2010 Yamaha Super Tenere OEM parts. Original fork and shock springs Grab handles Engine guard Rear rack base Footpegs Gear lever Exhaust (not pictured) Pick up Toronto NSW.
Set of KLR650 Schnitz racing stainless inlet and exhaust valves. 38mm Inlets, 33mm exhausts. Free postage anywhere in OZ
Gone to a new home Hey guys Got a TKC 80 110/80-19 Less than 500 km on it. Was damaged on the bead when removed (obviously) by the apprentice, not sure if it will hold air as a tubeless. Pick up NW Sydney
For the sophisticated bmw rider On offer is a suit bag , to keep your bmw jarmies in , and free from creases ...
Holan lower and upper bars for CRF1000 DCT or manual AT. Lower bars is a straight bolt on and no brackets needed. Upper bars need a bracket on the right side and longer engine bolts (not included) You pay postage or pickup from Esperance (or I can drop off in Perth end of January) Obviously needs some paint and TLC, but mostly straight
Pannier rack frames in good condition. Minor surface rust, but will scrub off. Off a GS Beemer, but can't recall model. Pickup near Canberra/Queanbeyan. Also, if anyone has a Kawasaki Super Sherpa, I have a long-range tank mounting kit for an XR650 tank.
Oddball items... Hope they can be used by someone. Proprietary memory stick dohickeys for the (brilliant but old) Garmin 276c GPS (no idea if they also fit Garmin's other older models)... 256Mb standard unit (was a lot back then) and housing plus another bare 256Mb pcb / chip. The other 2Gb (upgrade) has the Russian (garminsch- sp?) chipset / pcb installed. No bugs, no secret infections / malware... Worked for me flawlessly over many years Enables more maps to be loaded up from your preferred GPS / Mapset etc. All work perfectly. Reason - I fcuked my old 276c whilst trying to replace the internal clock battery... These are now a memory of memories... You'll need to re-format them both as they'll have some of my old routes on them. Free to a good home, including Aus wide post :) Thanks!
Old Road Rider mags in good condition. Few other various bike mags there too. Pickup near Canberra (Queanbeyan area).
I have a BMW R1150 GS collector box and muffler, free to inmates In Sydney BMW R1150 muffler, https://www.gumtree.com.au/s-ad/wai...ampaign=socialbuttons&utm_content=app_android
54 pristine copies of the BMWMCCVIC monthly newsletter from November 2003-November 2008. That means 6 missing I suppose. Collection is best, from Croydon, Vic.
