1. eNewsletter Sign Up
Oz/Kiwi KTM 640 ADV riders sign in here please.
Discussion in 'Australia' started by overlandr, May 10, 2006.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,533
    Here and There
    too much orange?... Nah!
    dnrobertson likes this.
  2. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,706
    THE MALLEE OUT BUSH IN Sth Oz
    i done my water in Orange & oil in Blue hoses
    braaap! likes this.
  3. braaap!
    Mar 16, 2005
    4,533
    Here and There
    where fore come these blue hoses you speak of... Samco?
  4. veetwo _tls
    Nov 14, 2005
    2,706
    Oil hoses were not samco but are same type silicon hoses - were on ebay ASI the brand approx 6 yrs ago
    just see the blue hose don't have any with it apart
  5. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Cheers V2TLS, are your (blue, oil) hoses formed, like Samco or generic pieces?
    All my hoses are now getting on, 13 years old and should be renewed. I'll delve further into the cesspit of ebay :)
  6. veetwo _tls
    Nov 14, 2005
    2,706
  7. Dee Cee
    Dee Cee Been here awhile
    Mar 6, 2006
    586
    Newlyn. Victoria.
    Watching the hose thing with great interest as mine are nearly 14 years old and I feel that it is time for some preventative maintenance.:-)
  8. clintnz
    clintnz Trans-Global Chook Chaser
    May 17, 2004
    4,915
    Rotoiti, North Is, New Zealand
    Me too, haven't heard anything bad about the bling orange silicone ASI ones & there must be some out there with a few miles on them now? I have heard it mentioned that you need to get the right kind of hoseclip for them, be interested to see exactly what they look like.
    Cheers
    Clint
  9. mcguyver
    mcguyver Long timer
    Dec 24, 2005
    2,163
    STRALIA
    I have had the orange asi hoses on mine for over 50000 klms. No issues at all.
    Bike now has 70000 so I should do the oil lines now.
  10. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,197
    Cloverdale,BC
    You can never have too much orange.......at last count, I think I had 13 different shades of orange on my bike......I sure wish all the vendors would get together and decide on one hue of orange.
    Oh, and by the way......you missed getting the KTM orange oil fill cap!
    Cheers
    braaap! likes this.
  11. Dee Cee
    Mar 6, 2006
    586
    Newlyn. Victoria.
    Bugger, now I know my life is incomplete.
    Yes I have heard that some hose clamps will cut the silicone hoses and also they can be more slippery than normal rubber so again, the appropriate clamps are good in the long run. What sort of ones you running Mr Mcguyver?
  12. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Hey DeeCee, the hose clamps for silicone hoses are not the std perforated type... Designed so they don't chew up the hose, Samco sell hose clamp sets to match their hose sets. I also bought same clamps from a local speed shop online, have to dig out the paperwork to check who they were, they where identical, S/S and sized to hose diameter.
    Close inspection of my original hoses showed up lots of age cracks... whilst new hoses aint cheap, it's peace of mind and might save a long walk repeating over and over... Fcuk, fcuk, fcuk!.. Shoulda...
  13. Dee Cee
    Mar 6, 2006
    586
    Newlyn. Victoria.
    Sounds like the hose clamps I would be looking for.
    Couldn't agree more about the long walk with time to contemplate a little cost cutting measure.:bluduh:bluduh
  14. GSDane
    GSDane Ride like a girl
    Jun 29, 2007
    641
    Denmark...
    G'day all...
    I am looking at replacing the radiator cap on my 2003 640 Adv... standard for the bike is 1.4bar (written om the current original cap) / 19,6 psi (info from the part no.).
    The shop only has a 1.8bar on the shelf at the moment...
    Any pro and cons on fitting a higher pressure cap?
    Cheers, D.
  15. braaap!
    Mar 16, 2005
    4,533
    Here and There
  16. braaap!
    Mar 16, 2005
    4,533
    Here and There
    temporary measure if you have to... what state are your 03 hoses in?
  17. clintnz
    May 17, 2004
    4,915
    Ah yep, so the type with indentations to form the 'thread' rather than perforations. Usually a better clamp anyway. Norma brand ones are common over here. If you want to go all factory-like & keep the crimp on clamps at the waterpump, see if your local engineering supplies shop has them - known as Oetiker clips. Crimp them on with end nippers.
    Cheers
    Clint
  18. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Hi Clintz, yep, Oetikers are very factory, but out in the field can be a pita to service, tracked down a local supplier of the S/S worm type clamps in all sizes.... Foaley Performance: https://www.fpstore.com.au/collections/jcs-hose-clamps.
    Interesting developments over in the BST Bible thread... Derek (Motolab) knows stuff! Seems early carb advice was not the best in the long run... I drilled my throttle slide in the early days.
    Slide Guide just a little worn!
    cheers,
  19. Droptarotter
    Jul 11, 2007
    2,197
    Cloverdale,BC
    Holey cow......do you have a needle left?? How oval is the emulsion tube hole??
    Cheers
  20. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,484
    GodSowncountry Australia
    The obvious con of having the extra pressure escape through the hole where it just blew a hose off?
