PA Unpaved Roads
Discussion in 'GPS Tracks - Northeast, Southeast & Florida' started by MooseisLoose, Sep 24, 2014.
  1. MooseisLoose
    MooseisLoose Explorer
    Nov 29, 2013
    1,811
    Lehigh valley,pa
  2. Auto-X Fil
    Auto-X Fil Been here awhile
    Feb 17, 2013
    894
    Montrose, PA.
    I live right in the middle of the biggest red section. :-)
  3. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
  4. CannonsvilleRider
    CannonsvilleRider Been here awhile
    Aug 26, 2007
    822
    North of Cannonsville, NY
    Nice find!
  5. camaroz1985
    camaroz1985 Been here awhile
    Mar 12, 2009
    175
    Carlisle, PA
    Map isn't working for me :( Just see pink squares over the google map
  6. MooseisLoose
    Nov 29, 2013
    1,811
    Lehigh valley,pa
    try zooming in alot?
  7. TowPro
    TowPro Single Track Geezer
    Aug 21, 2009
    4,909
    A mixed blessing
    this map is not as accurate as they think it is. I know when I build the Trans PA Trail I used this as a source, but in some areas 50% or more of the roads they show as unimproved have now been paved.
    and they don't include the roads in the State Forest which is where you find the best unimproved roads.:D
  8. MooseisLoose
    Nov 29, 2013
    1,811
    Lehigh valley,pa
    I agree their are still a lot of dirt roads not on that map... But it's still a lot of potential unimproved roads to explore:thumb
    #8
  9. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
  10. pghchico
    pghchico n00b
    Aug 18, 2014
    6
    Pittsburgh, Pennsylvania
    apparently no one has shown this map to Garmin or my oregon 450 because it keeps taking me on dirt roads when i do NOT want to be on them ! and i have it set to avoid dirt roads.
    #10
  11. ride4321
    ride4321 Long timer
    Dec 21, 2009
    4,950
    Binghamton, NY
    Yep, we have it pretty good around here don't we?:clap
    #11
  12. MX2ADV
    MX2ADV MX2ADV
    Mar 14, 2007
    197
    Annapolis, MD
    Ask and ye shall receive. I just stumbled upon this thread; maybe someone still cares...I converted this data shown on the map into a single .gpx. It appears that the individual track segments are separated by county and sequentially numbered. The data appears to be from 2009 and is getting a bit long in the tooth if it has not been maintained. The file is BIG. I tested it in EasyGPS as well as Garmin BaseCamp without issue. Enjoy.
    https://drive.google.com/file/d/0Bz0bzPHRYw1MRUdObWowZ1d2V0U/view?usp=sharing
    #12
  13. JerryMac
    JerryMac Been here awhile
    Feb 18, 2014
    231
    Litchfield, Illinois
    In Basecamp you have a kind of yellow background. A town will have a kind of grey color. Once you load this file it will turn the whole state grey and even if you delete the file from basecamp the state of Pa stays grey. Does anyone know how to return it to yellow? I tried restarting the computer. This is with CNNA maps. You notice it when you zoom in a little on the state.
    #13
  14. MX2ADV
    MX2ADV MX2ADV
    Mar 14, 2007
    197
    Annapolis, MD
    Hmmm. I'm certainly not seeing this behavior with the out-of-the-box maps. Basecamp is slow as hell to work with the data due to the big file size. The track segments come into the map in gray and are placed in a list. If you delete the list from your library all of the many track segments get placed into a folder in your library named Unlisted Data (and still render on the map). Select all of the track segments in the Unlisted Data folder (click the first and hold the Shift key while you click the last) and delete them from that folder. That should clear your map. This takes a few moments due to the file size. I think all of the gray that you are seeing on the map are all of the many, many track segments. Hope this helps. Sorry that this file created problems for you but I can't replicate the issues you are seeing. Are you on the latest version of Basecamp?
    #14
  15. JerryMac
    Feb 18, 2014
    231
    I deleted the file completely off my computer. Perhaps it was like that before I loaded this file. I have the latest version of Basecamp. It only shows up when the state takes up the whole screen. Maybe it is just because of the sheer number of towns in the state or maybe it's just a fluke on my computer. Either way it's a minor issue. Try zooming in until the state takes up the whole screen and then the panning to see part of West Virginia.
    #15
  16. JerryMac
    Feb 18, 2014
    231
    I don't think what I am seeing has anything to do with this file. Now that I look a little closer Vermont does the same thing when I zoom in. Sorry for the confusion.
    #16
  17. ryder1
    ryder1 Long timer
    Nov 12, 2012
    8,025
    SEPA
    Hi TowPro, do you mind sharing the Trans PA Trail link?
    I just did a search and found it. Thanks for posting it!!!!
    #17
  18. CannonsvilleRider
    Aug 26, 2007
    822
    Hi TowPro,
    I have upgraded my map making skills over this long cold miserable winter. Do you have any interest in publishing your tracks in a format like this
    http://www.advcatskills.org/Maps
    #18
  19. dvs
    dvs Adventurer
    Apr 2, 2009
    23
    Mississauga, Ontario, Canada
    Mad skills CannonsvilleRider! Huge props, I followed the route across PA this week-end and it was fantastic!
    #19
    CannonsvilleRider likes this.
  20. ADVer
    ADVer Been here awhile
    Nov 29, 2006
    671
    Pittsburgh, PA
    I find the PA unpaved pdf and GPX files to be a great resource for planning my dual sport rides.
    I haven’t been able to use the GPX file in any practical way however.
    Ideally if one could convert the GPX to an IMG file, the IMG map layer would be perfect to overlay on a regular map.
    I believe there’s a program called IMGfromGPX by Javawa but do not have the skills or the necessary computer to use this older program.
    Anyone try doing this?
    #20
