Perfect Squeeze: Off-Road Phone Mount
Discussion in 'Vendors' started by Mondo-Hondo, May 10, 2016.
  1. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,364
    Charlotte, Vt
    That's cool. Charging is the red headed step child of phone use on the bike. This seems like a good solution except for how damn fat that puck is. Maybe, @Mondo-Hondo can supply these longer screws for some of us that don't have as skilled friends as you do? My perfect squeeze is one of the originals when it first came out. Hint hint
    AdamChandler likes this.
  2. Tortuga353
    Tortuga353 Been here awhile Supporter
    May 2, 2017
    365
    Well I didn't wait on answers and just went for it. I ordered the perfect squeeze with ram ball. Plan on using a gopro handlebar mount with ram ball attachment and shortest double ball ram arm. I did not get the buzz-kill, but I have insurance on my phone and if I burn one then I'll look into it more. I figure rubber around bar plus the ram balls will provide some dampening and I think I'll only use the mount for longer trips. I liked the gopro mounts because now I have camera, phone, and light mounting systems I can use and it is easy to find/3d print gopro mount devices. I also already have gopro mounts on all my bikes and helmets.
  3. Mondo-Hondo
    Mondo-Hondo Delusional, but very excited
    Jun 20, 2013
    295
    Bozeman, Montana
    We're working on an adapter for the MotoPowerPuck. Will bolt right on to an existing Perfect Squeeze. Sort of the same approach but no welding required :) Still in the testing phase but stay tuned:
    (gripper posts not shown in this image)
  4. AdamChandler
    AdamChandler Ascending n00b Supporter
    Feb 29, 2016
    7,806
    Hanover, NH USA
  5. Gildus
    Gildus Long timer
    Feb 5, 2012
    1,053
    Oregon Territory
    If you have a single cylinder bike, get the buzzkill...your phone will thank you.
    karter18 likes this.
  6. AdamChandler
    Feb 29, 2016
    7,806
    Hanover, NH USA
    My iPhone XS died after one 4 hour ride on my Beta 500 w/ just the Perfect Squeeze w/o the buzzkill. well died isn't true. The camera basically stopped working. $1200 phone dead so yes, absolutely true. the buzzkill is required for anyone on a single.
  7. Tortuga353
    May 2, 2017
    365
    Yep my phone died after a 4 hour ride. I confirm as well. Oh well guess I have to buy the buzzkill. I was trying to avoid it because I didn’t want the ~1.5” raise on the phone. Oh well I’ll figure it out.
    iPhone XS Max
    typeamark likes this.
  8. Tortuga353
    May 2, 2017
    365
    So I bought the Buzzkill and I'm just curious what my confidence level should be this will save my next phone? I'm using a go pro handlebar mount to a ram ball on a go pro base that says RAM on it. There is a decent bit of movement/oscillation with this set-up and I thought that movement would help absorb the shock but I guess it shook it to death. I believe this movement is due to the go pro mount ram ball not have a rubber plug to lock the clip like most go pro mounts. Will this Buzzkill resolve this? Do I have to change mounts..uggh at this point I should have just bought a dedicated GPS.
    I would just get the claw, but I want to be able to change orientation without tools and from what I see this requires changing the orientation of the plate.
    [​IMG] upload_2019-2-26_8-48-53.jpeg [​IMG]
  9. KayDubbya
    KayDubbya Been here awhile
    Jul 26, 2014
    462
    The Buzz Kill works. I have a 650 GS single and rode from BC to Flagstaff AZ and back with my phone in the PS w/BK. No issues. Without it my last phone had the camera stabilization system go bezerk and couldn't take photos.
    AdamChandler, karter18 and I82l8 like this.
  10. DutchTerror
    DutchTerror Been here awhile
    Aug 22, 2012
    485
    Channahon, IL
    Is the Buzzkill required if you're planning on using a RAM mount with rubber balls? I'm planning on running it mostly on my Goldwing, but it will get moved over to the XR650L and Super Enduro as needed. Thanks!
    ETA, Is Paypal not an option?
  11. KayDubbya
    Jul 26, 2014
    462
    Might be overkill if you're already using a RAM mount. A Goldwing doesn't suffer from the vibration that a big single does so you're probably fine. If you switch it to the XR you will need it though.
  12. blown7.3lps
    blown7.3lps Brian
    Jan 31, 2008
    693
    Dallas, TX
    ordered on the 9th, came in today :) 20190316_113554.jpg
    Ready to do some riding :)
  13. Gildus
    Gildus Long timer
    Feb 5, 2012
    1,053
    Oregon Territory
    High confidence...same vibration isolator wire-mount tech used to protect high end camera equipment during vehicle shoots.
    Tortuga353 likes this.
  14. karter18
    karter18 Been here awhile
    Mar 8, 2017
    271
    So Cal
    Buzz kill is $39.00 and new phone or fixing your phone is quite a bit more so I say go for it. I ordered it a while ago and it works great to still use the phone in the mount like to open my garage door, etc. I mainly use the phone on a GS but got the buzz kill to move the mount from bike to bike.
    KneeDrachen likes this.
  15. blown7.3lps
    blown7.3lps Brian
    Jan 31, 2008
    693
    Dallas, TX
    Is the buzz kill overkill for use on a 2008 r1200gs? So far I Mounting the tablet mount to the BK, then BK to the ram 1'' ball the phone has an a lot of play at the BK. Probably just safe with ram ball straight to the tablet mount or tablet mount to the low profile bar clamp? I want to protect my company phone, would rather not mess up the camera on it. S8+ in a Otter box currently. PS and tablet mount both hold the phone perfectly otherwise :)
  16. Mondo-Hondo
    Jun 20, 2013
    295
    Bozeman, Montana
    In general, the Buzz-Kill is not needed on most multi-cylinder bikes unless it's a model that happens to be known for excessive engine vibration. So you should be just fine without it on the BMW. Besides, the Buzz-Kill isn't rated for use with the Big Squeeze tablet mount or a tablet. Even if you just have a phone in the Big Squeeze, the mount itself is too heavy for the Buzz-Kill to properly damp. The Buzz-Kill was only designed to be used with the Perfect Squeeze phone mount. If there's enough demand for using a tablet on single-cylinder bikes, we might make one though :)
    bugzilla likes this.
  17. TrailDust&SaddleLthr
    TrailDust&SaddleLthr Been here awhile
    Nov 18, 2008
    639
    Southern Idaho, along the Oregon Trail
    Hi!
    I had emailed Adrienne a few months ago and suggested that the clamp be knurled on the inside, so it would have a teeth-like profile as to "bite" the bar, thus eliminating any rotating/slipping issue.
    Your thoughts?
  18. CBRNE
    CBRNE Adventurer
    Apr 29, 2010
    63
    Mondo-Hondo,
    Received the perfect squeeze and low mount. This is art and function.
    Davethestick and Mondo-Hondo like this.
  19. ternus
    ternus Been here awhile Supporter
    May 3, 2012
    191
    Mount Desert Island, ME
    @Mondo-Hondo Any idea when this will be available? It's exactly what I'm looking for.
  20. DockingPilot
    DockingPilot Hooked Up and Hard Over
    Mar 24, 2004
    11,463
    Andover, N.J.
    Im waiting on this next evolution of the Perfect Squeeze mount myself.
    surferbum likes this.
