Oz / Kiwi Honda Postie (CT110) Adv Riders Sign in Here please
Discussion in 'Australia' started by Joe Watson, Apr 17, 2009.
  1. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,024
    goodly satisfactory place, qld
    So quiet
    Grinding welding
    Phat
    shank and Czechsix like this.
  2. tncpowell
    tncpowell Long timer
    Feb 7, 2011
    1,018
    Christmas Island Western Australia
    Question for any of you wiring gurus out there. One of our posties (2009) has suffered a setback in the wiring department. It has no horn, no indicators, no headlight, no tail light, not brakelight, a dead battery and even when running none of these things work. Am I looking at a dead stator or broken wire or....? Ive swapped regulators between bikes, pulled the wiring apart up in the steering area, checked the plugs from the stator, checked the wires from the extended ignition wiring and checked inside the headlight bucket. There appears to be nothing broken and nothing loose. The battery terminals are tight and clean, the fuse is intact. We have done some very rocky roads lately and I noticed the tail light would become very dim then bright then dim then it went out as we bumped along. Has to be a connection or something right? What should I look for? Bike runs perfect still and is a CDI postie. Its really annoying me!
  3. WILL_S
    Feb 16, 2009
    3,024
    Todd
    First try a good battery
    If you still have no luck
    It will be a power supply problem
    If it runs and things work at first then go down hill it will be a stator /regulator problem.
    A cheap multimeter will help espically if its stator related.
    Be easier to diagnose if i was ,wish, was over there :-)
    Cheers Will
  4. Turborob
    Turborob .
    May 14, 2008
    707
    Capital region.
    Can anyone tell me the diameter of the shifter spline? I have a knock-off Postie and want to replace the shifter with a less protrusive one. Thanks.
  5. Flodder
    Flodder Flodder
    Jan 25, 2007
    823
    Culcairn, NSW, Australia
    My spare motors are out side diameter of spline are 11mm. I have a spare gear shift lever if you want to modify it..
    cheers Flodder
  6. WILL_S
    Feb 16, 2009
    3,024
    Hello......
    Has the postie craze died off and only the old school hardcore nutterz remain ?
    Anyway if i can get this piston back down the bore i will be riding from qld to the Tiddlers rally. Be good to see some off the other nutters there
    Te Hopo, sidetrack one and Clacka like this.
  7. Flodder
    Flodder Flodder
    Jan 25, 2007
    823
    that does look like it is a bit bigger than standard. True or False.
    Mouse likes this.
  8. WILL_S
    Feb 16, 2009
    3,024
    Um true
    You can go back ;-)
    Flodder likes this.
  9. WILL_S
    Feb 16, 2009
    3,024
    Is your postie running hot ?
    Add extra cooling :kat
    Clacka and Mouse like this.
  10. Flodder
    Flodder Flodder
    Jan 25, 2007
    823
    WILL_S likes this.
  11. Mouse
    Mouse I'm only smelly
    Nov 1, 2005
    14,926
    Byron Bay
    Fire that up and you'd think you had a Detroit diesel hiding in your workshop (oil everywhere)
    WILL_S likes this.
  12. WILL_S
    Feb 16, 2009
    3,024
    Turns out the chinaman found a way to use less metal.
    The jap ones are the go ;-)
    Fat sleeve and a big hole
    Te Hopo, Clacka and Flodder like this.
  13. =SUTTO=
    =SUTTO= Adventurer
    Apr 4, 2012
    37
    Newcastle, Australia
    I'm not mechanic but I thought putting in new chain and sprockets would not be out of my depth until I started to struggle to remove the final drive sprocket. Can't for the life of me get the bolts off. Is there something I am missing? are the bolts held in by some kind of cir-clips?
  14. WILL_S
    Feb 16, 2009
    3,024
    Rattle gun.
    Depending sprocket brand you might need to hold the bolt head as well
  15. =SUTTO=
    =SUTTO= Adventurer
    Apr 4, 2012
    37
    Spot on Wiil-s, Needed the rattle gun, suckers were just on too tight.
  16. kipo
    kipo South Australian Tiger Resistance Group
    Jan 8, 2007
    2,962
    Port Augusta
    Mine were as tight as fuck as well. I got a big block of wood and put in 2 coach bolts to hold the sprocket so I could get some tension on the socket to undo them.
    WILL_S likes this.
  17. WILL_S
    Feb 16, 2009
    3,024
    Chucked a few thousand on the stroker over a week.
    It decided to throw a bolt out the cylinder and gove my boot a good old oiling.
    Pretty impressed no need for a china if you want a bit of go
    sidetrack one and Flodder like this.
  18. Rum Runna
    Rum Runna Adventurer
    Oct 15, 2015
    98
    Port Hedland WA
    Just bought my first postie yesterday. What foot pegs fit the CT?
  19. WILL_S
    Feb 16, 2009
    3,024
    A few mods can get pivot pegz on.
    Otherwise some of the china pitbike ones fit
  20. Toy Rolex
    Toy Rolex Been here awhile
    Feb 14, 2013
    291
    CT110 ag bikes have steel pegs while the CT110 posties have the rubber pegs.
