Oz XT1200Z Super Tenere owners sign in here please
Discussion in 'Australia' started by warnabrother, Jul 30, 2010.
  1. Sidm
    Sidm You get what you settle for!!!
    Oct 29, 2011
    56
    Middleton Sth Australia
    Hey guys, ive been running TKC80's on my S10, been reasonably happy with them, any suggestions on something similar, embarking on a 3k journey mid year, mostly dirt, any suggestions on what people are using and getting good klms,
  2. Hytram
    Hytram crash test dummy
    Sep 12, 2005
    813
    Melbourne
    Mitas E07 or E09 or E10
    Got about 5k out of E07 R/F and the same out a E07 R, E10 F.
    Extremely happy with grip levels on all surfaces
    Sidm likes this.
  3. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    8,705
    Snowy Mountains Oz
    Pirelli Scorpion Rally up front and an E07 up back has become my preferred setup. However I have a set of Motoz Tractionater Adventures to try next. The rears are getting good reviews, the 19" front have only just become available. They look a bit similar to the Rally so I'll find out if they work similar.
    rmunch44, Sidm and Hytram like this.
  4. trencher
    trencher BIG DEL
    Nov 3, 2013
    1
    western sydney
    i just bought this tenere . I bought in vic and rode it back to Sydney
    the tenere didn't miss a beat
    klx_dude, Hytram, Glenn C and 8 others like this.
  5. KIZ
    KIZ Marty
    Oct 7, 2011
    837
    Gawler South Australia
    Well my S10 now has a switch in series with the ABS solenoid, poxy mini 20 amp blade switch Hytram. Speedo still works OK , traction goes off as well. ABS still operated when I took out the 7.5 amp ABS control.
  6. neilc
    neilc Been here awhile
    Nov 10, 2008
    306
    GEELONG
    I have a 2016 SE to me I feel that the rear dose not ride quite as good as it might, my feeling is that the spring is to light I am around 95Kg with all riding gear and my wife 70Kg I find when solo the bike rids better with the suspension set for two up but using this when we get to two up with luggage I have run out of extra settings. It also feels as if there is to much compression dampening even set on the softest setting but then there is to little rebound so I generally run the STANDARD minus 3 setting dose anyone else notes this and have they found a solution or had there SE set up by a suspension specialist and if so who preferably in VIC
    Sidm likes this.
  7. Sidm
    Oct 29, 2011
    56
    Hey guys
    Can anyone tell me if there is a fuel filter on a 2010 S10, is it part of the pump, is the pump hard to change?
    Cheers
  8. BergDonk
    Nov 15, 2010
    8,705
    Snowy Mountains Oz
    There is a filter. I got one some time ago to carry it as a spare. Doesn't look hard to change, but not done yet. OTTOMH there isn't a S10 filter available, the one I got was for something else, but fits according to the internet consensus at the time. Can't tell you what it is from ATM as I'm on the road. I expect the stock filter could be cleaned OK too, perhaps with an ultrasonic cleaner.
  9. Glenn C
    Glenn C Adventurer
    Nov 18, 2010
    73
    Sydney
    Hi Sidm,
    Haven't changed one myself but as I recall, it's integrated into the fuel pump assembly. To remove the pump (again from memory of what I've read) - drain the tank, hinge it up from the front and undo the retaining bolts that hold the pump inside the tank. As I understand it, it's not too difficult to do.
    Here's a pic from the service manual
  10. Sidm
    Oct 29, 2011
    56
    Thanks for the info guys, much appreciated
  11. Happy Snapper
    Happy Snapper GOMOB.
    Feb 14, 2009
    3,146
    Brisbane, almost heaven!
    S10 40K service.
    Ok so the 40K service which includes checking the valves is closing in on me.
    Any idea from inmates on the time it takes for a dealer to do this and possible costs?
  12. BergDonk
    Nov 15, 2010
    8,705
    Snowy Mountains Oz
    Dunno, I'll be doing my 40k service soon too, including a new CCT so will have a better idea then. A bit time consuming to do it right I suspect, especially if the valves need adjusting.
  13. Happy Snapper
    Feb 14, 2009
    3,146
    Yes above my skill level. Are you going to change the clutch basket too....
  14. BergDonk
    Nov 15, 2010
    8,705
    Snowy Mountains Oz
    Clutch is fine on mine, so no change there.
  15. Happy Snapper
    Feb 14, 2009
    3,146
    Thought the new one was supposed to reduce vibration or something?
  16. BergDonk
    Nov 15, 2010
    8,705
    Snowy Mountains Oz
    Does if you have a vibe issue related to the clutch, if not....
  17. Happy Snapper
    Feb 14, 2009
    3,146
    OK... I have no idea..... will leave it.
  18. BergDonk
    Nov 15, 2010
    8,705
    Snowy Mountains Oz
    Some Gen Is vibrate at low revs, some more than others. Apparently its related to the clutch hub damping, and the Gen IIs got a new type damper. If you have a viby Gen I the new clutch hub supposedly fixes it, but if its not a problem, it doesn't make any difference. Mine is as smooth as a Gen II so I see no point to making the 'upgrade', especially at the full price. If I'd got one for $50 or whatever they went for initially then I might have got one anyway.
  19. gateman
    gateman Long timer
    Apr 12, 2009
    1,705
    Norther NSW, Australia
    Any post related to this. I would like to know as well.
    Cheers
  20. dazza67
    dazza67 Been here awhile
    Apr 29, 2012
    629
    Collinsville,Qld,Australia
    Hi guys...i've decided to sell the tiger955 & am keen for a second hand super ten preferably in qld if anyone is selling.
    Cheers!
    Out6ack likes this.
