On the side of the road...
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by whiskey_six, Jul 5, 2019.
  1. whiskey_six
    whiskey_six Adventurer
    Sep 27, 2009
    18
    Central Oregon
    Hey fellas. On the side of the road with my 2017 KTM 1290 SAR. Drinking a beer waiting for the trailer to arrive. Just North of Kalispelle. The bike started hesitating and then turned in to a big under load. It will idle but if it requires more fuel flow or power it bogs. I’m thinking either the fuel filter, fuel pump(still turns on and revs but will bog if I hold the revs high), or injectors have some crud in them. It did start to do this after I filled up with premium at a small conoco, went about 15 miles and the hesitation got worse and worse and now not driveable(rideable). Bad gas maybe? I drained about a gallon into the gravel with no improvement. The bike has 8000 miles. Smog delete is the only addition I’ve done to the air/fuel happenings. Any thoughts would be appreciated.
  2. Marki_GSA
    Marki_GSA Long timer
    Sep 6, 2011
    2,192
    Scotland
    Fuel filter most likely.
  3. Oldschoolrocker
    Oldschoolrocker a.k.a. EZE Supporter
    Sep 14, 2017
    2,022
    Tacoma Wa
    Sounds like it very well could be filters to me/and or fuel pump. Only way to eliminate future problems is to go Guglatech filters IMHO. Wish you the best! Might post up in Rockies thread too if you need a good shop to go to. Lotsa KTM boys over there.
  4. whiskey_six
    Sep 27, 2009
    18
    Central Oregon
    Right on thanks. I’ll get a gas container and drain the fuel to check out the filter. Guess I’m gonna miss the Road to the sun ride....unless I fix it. Guglatrch filters. Check.
  5. Night Crawler
    Night Crawler Been here awhile
    Mar 14, 2012
    259
    Portland, OR
    Its definitely the filters. Call the nearest dealer and see if they have them. Throw the Guglatech in this winter after riding season is over.
  6. Bartimus
    Bartimus Been here awhile
    Oct 12, 2008
    469
    The land of Entrapment
    Where are the filters located? Are they easy to get to?
  7. Oldschoolrocker
    Sep 14, 2017
    2,022
    Tacoma Wa
    You”ve got to pull the fuel pump out of the left bottom front of gas tank. Better have o rings and filters to swap if you do or Gulatech stuff.
  8. Oldschoolrocker
    Sep 14, 2017
    2,022
    Tacoma Wa
    Good luck!! Hope you make that Road to the sun!! Should be bad ass!
    #8
  9. Capo Rick
    Capo Rick Please understand...
    Dec 30, 2005
    2,804
    Groovy Grove, Oregon
    Coincidentally, my fuel filter issue from 2016 happened on the south end of Flathead Lake. Must be the Montana air :pope
    #9
  10. hoss1
    hoss1 Been here awhile Supporter
    Oct 25, 2015
    581
    Ventura, CA
    Obviously not many folks burn high test in Montana. The gas is old and the tanks probably full of crud. Use regular next time.
    #10
  11. Oldschoolrocker
    Sep 14, 2017
    2,022
    Tacoma Wa
    Guess I have been lucky going through there. Plus with the freeway speeds of 90-95 it could raise more issues running regular! Haha!!
    #11
    Wynnded likes this.
  12. Wynnded
    Wynnded Wait....what?
    Nov 11, 2017
    303
    Rockies
    At least it's easier to find E0 there, which I like.
    #12
  13. whiskey_six
    Sep 27, 2009
    18
    Central Oregon
    Headed back to civilization now. Took it apart to the injectors in the camp site, fuel pump works and the filter is spotless. I’m betting on bad gas. That’s a good idea to run regular out in the sticks. Fuel dongles might be a good add on.
    #13
    Oldschoolrocker likes this.
  14. ls6777
    ls6777 Been here awhile Supporter
    Mar 25, 2015
    518
    Vista, CA
    I don't think the 2017+ SAR/SAS has a bad fuel dongle option.
    #14
    TheBritAbroad and kokos79 like this.
  15. whiskey_six
    Sep 27, 2009
    18
    Central Oregon
    Well fellas. Bad gas was it. Frustrating to say the least. Guess I’ll have to plan another ride to Glacier to get that ride off my bucket list. Cheers!
    #15
    TomSummerfield and thirsty 1 like this.
  16. TomSummerfield
    TomSummerfield Orange Blooded
    May 18, 2015
    170
    Seattle,WA/Wenatchee,WA/Naples, FL
    Sorry to hear mate! Going to the Sun was the highlight of our Montana adventures especially on the big KTM.
    #16
  17. RCR001
    RCR001 MOTO CHASER Supporter
    Jul 16, 2007
    327
    Planet Cripton
    My Fuel issue happened on the Blue Ridge in NC about a month ago, limped it back to the house we were staying at, I always carry the Guglatech filters with me on trips, changed it out with the help from the U-tube video as a reference and rode back to Canada 3 days later..Time to order another kit.
    #17
    whiskey_six likes this.
  18. whiskey_six
    Sep 27, 2009
    18
    Central Oregon
    Do you guys run the filler neck filter and the sock around the pump?
    #18
    Themastermike likes this.
  19. KTM 1190advR
    KTM 1190advR Enema of the state Supporter
    Aug 2, 2015
    2,880
    Somewhere in Norway
    I do, it isn’t a sock though. It’s a pre-filter much like OEM but conciderably larger filter area and of a better suited material. There is also an in-line external filter in the complete kit so you’ll have to ditch the round fibre filter inside the pump assembly.
    #19
    Oldschoolrocker and Capo Rick like this.
  20. Wynnded
    Nov 11, 2017
    303
    Rockies
    This is what I do as well.
    #20
