1. eNewsletter Sign Up
Oz / Kiwi Suzuki DR650 Adv Riders Sign in Here please
Discussion in 'Australia' started by davorallyfan, Feb 20, 2007.
  1. Russ
    Russ Long timer
    Jul 22, 2007
    23,995
    Sydney
    Jump on a ferry to Manly and have a couple of schooners at the Steyne.
    Or jump on a river cat and get off at Abbortsford and have a few quiet ones at Sydney rowing club.
    Or walk over the bridge and have a few quiet ones at the Kirribilli club over looking lavender bay.
    Precis and sidetrack one like this.
  2. sidetrack one
    sidetrack one Chief Tiddler Supporter
    Jul 2, 2006
    9,824
    hole shaven area
    Nicks at Darling harbour for seafood
    Munich Brauhaus at the rocks.for meat
    Bbq king for Asian
    Joe Black cafe for brekky
    Precis and Russ like this.
  3. fayeslane
    fayeslane Rankest of amateurs
    Oct 16, 2009
    4,767
    Albury, NSW
    There goes another 80 bucks of my pocket money :D
    BygDaddee likes this.
  4. DR Steve
    DR Steve Been here awhile
    Jan 21, 2012
    862
    Melbourne, Australia
    Modding the cush hub to add an inner bearing will make the drive line smoother. The comments on improvements with the poly cush rubbers prove it although they're treating the symptom not the cause.
    Precis and BergDonk like this.
  5. Maso
    Maso Adventurer
    Aug 8, 2010
    42
    Coffs Harbour
    Leaking Shock Absorber
    To cut a long story short, I haven't ridden for a while till couple of weeks ago.
    Now my rear shock is leaking. Guess that serves me right for not riding more often.
    Does anyone know of someone in Coffs Harbour area that rebuilds them, or is an aftermarket / replacement one a better option.
    If so where is the best place to get one from?
  6. fayeslane
    Oct 16, 2009
    4,767
    Albury, NSW
    Send it to
    https://www.fullforceracing.com.au/
    and get it rebuilt to your specs. You'll be very happy.
    Good blokes to talk to who know DR suspension.
    Chuck some Plex valves in the forks while you are on the go.
  7. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    9,743
    Brisbane Northside, OZ
    What he said, well worth it from FFRC
  8. Maso
    Maso Adventurer
    Aug 8, 2010
    42
    Coffs Harbour
    Thanks I will check it out
  9. Precis
    Precis Maladroit malcontent
    Oct 13, 2009
    6,300
    Body's back home, but soul is in Central America
    If yours is FBR, I have a couple of standard ones available. And Intiminators in the forks are the best single improvement to our DRs so far.
    leighwgold likes this.
  10. Maso
    Maso Adventurer
    Aug 8, 2010
    42
    Coffs Harbour
    I don't Think it is totally had it. I think it probably just needs new seals.
    Is that something most bike shops would do or is it more specialised?
  11. TheDecepticon
    TheDecepticon Wannabe
    Mar 17, 2014
    708
    Adelaide, South Australia
    Depends. Your bike shop is only as good as the blokes working in it. I would recommend someone who is familiar with the bike and its characteristics and can set the shock up to suit you and your gear.
    And maybe have the fronts checked and setup with intimators, plex or gold valves or something, it will be different bike.
    Precis, leighwgold and fayeslane like this.
  12. fayeslane
    Oct 16, 2009
    4,767
    Albury, NSW
    Had one done by FFRC . Already had a heavier Eibach spring on it. The new piston and revalving transformed it.
    If yours has to be rebuilt it might as well be set up for your use at the same time.
    Money spent on suspension is well spent.
  13. willows
    willows Been here awhile
    Jul 30, 2007
    316
    Grafton, NSW. Australia
    Hi guys, have listed my 2007 DR in the Flea market.. If you know anyone looking for one...
  14. Precis
    Oct 13, 2009
    6,300
    I put up a pic in the big DR thread about how Cogent will make a Mojave shock that matches the factory lowering measurements; fitting one is the easiest 780g you'll save - the shorter Cogent is 3.27kg, the stock Suzuki shock is 4.05kg. Woo-hoo - at this rate, I'll have to chain it down in strong winds - or just sit on it....
  15. BygDaddee
    Oct 26, 2012
    9,743
    Can someone tell me /diagram of how the stock carbie hooks up to the stock tank / petcock, im just not sure about the vacuum as its had the acerbis tank since i got
    Or can you just ignore the vacuum, blank something ?
  16. 0405canvet
    0405canvet Long timer Supporter
    Apr 14, 2012
    1,449
    brisbanish
    Stock tank fuel line goes to the carb obviously and the vacuum line must go from the diaphram cap to the petcock, to allow fuel to flow, if using the stock petcock.
  17. Goosefeather
    Goosefeather Captain Slow
    Apr 6, 2006
    1,041
    Brisbane, Queensland, Australia
  18. BygDaddee
    Oct 26, 2012
    9,743
    Ah up on top there, thanks for that i wasnt sure which little nozzle the vacuum was meant to go to
    Another stupid question then, seeing as it runs great now with acerbis with a standard type petcock with no vacuum can you fit a different tank petcock to stock tank and just run like it does now with no vacuum
  19. 0405canvet
    Apr 14, 2012
    1,449
    brisbanish
    Children with their questions! The stock petcock has three positions. Regular, reserve and prime. In the prime position fuel flows without the need for a vacuum line. That’s if the petcock is working properly.
  20. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    12,409
    Snowy Mountains Oz
    You could fit a standard type fuel tap if you can find one that fits. More Amercanisms sneaking into the language Paul, 'petcock'! A pet rooster or......?
