1. eNewsletter Sign Up
Oz/Kiwi KTM 640 ADV riders sign in here please.
Discussion in 'Australia' started by overlandr, May 10, 2006.
  1. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,536
    Here and There
    @enookway
    Sure! zing me a post address :)
  2. enookway
    enookway Are we having fun yet?
    Jan 3, 2008
    855
    Leeton NSW
    PM Sent. The photo highlights a bit if a gap in my question. I also need the frame brackets that the pegs mount to.
  3. rvt
    rvt Big Fat Trail Bikes
    Feb 20, 2011
    2,030
    Western Australia
    @enookway you can have these for postage, if no luck with @braaap! Will be from Perth way, not sure of $
    No rubber grips unfortunately. [​IMG]
  4. rvt
    Feb 20, 2011
    2,030
    Western Australia
    I managed to get hold of a standard ktm hgs4 muffler locally, thanks to Jabba600 and Dave (not sure if Dave is on here).
    It seems a bit quieter than the staintune, so the mission is sort of accomplished
    Bit confused now though. Being me, I pulled the large end cap off to look inside. After much researching, I expected it to contain a few sections of perforated pipe, with the flow taking a path backward and forward to the outlet.
    What I could see was a pipe projecting into the front end, a void in the middle, and a perforated pipe surrounded by packing at the rear. The packing goes all the way to the end cap. No discs that I could see. This is all by peering into the end so may not be completely accurate. I could poke a plastic strip all the way through.
    It also has a removable tailpipe insert thingy, like the staintune.
    Is this what the Australian hgs4 is like? Or has mine been modified somehow?
    The markings are KTM HGS 4 e1 0272
    It seems a bit quieter than the staintune, so the mission is sort of accomplished.
  5. bikemoto
    bikemoto Tyre critic
    Oct 24, 2004
    4,267
    Nelson, New Zealand
    Not sure, will go look at mine which is the EU/AU spec likely the same as yours. This is a completely different beast to the USA-spec muffler which is a SuperTrapp with their signature end-discs under the end cap. The USA-spec item is 1 kg heavier, too. I'm running a USA-spec with more discs than standard so it is a bit more open than the EU/AU one. Probably should chase up an SXC one to shave some weight.
    rvt likes this.
  6. rvt
    Feb 20, 2011
    2,030
    Western Australia
    Thanks Bikemoto.
    I found the claw hammer was the best tool for working the end cap out, after removing the three screws. If you go that far.
  7. rvt
    Feb 20, 2011
    2,030
    Western Australia
    With the end cap removed, lit up inside with a telescopic torch.
  8. Aussie Steve
    Aussie Steve Long timer
    Apr 9, 2007
    1,488
    Maitland
    Just had a look at my stock muffler, looks to be a baffled job as can see an end cap though the tip with cutouts around the outside for exhaust flow, also no insert in mine.
    rvt likes this.
  9. rvt
    Feb 20, 2011
    2,030
    Western Australia
    Thanks Aussie Steve. Is the end cap on a perforated tube? Which end? Or am I picturing it wrong?
  10. Aussie Steve
    Apr 9, 2007
    1,488
    Maitland
    Haven't been real thorough with inspection but end cap appears to be welded to outer housing at three points with exhaust flow between the cap and outer section. This is looking in the exhaust outlet with the end cap still in place.
    I am disorganised at the moment and have broken my phone so cant send you pictures this week, can follow up later if you like.
    rvt likes this.
  11. Aussie Steve
    Apr 9, 2007
    1,488
    Maitland
    Question for those with non cush drive hubs, have you done much road biased riding on them without failure?
    Just gave the bike a look over before next weekends 1500ish km ride which will have plenty of road, my rear cush drive rim is stuffed. Thinking if time beats me will just chuck a good non cush drive wheel on as that many ks on a 10 year old wheel shouldn't be asking for too much trouble. Anyone with any experience??
  12. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,494
    GodSowncountry Australia
    I run a non-cush hub on my '95 XR600R. It's seen lots of tar kilometres, but I always run full knobbies as I figure the knob flex is as good as a cush hub.
  13. Aussie Steve
    Apr 9, 2007
    1,488
    Maitland
    Thanks Gods, think the old xr hubs were built with a little less consideration given to weight. Know the 625s were prone to cracking hubs at the drive flange but wasn't sure how long it was taking.
  14. motolab
    motolab Long timer
    Feb 16, 2006
    6,287
    I'd be more concerned about the transmission (that's what the cush drive is meant to protect).
    Regards,
    Derek
  15. GodSilla
    Sep 21, 2006
    12,494
    Exactly.
  16. Toe - Cutter
    Toe - Cutter 666
    Sep 3, 2010
    947
    S/Coast NSW Oz Planet of the apes.
    Trashed a hub , @ krawarree
    3500k trip,
    During ,,,,Did,nt bother to check touque on sprocket bolts ,
    Came Loose from lotsa transport sections ,
    Old bloke in a kingswood stopped and we fished out a few odd bolts rolling around in the recesses of his boot, bunch ah zip ties ,
    Got me top speed off 30 k ph
    Now I carry a spare set of bolts .....
    Luckily it happened about 100 k from home ,
  17. enookway
    Jan 3, 2008
    855
    Leeton NSW
    All good, @braaap! had the brackets as well.
    Many thinks to @braaap! for his generous donation to the greater motorcycledom.
    Did anyone on here pick up this bargain:
    Sounds like it wasn't a basket case either:
    I brought it about 6 months ago to get on the road but the same old story haven't got time. I have cleaned the carburetor out and had it running for about five minutes. The motor turn over free on starter motor with the decompression lever on but only just turn over with it off. Kicking its hard with the left hand kicker. Seems to have good compression. Have books........
    5776km
  18. overlandr
    overlandr Dystopist
    Nov 30, 2003
    6,021
    Sydney
    Time to kick this thready back into action. Q. I wonder if anyone has come across one of these fairings in oz, top half from a 660 rr tall fairing and bottom "as you were" from a 640A. They seem to be popular on pre-2007 640A dakar entrants' bikes.
    The rider above has a bit of a long story on his own Paris-Dakar race. Anyone whom can handle french, its all here. Actually, it sounds exciting stuff, eg "Je m’arrête à nouveau sur le bord de la piste, un contrôleur me crie qu’il ne faut pas rester là, les voitures arrivent ! Je me range un peu mieux pour une nouvelle réparation… « TRIIIT-TRIIIT-TRIIIT…TRIIIT-TRIIIT-TRIIIT ! ! ! » hurle le buzzer de mon SENTINEL. Voilà la première voiture."
    PS He's got the right bike for the rallye but what about the rider? Guessing one should have a skillset that includez dis 'ere !
  19. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,198
    Cloverdale,BC
    The guy in the red gear must be huge.......he makes the 640 look small!
    Cheers
  20. enookway
    Jan 3, 2008
    855
    Leeton NSW
