1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
Oz / Kiwi Suzuki DR650 Adv Riders Sign in Here please
Discussion in 'Australia' started by davorallyfan, Feb 20, 2007.
  1. sidetrack one
    sidetrack one Chief Tiddler Supporter
    Jul 2, 2006
    10,289
    hole shaven area
    Had a great week with the scrappers!
    OzCRU, Nogoodnamesleft and BergDonk like this.
  2. Precis
    Precis Maladroit malcontent
    Oct 13, 2009
    6,934
    Free at last, free at last!
    Rear shock removal & replacement: piece of cake, or PITA? Roughly how long should it take, what needs to come off? Airbox? Battery? Headlamp? (No, hang on - that's BMW, isn't it...?)
  3. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    14,443
    Snowy Mountains Oz
    3 options:
    1. remove airbox and then remove the shock that way via the LHS
    2. remove exhaust and remove the shock up and via the RHS
    3. remove the rear wheel and drop the shock out underneath
    I've mostly done it via #2, but #3 of late, much the same time wise, but now no choice with my frame upgrades to use #3. I reckon removing the airbox first is more work than necessary, but others prefer to do it this way.
    Precis likes this.
  4. leighwgold
    leighwgold Ph.D. of B.S. Supporter
    Oct 18, 2008
    270
    Salisbury Heights
    I use #3 but I have removed side covers, seat and tank too, usually to do other stuff as well.
    Precis and BergDonk like this.
  5. sidetrack one
    Jul 2, 2006
    10,289
    hole shaven area
    #3 for me as well! With all the mods to mine only option time wise!
    leighwgold, Precis and BergDonk like this.
  6. BergDonk
    Nov 15, 2010
    14,443
    Snowy Mountains Oz
    #3 also makes it easy to then remove the swingarm to lube the pivot bearing too.
  7. dmsantam
    dmsantam DR and FZ1 rider
    Dec 15, 2012
    216
    Sydney, Australia
    always #3 for me. piece of cake.
    leighwgold and Precis like this.
  8. Precis
    Oct 13, 2009
    6,934
    Yes, I know I need to vacuum the carpet. Someday....
  9. Precis
    Oct 13, 2009
    6,934
    Okay, not entirely unrelated Q: the two plastic nubs on the front of the airbox which are supposed to locate the front of the sidecovers: all of ours are too short and the sidecover is effectively held in place only by the seat and the knurled thumb-nut I replaced the lower bolt with. I had idly considered cutting the little plastic bits off and replacing them with slightly longer studs of the same diameter. With the stock shock's reservoir in place there's no room - but with the Cogent...
    Worthwhile, or am I just finding reasons to stuff about instead of doing other things - such as vacuumming the damn carpet?!
  10. BergDonk
    Nov 15, 2010
    14,443
    Snowy Mountains Oz
    the cheap one :D
  11. BergDonk
    Nov 15, 2010
    14,443
    Snowy Mountains Oz
    Why bother, its been fine to date? I don't think any of them ever worked as intended for very long. Maybe they'll sort it on the 2021 model?
  12. Precis
    Oct 13, 2009
    6,934
    Yes - but I need 3, don't forget! And anyway I suspect I don't need the extra capability.
  13. Precis
    Oct 13, 2009
    6,934
    You are NOT helping me find reasons to avoid vacuuming! Actually, MrsP's right sidecover did pop out from under the seat a while back.
    leighwgold likes this.
  14. dmsantam
    Dec 15, 2012
    216
    Sydney, Australia
    Awesome! be aware that the torque specs for that lower shock bolt is a known suzuki manual error (55Nm). It's also that value in the My DR650 app. If you use the book value, it may strip. I use 37Nm. The cogent shock may come with instructions with the correct value, I'm not sure.
  15. sages
    sages Been here awhile
    Sep 23, 2008
    406
    Perth, West Australia
    I think the carpet looks fine. You can still see it's carpet.
    Precis and leighwgold like this.
  16. Precis
    Oct 13, 2009
    6,934
    One of those labels addresses just that: 41Nm and locktite are recommended!
    dmsantam likes this.
  17. Precis
    Oct 13, 2009
    6,934
    :jack:imaposer:wings:happay
  18. sidetrack one
    Jul 2, 2006
    10,289
    hole shaven area
    Getting TTR shock out was a real mission so I heavily modded the lhs and repositioned most stuff
  19. Precis
    Oct 13, 2009
    6,934
    I'm hoping to only do it the once... just on three bikes...
    leighwgold and sidetrack one like this.
  20. kezzajohnson
    kezzajohnson kezza
    Apr 17, 2007
    3,962
    Cairns - Queensland Australia
    I secure mine at the other (rear) end with a simple screw - just drill a hole there and Bob's your Aunty Mary.
