P r o j e c t "s"
Discussion in 'Airheads' started by TINK, May 3, 2011.
  1. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,753
    Silver Spring, Md
    My speedo lights still work but I'm tempted to go with the KATDASH unit just for the improved lighting.
    Maybe I could sell the OEM unit for enough money to retire on? :rayof
  2. GSAviator
    GSAviator Been here awhile Supporter
    Apr 10, 2007
    172
    Colorado Springs
    Yep, mine worked too, but the Katdash is so much better. Let me know how the sale goes -- maybe I'll sell mine too.
    Terry had worked on mine before I changed the lights, so it was pretty nice and clean inside (Thanks Terry!)
  3. WRC51
    WRC51 Long timer
    Sep 8, 2008
    1,527
    Santa Rosa, Calif.
    Since we are talking speedos, can you run the bike long term with out the speedo/tach unit.(1976 R90/6) Most places are talking atleast a month and most a longer period of time, if I am not mistaken the Gen. light has to have a completed circuit to charge the batt.?? Not even sure if the blinkers and running lights would work with out eh speedo unit. Thanks
  4. Disston
    Aug 31, 2009
    15,753
    Silver Spring, Md
    I think the lights and turn signals work on a '76 without the dash but I'm not sure.
    True the alternator needs the resistance of the bulb to start charging but sometimes there will be enough residual magnetism in the rotor for it to start on it's own. You can check with a volt meter to see if it starts next time you start the bike but then you have to do that every time you take the bike out. It is most likely to start charging on it's own if it was run recently.
    I suppose you could also start it to charge by inserting a jumper with a fuse or bulb attached into the proper place, tiny holes, in the wiring block that fits into the back of the instrument cluster. Can't tell you off hand which ports that would be because I don'y have a wiring diagram here.
    WRC51 likes this.
  5. TINK
    TINK Been here awhile
    Nov 18, 2007
    788
    So Cal
    Finally got around to replacing the original 40 year old HELLA flasher relay on my BMW R100S with a modern LED compatible unit from https://katdash.com/
    [​IMG] [​IMG]
    My voltage gauge would swing wildly with the HELLA unit and the turn indicator lamp on the dash would stay on all the time regardless of the turn signal switch position.
    Now, with the new flasher, the voltage meter hardly moves when a turn signal is on and the indicator lamp turns on/off as expected.
    BTW; I'm still running the standard bulbs in my turn signals.
  6. TINK
    Nov 18, 2007
    788
    So Cal
    Finally did something about the faded instrument lettering using my Brother P-touch printer.
    It's not bad, but I would still like to find someone that can restore the original painted lettering.
    Replacing the face is out of the question at $250.
    tac650 and WRC51 like this.
  7. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    11,105
    Shoreline, WA
    I wish I had a p-touch printer, great idea!
  8. TINK
    Nov 18, 2007
    788
    So Cal
    After debating with myself whether to change out the /7 valve covers for the earlier "peanut" style valve covers, I finally threw in the towel.
    tac650, BicyclebBob and kaput13 like this.
  9. Disston
    Aug 31, 2009
    15,753
    Silver Spring, Md
    I like the early finned nuts too but the word is there is no extra cooling because of them so it's just looks. I run the late model covers because I got tired of buying the expensive peanut covers. The late model covers are quieter. You should notice this at first but after awhile you'll get used to it.
  10. TINK
    Nov 18, 2007
    788
    So Cal
    Before and After
    tac650 likes this.
  11. Disston
    Aug 31, 2009
    15,753
    Silver Spring, Md
    I was talking about extra cooling from the longer finned exhaust nuts. But I guess valve covers are involved too.
  12. TINK
    Nov 18, 2007
    788
    So Cal
    Poster worthy shot.
    bike41, mslim, PaulBarton and 5 others like this.
  13. TINK
    Nov 18, 2007
    788
    So Cal
    One of the things I've had to deal with are leaky valve covers.
    The covers are flat, the head is not.
    Usually a little Yamabond, ThreeBond, or Hylomar will do the trick.
    But I'm getting tired of cleaning off sealer every time I pull the valve covers.
    So, I tried a set of those silicone gaskets when I put on the peanut covers.
    Voila! No leaks, no sealer.
    I like it.
    tac650 and Solo Lobo like this.
  14. Solo Lobo
    Mar 16, 2004
    11,105
    Shoreline, WA
    I didn't want to admit it, given some of the folks around here... I'm running silicone valve covers on my RS and they have been working really well to stop the leaks I had before.
    Maybe these new versions are better than the ones from 110-20 years ago that didn't seen to work very well?
    TINK likes this.
  15. TINK
    Nov 18, 2007
    788
    So Cal
    I'm not familiar with these "cast" silicone gaskets. Where would I buy them?
  16. ME 109
    ME 109 Long timer
    Jun 25, 2009
    8,574
    Albury Australia
    Why has no one produced a valve cover gasket in between rock hard, and jelly? There must be a more suitable material or method that will prevent weeps. It would be a top seller.
    If the lh head is warped, the tightened front valve cover nut can lever the cover outward at the bottom.
    I'd describe warp on my R100 heads as..... flat on the horizontal centre line of the head, with the upper and lower forward sealing surfaces (ex valve area) pulled in towards the engine case. The rear upper and lower sealing surfaces are in line with the centre, so a flat surface.
    Uke likes this.
  17. korinthias
    korinthias Adventurer
    Apr 29, 2019
    51
    Devon, UK
    It would be really great if you could re-establish the links to the photos through this thread. I'm keen to travel this journey myself and would love to see, as well as read, all the twists and turns. Lovely bike BTW!
