1. eNewsletter Sign Up
Owners Chat (with pics!): Honda NC700X
Discussion in 'Road Warriors' started by swiss-happy, Aug 9, 2012.
  1. Fuzzy74
    Fuzzy74 Been here awhile
    Mar 6, 2009
    555
    Cumberland Plateau in Tennessee
    Any hardware store, auto parts store or even Wally World should have penetrating oil.
  2. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    Penetrating oil yes.....but, Kroil is great stuff.....per my brother. Use to only be available for / thru industrial uses ir suppliers years ago. Times have changed I suppose
  3. Eyebooger
    Eyebooger scrutinologist
    Jun 25, 2014
    1,521
    Land of the Bella Vistoners, NW Arkansas
    +1 for Kroil. I had a can given to me when I worked in industry 20 years ago. The propellant leaked out long before I used it all up, so I just poked a hole in the can top. Application was a little... messy.
    I think I finally replaced it with some bought from Amazon.
    frog13 likes this.
  4. TheHeretic
    TheHeretic Been here awhile
    Jun 7, 2005
    352
    RI
    I really have not noticed a performance difference from one brand of PO to another but it may be because the old rusty relics I drive are about 80% fallen back into the earth as iron ore...lol....
    frog13 likes this.
  5. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    C'mon spring........got a little snow here in SW Ohio. Obviously, no riding possible.....DoH.
  6. 10/10ths
    10/10ths Road Trip Fool Supporter
    Aug 26, 2007
    1,169
    Bayou country
    Ok, so after spending some time really looking at the seat issue, I discovered that the previous owner made a lot of modifications in order to RAISE the seat. He was 6’5”.
    My 5’8” self needed help.
    He had installed a bracket to raise the tongue on the front of the seat. He also put folding chair feet under the back of the seat to raise the rear up.
    After removing those mods, placing the Russel Day Long back on, and putting on a pair of Daytona M-Star GTX boots, I now have a perfect seating situation.
    I can sit on the RDL and get my feet down.
    Success!!
  7. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    Good show!.
    It's probably the photo angle , but it looks like the "winged" sides of the RDL would dig into ones upper bottom thigh......?. Perhaps not.
  8. 10/10ths
    Aug 26, 2007
    1,169
    Bayou country
    597AED63-44A2-479A-8247-B146B3F68B9F.jpeg They do not.
    RDL seats are shaped like a classic tractor seat.
    Super comfy.
    Cheers!
    zap2504 and frog13 like this.
  9. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    Ahhh, very good.....now I understand, thank you. May have to get a RDL.....someday.
  10. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    14° here in SW Ohio this morning.....brrrr,.
    Come on spring time !.
    Nttra likes this.
  11. dduelin
    dduelin Prone To Wander, Lord, I Feel It
    Oct 17, 2006
    2,828
    Shaft City
    The wings do not dig into one’s thighs but they do somewhat inhibit active body positioning when aggressively cornering. The trade off is generally worth it.
    frog13 likes this.
  12. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    Understood dduelin, thank you.
    From the photo angle it just looked like a thigh digger......always good to have actual perspective from product users. Just like bar risers. I've read if you stay at 2" or less no issues have been found / noticed with cables nor front brake line. I'll probably go with ROX risers, I'm quality paranoid on such things......lol..... : )
  13. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    I'll also look at SW Motech.
  14. beemerphile
    beemerphile Unreconstructed Southerner Supporter
    Jan 31, 2006
    3,740
    Danielsville, GA USA
    Kroil is good stuff, but you can make your own penetrating oil with 1/2 acetone and 1/2 ATF. Works as well as anything you can buy.
  15. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    Wow , never heard of that, I need to get out more !
  16. twistedthrottle
    twistedthrottle Long timer
    Apr 30, 2003
    1,025
    Rhode Island, USA
  17. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    No , bar risers. It'll either be SWM or ROX...... I think?...... : )
    Thank you for chiming in .
  18. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,380
    Middletown, PA
    I also have a couple cans of Kroil (and use it for almost everything including stuff WD40 is good for) but have heard of the ATF/acetone mix many times; most recently on the BBC "Repair Shop" episode where it was referred to as "the old farmer's trick" for loosening bolts.
    frog13 likes this.
  19. Eyebooger
    Jun 25, 2014
    1,521
    I thought the old farmers trick was the ‘flame wrench’ :lol3
    Seriously, I was attempting to remove an o2 sensor from a car the other day. Soaked over night in kroil, started off with pipe dead cold. No go. Started engine a few sec to warm pipe, still no go. Broke out the cheater, thought I had it, but no, the flats on the sensor were starting to round off. :bluduh
    Grabbed the handy dandy torch, heated that mf’r to a dull cherry red, and it popped loose with a stubby 7/8 line wrench. Yay!
    Of course, I don’t recommend doing that on something that needs to be reinstalled...
    zap2504, TonyKZ1 and frog13 like this.
  20. frog13
    frog13 Long timer
    Feb 10, 2007
    3,067
    SW Ohio
    Nothing like a little heat !
    Eyebooger likes this.
