    Dismiss Notice
Paint job, about paints (no powder coating)
Discussion in 'Old's Cool' started by Subutai, Jul 16, 2019.
  1. Subutai
    Subutai Been here awhile
    Nov 27, 2010
    556
    I have a hard tail frame that was fabricated for me to go with my old panhead motors.
    Called around and nobody seems to do powder coatings near my area and I'm not willing to gamble the frame to post, so good ol' wet paint it's going to be.
    A very old machine shop that does just about everything wants to know how I want it to be done and they use industrial epoxy or urethane paints, as they do industrial coatings.
    The frame is on bare steel so only the storage grease has to be washed off before painting. The color will be Ford black.
    Does it really matter what type of coating I use? We use epoxy coatings at work all the time but they are marine coatings. There's also a kind of language barrier as some case urethane and epoxy are meant the same thing.
    I don't want to do the frame again if I screw up this stage and I'm not planning on selling it either. The bike will be ridden so I would like the paint to be durable also. The sheet metal parts are not that important as the frame is a PITA to do again and it's not like I'm going to get another one.
    On a note the parts going to the bike will all be old, self made or refurbished save for bearings and such.
  2. rokytnji
    rokytnji Been here awhile
    Oct 9, 2018
    482
    Pecos Texas
    Amphib likes this.
  3. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    3,671
    Wnc
    I used to paint wheel loaders for kawasaki.
    We switched from epoxy to urethane because it's more uv tolerant and more scratch/chip resistant. The epoxy would get chalky from the sun, it's also harder, so rock chips would go straight to the metal.
    I personally would choose urethane.... (2 part)
    Mista Vern, chris a and 9Realms like this.
  4. haggzcycle
    haggzcycle n00b
    Mar 3, 2013
    5
    PPG polyurethane Essentials is the trade name. Two part system. nice gloss and tough as nails.
    Mista Vern likes this.
  5. Scrivens
    Scrivens Long timer
    Jun 5, 2011
    1,412
    usually the garage
    It's better to avoid powdercoat on vintage frames as it is hard to repair chips or scrapes, near impossible to remove if you ever have to go back to bare metal and it doesn't have the same clarity and lustre as the old paint or enamel finishes. Modern urethanes are excellent, and as has been said above, don't have the downsides of epoxies.
    bmwrench likes this.
  6. bmwrench
    bmwrench Long timer Supporter
    Nov 10, 2006
    8,140
    If that frame is new, you may want to bead-blast it to remove any scale, surface corrosion, and to improve adhesion.
