Oz / Kiwi Suzuki DR650 Adv Riders Sign in Here please
Discussion in 'Australia' started by davorallyfan, Feb 20, 2007.
  1. TheDecepticon
    TheDecepticon Wannabe
    Mar 17, 2014
    762
    Adelaide, South Australia
    Depends. Your bike shop is only as good as the blokes working in it. I would recommend someone who is familiar with the bike and its characteristics and can set the shock up to suit you and your gear.
    And maybe have the fronts checked and setup with intimators, plex or gold valves or something, it will be different bike.
    Precis, leighwgold and fayeslane like this.
  2. fayeslane
    fayeslane Rankest of amateurs
    Oct 16, 2009
    5,025
    Albury, NSW
    Had one done by FFRC . Already had a heavier Eibach spring on it. The new piston and revalving transformed it.
    If yours has to be rebuilt it might as well be set up for your use at the same time.
    Money spent on suspension is well spent.
  3. willows
    willows Been here awhile
    Jul 30, 2007
    322
    Grafton, NSW. Australia
    Hi guys, have listed my 2007 DR in the Flea market.. If you know anyone looking for one...
  4. Precis
    Precis Maladroit malcontent
    Oct 13, 2009
    6,939
    Free at last, free at last!
    I put up a pic in the big DR thread about how Cogent will make a Mojave shock that matches the factory lowering measurements; fitting one is the easiest 780g you'll save - the shorter Cogent is 3.27kg, the stock Suzuki shock is 4.05kg. Woo-hoo - at this rate, I'll have to chain it down in strong winds - or just sit on it....
  5. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    12,111
    Brisbane Northside, OZ
    Can someone tell me /diagram of how the stock carbie hooks up to the stock tank / petcock, im just not sure about the vacuum as its had the acerbis tank since i got
    Or can you just ignore the vacuum, blank something ?
  6. 0405canvet
    0405canvet Long timer Supporter
    Apr 14, 2012
    1,604
    brisbanish
    Stock tank fuel line goes to the carb obviously and the vacuum line must go from the diaphram cap to the petcock, to allow fuel to flow, if using the stock petcock.
    BygDaddee likes this.
  7. Goosefeather
    Goosefeather Captain Slow
    Apr 6, 2006
    1,072
    Brisbane, Queensland, Australia
  8. BygDaddee
    Oct 26, 2012
    12,111
    Ah up on top there, thanks for that i wasnt sure which little nozzle the vacuum was meant to go to
    Another stupid question then, seeing as it runs great now with acerbis with a standard type petcock with no vacuum can you fit a different tank petcock to stock tank and just run like it does now with no vacuum
  9. 0405canvet
    Apr 14, 2012
    1,604
    brisbanish
    Children with their questions! The stock petcock has three positions. Regular, reserve and prime. In the prime position fuel flows without the need for a vacuum line. That’s if the petcock is working properly.
  10. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    14,467
    Snowy Mountains Oz
    You could fit a standard type fuel tap if you can find one that fits. More Amercanisms sneaking into the language Paul, 'petcock'! A pet rooster or......?
  11. BygDaddee
    Oct 26, 2012
    12,111
    Um, its been called a petcock since i had my first yamaha in australia 1983, maybe NSW was just slow to catch on :D
    Precis likes this.
  12. BergDonk
    Nov 15, 2010
    14,467
    Snowy Mountains Oz
    Queenslanders, still learning the lingo!
  13. 0405canvet
    Apr 14, 2012
    1,604
    brisbanish
    Canadianism?? Petcock... married??
    simestd, BygDaddee and BergDonk like this.
  14. BygDaddee
    Oct 26, 2012
    12,111
    Sorry for the nube questions :linzi
    One more, will nitrogen in my tyres make the DR lighter :lol3
  15. BergDonk
    Nov 15, 2010
    14,467
    Snowy Mountains Oz
    Try helium.
  16. fayeslane
    Oct 16, 2009
    5,025
    Albury, NSW
    Come around and I'll do them for a slab. I've got a handy source of nitrogen...……......……...… :evil
    (...By volume, dry air contains 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.04% carbon dioxide, and small amounts of other gases.)
  17. BergDonk
    Nov 15, 2010
    14,467
    Snowy Mountains Oz
    But how heavy is it, density?
  18. fayeslane
    Oct 16, 2009
    5,025
    Albury, NSW
    About 0.0012506 grams/cubic cm depending on the day :wink:
    BergDonk likes this.
  19. BygDaddee
    Oct 26, 2012
    12,111
    If I don’t connect the vacuum hose to the tank but run it up to my mouth and blow will it act like a pumper carb ?
    Asking for a friend
  20. fayeslane
    Oct 16, 2009
    5,025
    Albury, NSW
    Two points -
    1. Less hose required to access your PCV (Posterior clacker valve) for an unlimited supply of methane that has an octane rating of approx. 130. Some engine and garment mods may be required :evil
    2. Change friends :D
