P r o j e c t "s"
Discussion in 'Airheads' started by TINK, May 3, 2011.
  1. TINK
    TINK Been here awhile
    Nov 18, 2007
    788
    So Cal
  2. TINK
    Nov 18, 2007
    788
    So Cal
    Not really :hmmmmm
  3. GSAviator
    GSAviator Been here awhile Supporter
    Apr 10, 2007
    172
    Colorado Springs
    The rider doesn't.
  4. GSAviator
    Apr 10, 2007
    172
    Colorado Springs
    Thanks for the bar information, Tink. Probably will use the C20, though you can't beat the look of the low bar.
  5. TINK
    Nov 18, 2007
    788
    So Cal
    Flanders C20: Chrome Flanders BMW R90S Bar (Magura style 478-46300), http://www.flandersco.com/
    These are the proper 22mm diameter bars for BMW.
  6. TINK
    Nov 18, 2007
    788
    So Cal
    Sorry, it's been a while since I've posted anything...
    Time to have Race Tech upgrade my BMW R100S forks. When I restored my BMW back in 2011 I simply threw in a new set of IKON 500-084 progressive fork springs and replace all the seals. However, the stock BMW fork dampening has never been right for this bike. On the other hand; the IKON 7610-1298 shocks on the back have been amazing.
    Also replaced the 8 year old battery with a new WestCo 12V/30A from euromotoelectrics.com
    BTW; the battery weighs 21.6 lbs, it's a beast.
  7. GSAviator
    Apr 10, 2007
    172
    Colorado Springs
  8. TINK
    Nov 18, 2007
    788
    So Cal
    The WestCo fit is fine. The new battery is the same size as the one I had.
  9. mslim
    mslim If it's worth doing... it's worth overdoing
    Jan 11, 2015
    1,291
    Austin of the Ozarks
    These are great bars but be advised that the Tanax Napoleon Baren AP104's will not fit the Flanders bars. Although the Flanders o.d. is indeed 22mm, the i.d. is considerably thicker preventing the expandable rubber bushing on the Napoleons from fitting inside the bars. DAMHIK
  10. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,343
    rubber grinds well. Ask any shoemaker. I grind new tires before running them. Just use a i/4 sheet sander. I used to have some barens AIIRC the bushing is on a bolt. So it can be chucked in a drill press and worked with a strip of coarse sandpaper.
  11. TINK
    Nov 18, 2007
    788
    So Cal
    One thing that has bugged me about my R100S is that I could not see the blue high beam indicator light, and the other instrument lights were "adequate", but just barely.
    I just knew there had to be a fix for this... and KATDASH was the answer.
    Very well engineered high quality product, detailed installation instructions, only took one hour to install.
    I highly recommend KATDASH to every loyal Airhead owner.
    TINK
    GSAviator, groop and Big Bamboo like this.
  12. nobbylon
    nobbylon Long timer
    Aug 13, 2012
    1,062
    Very nice dash lights but jeez expensive.
    Steve W. likes this.
  13. ccmickelson
    ccmickelson MonoMania Supporter
    Dec 11, 2013
    2,267
    Fanta Se
    On the face of it, yes it seems a bit expensive for what it is, but when you factor in what all is involved to design and manufacture such esoteric parts for a motorcycle in relatively small numbers, it almost seems cheap. I can promise you she's not getting rich off of this endeavor and she is providing a much needed upgrade for these old bikes. I had the pleasure of meeting her a few years ago. Very cool person and as a rider, she's the real deal.
  14. robtg
    robtg Long timer
    Jun 29, 2007
    1,338
    san jose
    I looked at the prices,what a bargain.
  15. groop
    groop So much to ponder
    Jun 5, 2007
    6,119
    oc, ca
    Nice upgrade Brian. I don't typically ride the S at night, but if I did I certainly would consider this upgrade. Also I met Kat at the Airheads tent at a MOA rally a few years ago and she seems like a fine person who is truly interested in improving the airhead riding experience
    Uke likes this.
  16. brfoster
    brfoster Baile Atha Cliath
    Sep 2, 2010
    539
    Australia
    @nobbylon, expensive?? $130?? That's dirt cheap for what you are getting. The genuine BMW part is about $90 - if you can find one anywhere.
    And the KATDASH will probably outlive the bike.
    I will be getting the one for my 1984 R80G/S shortly. :beer
    Uke and WRC51 like this.
  17. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,767
    Silver Spring, Md
    On my list of things to do. Considering the amount of time spent getting worn out units to work it's a bargain. This is the logical solution for a common problem.
  18. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,730
    Orange County, CA
    cheapest thing about a bmw.......
    the rider
    Uke likes this.
  19. GSAviator
    Apr 10, 2007
    172
    Colorado Springs
    I agree. I spoke with her on the phone about an ordering error I made, and she was very gracious and accommodating. And, yes, the lights are wonderful.
    Uke likes this.
  20. TwoShoes
    TwoShoes How Many Shoes?
    Aug 18, 2003
    471
    Fredericton, New Brunswick, Canada
    This tread prompted me to order one to fix a problem affecting 3 of the lights on one of the R90S's (both instrument lights and the turn signal light). At first I thought it was just bad bulbs or bad connections, but digging deeper realized that it was the "circuit board", lights would go on if I jiggled it / bent it a certain way. Ordered the KatDash last Sunday, received it today, installed it and everything works like new again. Scratch that, everything works better than new, but without being an "obvious modern upgrade". I'm really impressed with the quality, the "plug-and-play"ness, and the fact that she includes an instrument gasket set along with it, really icing on the cake! Looking forwards to that first ride at night on the bike, imagine being actually able to see the instruments... IMG_2719.JPG IMG_2721.JPG
    TINK, headtube and Uke like this.
