Perfect Squeeze: Off-Road Phone Mount
Discussion in 'Vendors' started by Mondo-Hondo, May 10, 2016.
  1. StuartV
    StuartV Motorcyclist Supporter
    Oct 11, 2004
    2,999
    Manassas, VA
    I definitely don't get that. I have my Galaxy Note 8 mounted in the PS using the low profile handlebar mount, and it is solid as a rock (with just 2 or 3 clicks past where I can just flip/twist the phone into place in the holder).
  2. Gargantuan
    Gargantuan Been here awhile
    Jan 11, 2015
    445
    R1200GSW, iPhone X, no case - which setup would work best for me? Thanks in advance!
  3. cug
    cug Out riding ... Super Supporter
    May 31, 2009
    7,515
    Sunny California
    Received my low profile bar clamp today, bought because I was told here I could mount a RAM cradle to it. Sorry, no worky. It's useless for this. Wasted time and money and back to RAM mounts. So far, the whole endeavor, from the clamp to the actual mount has been less than stellar. Over-engineered stuff that's cumbersome and for some cases plain doesn't work.
    I'm switching back to a phone specific RAM mount for the phone as well, less cumbersome, faster, easier.
  4. KayDubbya
    KayDubbya Been here awhile
    Jul 26, 2014
    518
    @cug Sorry to hear that as it hasn't been my experience at all. The only RAM mount I've had any success with is their finger style mount and the side "adjustable" arms get in the way of something on the phone no matter what position I've put them in. The Perfect Squeeze on the other hand has been bomb proof since I got it. The addition of the Buzz-Kill mount solved the vibration/screen problem on both my big thumpers. I just came back from 2 weeks on pavement and off and had no issues. On my Husky, off road, a couple of clicks holds it tight enough no matter what sort of crash or bumps I'm dealing with and it still just lifts out with minimal effort when I'm done. My only regret is not having ordered the low-profile clamp when I originally purchased it (shipping to Canada is ridiculously expensive for a small item), but I solved that by mickey-mousing my own mounting plate.
  5. cug
    May 31, 2009
    7,515
    Sunny California
    That's good for you. I use these:
    https://www.rammount.com/part/RAM-HOL-AP18U
    They are great, there is no way a phone would come out, and it's super quick to use. I wasn't planning on using my iPhone X on the handlebars anyways, but use an old iPhone 6 for music and radar detector apps. The good thing there is that it also has TouchID which is much more convenient with a helmet on ... so, many benefits and I wanted to get rid on the Perfect Squeeze anyways.
  6. KayDubbya
    Jul 26, 2014
    518
    Thanks for that. Unfortunately without a Buzz-kill type adapter that mount would kill my phone from the vibrations in a couple of minutes. The trouble with singles I guess.
  7. cug
    May 31, 2009
    7,515
    Sunny California
    Possibly.
  8. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    3,465
    Long Island New York
    i too could pick my bike off the ground after a few clicks in any mode
    you may have something very wrong with your mount
    my phone and mount become one
  9. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,328
    395 miles South East of Orla, Texas
    I would call and talk with Mondo-Hondo. Something is wrong with your unit. My Perfect Squeeze and Big Squeeze are used on/off road on all three of my bikes using RAM ball mounts and cases for an iPhone 6 or iPad mini. No issues. I do use the vibration damper for phones on my 701 because it has some vibes.
  10. hennikerjd
    hennikerjd I am Jack's wasted life
    Jan 6, 2007
    1,187
    Idaho
    Something is wrong with yours or you've assembled it wrong, contact the vendor. I have one on my TX300 ridden in hard enduro terrain. I have full on body slammed the phone and it didn't come out of the mount.
  11. HandCanonShootr
    HandCanonShootr Been here awhile Supporter
    May 17, 2013
    559
    So. California
    My S7 Active is in a Pelican, and is gripped tightly with a perfect squeeze been there solid thru quite a few offroad adventures on my S10 (dirt-naps), as well as Freeway get-offs. Phone has never moved, sometimes my glasses or helmet rattled from rough terrain, but (as with prev S5 active/multiple cases) zero issues. Even pops off easily, and into pocket when leaving bike for service.
    I'll buy one again, if I forget to remove when I sell the S10.
    pretty sure its been almost 2 years.
    Mike B
  12. Chrismcp12
    Chrismcp12 Been here awhile
    Mar 9, 2013
    544
    iPhone 6 and a bodyglove case.... it's not moving.
    Sent from my iPad using Tapatalk
  13. karter18
    karter18 Been here awhile
    Mar 8, 2017
    283
    So Cal
    I have a GSW 2017 and have used the Perfect Squeeze with two mounts. I had a RAM X-Mount with the RAM ball mounted on one of the fork bolts. I used the perfect squeeze with their RAM mount adapter and it worked well. I did worry about theft so I ordered the Buzz Kill and mounted the Perfect squeeze handlebar mount with some adhesive closed cell foam to protect the handlebar finish this mounts to the Buzz Kill and then the Perfect squeeze. I put this on the right of the handlebar clamp and the phone is very visible and does not obstruct the gauges or NAV. I also run an adapter plug into the powerlet with USB's to charge the phone while riding. I think this set-up is more secure for the mount as my bike sits outside a lot of the day.
    One thing I like about the Perfect Squeeze is that it works much better than the X mount with the iPhone side buttons as you have a lot more leeway in how high you mount the phone.
  14. Zubb
    Zubb he went that-a-way... Supporter
    Sep 8, 2002
    3,795
    San Diego
    I noticed that when I use my 'naked' iPhoneX, it takes a few more turns of the knob to get it held solid. It felt like I was putting a ton of pressure on the phone to get it secure. When I put a case on the phone, it takes less cranking on the knob (less pressure) to get it solid.
    Probably because phones are pretty slick until you put a case on them.
  15. karter18
    Mar 8, 2017
    283
    So Cal
    It's like Apple made them really slick so that more people drop them and need replacements.
  16. StuartV
    Oct 11, 2004
    2,999
    Manassas, VA
    My Note 8 is pretty slick. I don't use any kind of case. I put it in the PS, tighten 3 clicks, and it is in there very solid!
  17. Zubb
    Sep 8, 2002
    3,795
    San Diego
    I may be a little overprotective, since the reason I bought the PS is my new iPhoneX flew off my X-grip at 70+mph recently.
  18. eakins
    eakins Butler Maps
    May 29, 2002
    38,512
    Fort Collins, Colorado
    Loving mine, incredible design & no vibs.
    Perfect to use Rever & Osmand on my bike.
    I put a ram ball & arm on the buzz-kill so I can quickly move to my other bikes, that have a ram ball mounted too.
    GAS GUY likes this.
  19. eakins
    eakins Butler Maps
    May 29, 2002
    38,512
    Oh this design clamps down like a gorilla.
    Much better than other ones I've used.
    The tappered grip arms and sticky rubber base plate is the key. Your phone pulls downwards in the base and then base plate keeps it from ever moving out sideways from the mount.
    You control how much tension your phone needs via the knob. Brilliant design!
  20. muddyrabbit
    muddyrabbit Lost Boy
    Aug 3, 2007
    4,016
    Fugawee Land.
    I have 2 of these, bought them when they first launched. Use them on the Tiger 800, KTM 690 SSAT, mountain bikes, and road bicycles. The grip is so tight you can lift my mountain bike by it.
    If someone is having a problem with a Perfect Squeeze not gripping a phone, or the clamp not gripping the bars they are most likely doing something wrong.
    Due to the fact I swap these between bikes quite often I needed a couple replacment screws and the portrait orientation adapter that was not included with the original units. Communication with Hondo was excellent, and they squared my order when they realized I hadn't actually ordered what I needed. Super helpful. I should really buy a couple more...
    karter18 likes this.
