Oz / Kiwi Suzuki DR650 Adv Riders Sign in Here please
Discussion in 'Australia' started by davorallyfan, Feb 20, 2007.
  1. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    11,865
    Snowy Mountains Oz
    The Mitas E09 and E07 130/80s are OK too.
    NTJosh likes this.
  2. sidetrack one
    sidetrack one Chief Tiddler Supporter
    Jul 2, 2006
    9,702
    hole shaven area
    What we are talking about re sprocket tooth count...a chain has an inner and outer link,in this example it is clear the inner was in contact with the same teeth constantly!
    20190824_172654.jpg p
    robmoto, Chalkie62 and Precis like this.
  3. schmik
    schmik Been here awhile
    Oct 1, 2016
    460
    Shitney
    I WISH it came in a 17.
    4000 - 4500km is all I can get out of a 606 rear.
    The E07 lasted a lot long but was only good for the first half of its life offroad. After that, the centre strip would make it break loose very easily.
    BergDonk and dmsantam like this.
  4. fayeslane
    fayeslane Rankest of amateurs
    Oct 16, 2009
    4,624
    Albury, NSW
    You are 500-1000kms ahead of most blokes :bluduh
  5. schmik
    Oct 1, 2016
    460
    Shitney
    Meaning you guys get more or less km?
  6. fayeslane
    Oct 16, 2009
    4,624
    Albury, NSW
    Usually gone at abour 3500 kms for me
  7. schmik
    Oct 1, 2016
    460
    Shitney
    Then again... I do have my speedo / odo fail regularly. Maybe I am over estimating what i get.
  8. kezzajohnson
    kezzajohnson kezza
    Apr 17, 2007
    3,853
    Cairns - Queensland Australia
    Only ever had a D606 in the same size as yours on the 18 inch. With a 112 links 15/46 combo, here's my gap between the swingarm with a brand new one (and brand new chain and sprockets). Never rubs anywhere except on the stock tool tube plastic guard on compression.
    BergDonk likes this.
  9. NTJosh
    NTJosh Been here awhile Supporter
    Nov 27, 2015
    254
    Western Australia
    Yep, mines similar..not much room in there!!
  10. NTJosh
    Nov 27, 2015
    254
    Western Australia
    Lad’s,
    Just an update on my Trailtech Vapour issue (Moisture/Condensation in screen).
    I heard back from Adv Bike Aus this morning, they contacted Trailtech who have advised they are going to send me a replacement unit direct.
    Can’t complain about that!
    Regards
    Josh
  11. kezzajohnson
    kezzajohnson kezza
    Apr 17, 2007
    3,853
    Nice - good to see they back them up. Might have to have a whine about mine except I don't have a photo of it in that condition.
    edit...just looked up my receipt and have had it over a year now so out of warranty. Ah, well-suck it up.
  12. BergDonk
    Nov 15, 2010
    11,865
    Snowy Mountains Oz
    Not unexpected, I have heard good things about TT's backup in such situations in the past.
    leighwgold and Precis like this.
  13. DIRT SQUIRTER
    DIRT SQUIRTER Bitumen is just a way of getting there!
    Oct 7, 2015
    130
    Coromadel Valley
    Farkles.... just got round to tallying up about $3,000 to date. Maybe a screen, Barrett rack and luggage kit of some sort should see me done; Oh fark! maybe the Nova box and big bore kit too???:gdog Meh... :D
    Needless to say it is coming together nicely. Best $ spent so far was on the FFRC suspension, transformed it. (ok, the replacement seat = 1st):hmmmmm
  14. DIRT SQUIRTER
    Oct 7, 2015
    130
    Coromadel Valley
    Results of a bit of shed time on the week end.
    1) Tuck in gauge and switch holder fabricated; fitted grip heater Heat demon switch, & light bar isolate/off switch (it still dips on/off STD switch)
    2) Trail tech fan fitted after re-doing plugs to fit the gauge in the dash: I was a bit disappointed that the kit did not come with enough goodies to get the control unit remote mounted (probably sold as kit to add to the kit???FFS).. had to buy plugs and change them with extra wire. :dirtdog It was a squeeze and trimmed a bit off the fan housing to allow for the movement of the radiator on mounts during "naps" on the trails.. :augie
    3) Brackets fabricated for Aurora 50W Light bar, fitted and wired up via relay. Yet to try on road but over powers the JNS LED head light output (a lot)
    4) SAE lead to main fused block, for Mini moto air pump/battery maintenance
    Will be interesting to see what the temps on the gauge get to.
    The grip heaters will get put off from fitting for a while. Do you need 2 throttle tube side grips to fit these? Looks like you might stuff them trying to get the STD LH grip over them ?? suggestions? experiences gents??
    leighwgold and Suncoaster like this.
  15. BergDonk
    Nov 15, 2010
    11,865
    Snowy Mountains Oz
    Not normally, but can be grip dependent to an extent. Softer grips will grow enough. I use brake cleaner as a lube/part solvent, then 5 double wraps of stainless tie wire.
    I'm keen to hear how the fan works out, I still might swap my thermostat for a fan.
    DIRT SQUIRTER likes this.
  16. leighwgold
    leighwgold Ph.D. of B.S. Supporter
    Oct 18, 2008
    233
    Salisbury Heights
    A fan question? Just putting a Safari 30l tank on and can see the oil cooler airflow is a bit restricted, has anyone noticed if the oil temps have increased in slow hard going? Might it be beneficial to fit one? DR is standard bore with Staintune, airbox and BST40 mods.
  17. DIRT SQUIRTER
    Oct 7, 2015
    130
    Coromadel Valley
    Nice to know; thanks. I'll have a fool around and get some fan on/off temps as well as air scoop off for giggles on a slow weekend. I'll collate and post for all.
    Probably (based on my faulty logic:loco) would have to get hotter. My 20L restricts air movement compared to the stock tank; I put the air scoop on the side of the oil cooler to help out the air flow. I get a hit of hot air as I start moving since fitting. (PM me & I'll post you one to try).
    The fan when it kicks in moves a lot of air! I was impressed. I think it was necessary for me, to fit one, as I commute in city traffic and the oil change after a hot week (40C+) suggested I may have "overheated" the oil, based on the metal "dust" in it not usually seen. :hmmmmm
    Cheers DS
  18. Precis
    Precis Maladroit malcontent
    Oct 13, 2009
    6,188
    Body's back home, but soul is in Central America
    Highest oil temp I've seen is 186 degC.
  19. leighwgold
    Oct 18, 2008
    233
    Salisbury Heights
    Thanks DS
    I have already fitted an airscoop to the oil cooler which would also act as a bit of a heat sink too! Interesting point about the hit of hot air when you move off. I haven't ridden with the Safari on yet, only the Acerbis 20litre.
    When you change your oil after a hot one is it burnt looking (dark)? Do you run full synthetic or semi oil?
    I am running Penrite 4L MC-4 10W40 100% Pao Ester 4 Stroke Oil, seems ok.
  20. BergDonk
    Nov 15, 2010
    11,865
    Snowy Mountains Oz
    Measured where? Curious minds...
