1. eNewsletter Sign Up
Oz/Kiwi KTM 640 ADV riders sign in here please.
Discussion in 'Australia' started by overlandr, May 10, 2006.
  1. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,485
    GodSowncountry Australia
    New rubbers is tight. :nod (wait until you try and remove it soon after fitting .....:knary)
    Some rubber grease may assist if you have any. Otherwise, try talc?
  2. rowie
    rowie Been here awhile
    May 1, 2011
    373
    Proserpine, QLD
    Thanks mate. I have both. Will try talc first. If that doesn't work, then grease it is :D
  3. rowie
    May 1, 2011
    373
    Proserpine, QLD
    Noticed a couple of weeps from the left radiator. Gave them a poke and this happened
    The only options seem to be the Chinese versions from Ebay. Has anyone fitted them to a 625? If so, did they fit okay and is there any clearance issues with the fan and 27L Safari tank cross brace?
    The bike has been sitting for about 8 years and there is a lot of rust in the bottom tanks. Not sure where the rust would have come from because I thought everything the coolant touched was alloy. Planning to put new seal and bearings in the water pump, and I'll check the thermostat while I'm at it.
  4. GodSilla
    Sep 21, 2006
    12,485
    I'd stay away from Chinese ebay stuff.
    Look for a decent radiator repairer/fabricator and get them redone or remade, with an extra core maybe for the Queensland heat eh. That's an option if you have bucks to spare. I seem to recall a couple of businesses used to advertise in the Australian Motor Ccycle News a few years ago for that service, so I'd suppose there's still folks around who do it.
    Locally, I use a bloke in Canberra who can fix anything made of any metal, basically. He didn't even take money for the last job (a split KTM bashplate, almost split in half..). He did the best repair job on the crankcase of my old TY250 twinshock too, without splitting the cases either, and it was better than original when he was done. He's done my XR a couple of times too. He'd fix a radiator, probably put a new bottom on the tank eh and weld it in, that would be the easiest/cheapest repair and you could inspect the guts while the bottom was off.
  5. clintnz
    clintnz Trans-Global Chook Chaser
    May 17, 2004
    4,917
    Rotoiti, North Is, New Zealand
    I got some of the cheap Rads for the 640, off NZ trademe site but ex Oz 'alloyworks' They were pretty much identical to stock, apart from the thermoswitch fitting which was too small a thread. I drilled & tapped it to the correct M18 x 1.5, there was plenty of meat in the boss to do that, & they have been running happily for 3 years+.
    Cheers
    Clint
    GodSilla likes this.
  6. enookway
    enookway Are we having fun yet?
    Jan 3, 2008
    854
    Leeton NSW
  7. rowie
    May 1, 2011
    373
    Proserpine, QLD
    Thanks mate. I cut the bottom tank off and found the tube headers are just about shagged as well. So it went into the recycle bin. I have a new right side radiator which I picked up dirt cheap from ebay. Not having much luck finding a suitable left side companion for it, so it looks like the Chinese versions are the best option at this stage. I've done a lot of searching and haven't seen any negative comments about them when fitted to LC4s.
  8. rowie
    May 1, 2011
    373
    Proserpine, QLD
    Thanks Clint. Found the alloyworks versions on ebay and have ordered a set.
  9. rowie
    May 1, 2011
    373
    Proserpine, QLD
  10. rowie
    May 1, 2011
    373
    Proserpine, QLD
    Checked the rest of the cooling system after finding the forked radiators.
    Oh dear
    So it looks like I'll be removing the head and cylinder so they can be thoroughly cleaned and checked. Bike has done 12000km, but I'll replace the rings because they won't go back in the exact position. Anything else I should check or replace while it's apart? Obviously the water pump housing is one thing :-)
    Sigh.....
  11. enookway
    Jan 3, 2008
    854
    Leeton NSW
    Starter sprague clutch spring
    Water pump bearings and seals
    Camshaft bearings
    Rocker needle bearings
    There was a bit of discussion about this around page 278 of this thread
  12. GodSilla
    Sep 21, 2006
    12,485
    :fpalm That bike looks to have been run on straight water @rowie. A good pressure clean of the coolant galleries will be required to get all the rust slime out eh.
  13. OzCRU
    OzCRU Been here awhile
    Feb 16, 2015
    880
    Sydney Australia
    How about a soda blast?
  14. clintnz
    May 17, 2004
    4,917
    Or seawater maybe? :eekers The coolant circuit in mine has always been quite clean when I've had things apart.
    12000km is bugger all really, apart from the obviously rooted bits I wouldn't get too carried away replacing stuff unless it definitely needs it, but I would give it all a good check.
    Cheers
    Clint
  15. GodSilla
    Sep 21, 2006
    12,485
    I'm with you, the rocker arm bearings I'd replace because they do randomly fail in some low-k bikes, but otherwise just seals and damaged bits.
  16. rowie
    May 1, 2011
    373
    Proserpine, QLD
    Thanks blokes. Going to pull it apart today and hopefully there wont be any more expensive surprises. It has been sitting for about 8 years now so I guess the fluid that was in the radiators was the remains of the factory coolant. Still a bit worried about the rust though. Hopefully the cylinder bolts are not in the coolant galleries. So far the only steel touching the coolant I've found is the 2 bolts holding the thermostat housing, which were corroded on the end.
    An engine builder here has a big ultrasonic cleaner now, so I'll take the parts to him and ask if it will get all the shite out of the galleries.
    The new radiators arrived yesterday
    FFS :fpalm
    I'll post some photos once I have it apart.
    mcguyver and braaap! like this.
  17. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,533
    Here and There
    These things and their parts are becoming a bit like 'hens teeth'... Let's look after them!
    mcguyver likes this.
  18. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,308
    NW Sydney, Australia
    Would anyone have a late good clutch master for sale?
  19. rowie
    May 1, 2011
    373
    Proserpine, QLD
    This is what it looked like inside the water jacket.
    Luckily it looked much worse than it actually was. Gave it a blast with the Gerni and most of it cleaned out.
    Just have to wait for parts now
    mcguyver and GodSilla like this.
  20. braaap!
    Mar 16, 2005
    4,533
    Here and There
    Hey @rowie grab some of this gear from Supercheap Auto... Brilliant rust remover! Will clean out the water jacket galleries like new.
    Non toxic, bio-degradable... Will not affect aluminium etc!
    Cheers!
    mcguyver, GodSilla and 1coolbanana like this.
