as swapping out the spindle/bearing/hub. I'll hear from Kendon eventually but thought someone might know off the top of their head.
  5. Hipster
    Hipster Long timer
    Aug 31, 2004
    2,376
    Mpls, Mn.
    My 2004 single is also rated for 1,000 lbs, which I've upgraded the tires to radial. I wounder if the limiting factor on older trailers is the bias ply tires vs newer trailers with radial tires?
  6. Catatafish
    Oct 30, 2017
    45
    Memphis, TN
    It's funny, the older singles were 1000 and the brand new single is still 1000. It's the triple sport/dirtbike model that gained 500 pounds somewhere along the line.
  7. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,099
    South Jersey... Close to the Pines
    The torsion axle with be the most expensive part to change to upgrade the weight rating.
  8. Aprilia
    Aprilia Long timer
    Sep 15, 2008
    1,647
    Phoenix, AZ
    I have a 2005 2 rail built in June. Vin sticker shows its Gross is 2000lbs. Weight rating is based on the torsion (rubber) within the axle tube. Would be very expensive to upgrade.
    #8
  9. Catatafish
    Oct 30, 2017
    45
    Memphis, TN
    eTrailer shows them in the $500 for a similar axle and then about $100 for a pair of spindles/bearings. I'm hoping Kendon tells me it's just the spindle but more than likely it's probably both. I'll probably just call them today....they are great at making trailers but emailing is not their thing apparently.
    #9
  10. ydarg
    ydarg Miscreant
    Nov 11, 2015
    1,394
    Above the Equator
    Go to Dexter for info. It either has a #8 or #9 torflex axle.
    #10
    Catatafish likes this.
  11. Catatafish
    Oct 30, 2017
    45
    Memphis, TN
    Great lead ydarg, much appreciated!
    #11
    ydarg likes this.
  12. SnoDrtRider
    Mar 21, 2006
    6,099
    #12
