Ossa tr280
Discussion in 'Trials' started by bohica53, Sep 26, 2020.
  1. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    16,182
    Dubuque, Iowa
    It might be more fun just to throw the money out the car window and watch people scramble for it.
    #21
  2. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    538
    Michigan
    Any cherry trials bike under the hand of a smart person who takes care of things and isn't crashing and bashing repeatedly can ride a bike no longer made without issues, for a decade and never need a critical custom-to-that-manufacturer part. if a trials bike breathes clean air, I consider the top end to be permanent and maintenance free. That bike will need parts common to all trials bikes, but that's no issue. And there is a parts base out there. No big, but I'd bet one could - eventually - get any part needed.
    As always Bene , well said .
    On the other hand ...
    Maybe all they're worth is scrap .
    Hmmm ...
    If I could get one for nothing ....
    I've got a TY 175 ....
    Wonder if that would fit ? ( without hitting the front fender ? ) :hmmmmm
    Wait a minute .... !
    A TY 80 !!!
    DUDE !!!
    A YamaOssa !
    :bmwrider
    #22
    motobene and Norman Foley like this.
  3. bohica53
    bohica53 Adventurer
    Jan 2, 2017
    50
    Well I talked to Mike Komer and we agreed that even at an excellent price the Ossa was to much of a question mark. So..... I am now in a search for a Montesa 315r! If anyone wants to unload one.....let me know. Thks to all!
    #23
    DyrWolf and Norman Foley like this.
  4. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    4,631
    New York... The Finger Lakes
    The Ossa outcome of that I expected....
    #24
  5. sprinter27
    sprinter27 Adventurer
    Oct 14, 2009
    70
    While aftermarket can source lots for a 315 , it’s been out of production and is a bastard Honda that will still give you fits for finding many of the spares . At least the one I owned did .
    #25
  6. Lotus54
    Lotus54 Ngana
    Nov 22, 2007
    314
    Port Angeles, WA USA
    I would certainly buy a newer OSSA. Newer the better. The starting is super easy to fix, engine is great and gearbox decent. So far, I have not had too much in the way of parts issues- although some things can be hard to find.
    I don’t particularly like the linkage bearing setup (they use teflon coated bushings) and linkage could be more robust.
    Injection is quite easy to work on- software is free and I’ve made a few of the interface.
    I know a 2013 for sale that has about 15 minutes running time. Dealer has it for sale.
    #26
    motobene and Wingboy like this.
  7. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,487
    ABQ NM & Wichita Mountains OK
    FWIW some suspension bearings thoughts.
    Coated bushings can be viewed as inferior to needle bearings. I did too, but after living with them on the Shercos I prefer them because they are so easy to maintain. Sherco uses Teflon-coated bushings for the dog bones in their trials bikes. I found them super reliable and quiet when greased every season or two. But some riders do no maintenance on bikes many years ridden. They'll complain of creaking noises when the bike is sat on or ridden (a few drops of oil into the bushing will diagnose this). Those abused bushings survive fairly well, but eventually the low-friction surface coating will get wiped off.
    Journal bearings have a higher load capacity than needle bearings because of the much larger surface area of contact. Needle bearings have the advantage of rolling instead of sliding between the bearing surfaces, but the tradeoff is higher contact stresses. Lower bearing contact area is why you'll find needles laying side-by-side in suspension linkages. I've seen caged needle bearing in cheapo Chinese suspension bearing kits. Avoid those! They won't last. Uncaged needles can be a pain when doing maintenance if you have to clean them instead of just reapplying grease. In that case it pays to lay needles carefully into grease in the outer races after cleaning everything, and stick your tongue out just so :yum while lining all the needles up and hoping you haven't lost any:bluduh.
    #27
    Norman Foley likes this.
  8. Lotus54
    Lotus54 Ngana
    Nov 22, 2007
    314
    Yes, they do hold up pretty well- except when riding in lots of mud. There are no seals at all- so the mud gets in there and rapidly wears the teflon. At least that has been my experience. The good thing? Those bushings are super cheap, very small and light.
    I also broke parts of the linkage twice, so I went to a titanium setup, with grease fittings. I would push silicone grease with teflon after most rides, which (appeared to) push out any dirt/mud/water pretty well. Plus it was really quick to do.
    The bikes I’ve had with sealed needle bearings seem to hold up a lot better, although I agree if they seals fail, they are much more work to clean.
    #28
  9. motobene
    Mar 9, 2013
    7,487
    Lotus54 you must slam into stuff pretty hard and often:pynd
    I've roasted some Gas-Gas dog bones, but often they were already somewhat abused before I got them. On the Sherco dogbones I have fit some o-rings to have a seal - any seal - but I ended up leaving them off and just re greasing them every season if I'm riding a lot. The full grease-packing acts like seals for long enough, but I must admit to living in a dryer part of the country and generally avoid slop-mud riding. Your locale, Port Angeles, WA isn't exactly dry country!
    Grease zirks are really nice for easy maintenance. I wish I could fit them everywhere but on the smallish trials bikes that's technically difficult as well as creates stress risers. Were your titanium bits the dogbones? That would certainly help.
    #29
  10. Vintage pro
    Vintage pro Been here awhile
    Sep 26, 2013
    295
    Stallion Springs , Ca
    I built and modified the Ohlins on these bikes, took the standard Ohlins and would make another longer shaft to increase the travel.
    #30
    Lotus54 likes this.
