Perfect Squeeze: Off-Road Phone Mount
Discussion in 'Vendors' started by Mondo-Hondo, May 10, 2016.
  1. surferbum
    surferbum Been here awhile
    Apr 25, 2010
    802
    Relocated to Scottsdale, AZ from SF Bay area
    Here's what Wiley told me -
    1. Remove the gripper posts if the post comes off the set screw, remove the set screw as well. Usually the post and the screw come off together. They're loc-tited on so you may need to use pliers, which is why the upgrade comes with new posts.
    2. Install the bottom adapter first (the one without the puck) by threading the two allen bolts preinstalled in the adapter into the now empty gripper post holes. We recommend a tiny amount of blue loc-tite on the screw. You can get an allen key in there without removing the new gripper posts. Just tighten them a little past snug, no need to make them extra tight. The larger radius curve goes toward the puck, the smaller radius toward the click wheel.
    Install the puck holder the same way.
    When wiring it up, the charger needs a 12v input. red is positive and black is negative (reversing the polarity can damage the puck). Don't cut off the small voltage reducer at the end of the cord. We recommend wiring this to an ignition-switched circuit so you don't drain the battery over time.
    Note- you need to remove this unneeded plate that is attached to the power puck.
    Brutalguyracing likes this.
  2. Mondo-Hondo
    Mondo-Hondo Delusional, but very excited
    Jun 20, 2013
    275
    Bozeman, Montana
  3. Power Band Junkie
    Power Band Junkie Son of a Novice
    Oct 6, 2008
    246
    North Brisbane, Australia
    I'm loving the perfect squeeze that I bought down-under, just wondering if this connection is plug in, or hardwired? I've had issues with plug in connections becoming sloppy and failing over time.
    Thanks again for a rock solid product. Over 30,000kms of abuse of my 950 and not once has my phone even looked like popping out.
  4. CoastieAM
    CoastieAM Been here awhile
    Sep 7, 2012
    184
    NoVA
    As the partner wireless charging tech I’ll hop in here. The nub you pointed out is a strain relief that is directly molded to the cable jacket. The terminals are soldered directly to the board and have withstood more than 35k miles in a year without the solder breaking. The new Juiced Squeeze is by far the most robust wireless charging mount out there!
  5. Power Band Junkie
    Oct 6, 2008
    246
    Fantastic, you were my next port of call if the HondoGarage guys were uncertain. Thanks very much.
  6. Fosters
    Fosters Loner
    Nov 6, 2010
    381
    florida
    Just received mine and mounted it up to my bike...didn’t hard wire it but went with a right angled Powerlet plug to the dash outlet...
    Wrapped the excesss wire around the tft and I’m good to go
    Thanks guys
  7. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,003
    Charlotte, Vt
    I hate being a whiner. Just feedback is all. Nothing more.
    I ordered a juicer for my perfect squeeze I've had since they came out. About 10min after ordering, I noticed the powerpuck guys offered adv 10% off, and emailed to ask if you'd credit that. Fair enough it seems.
    Never heard from you and juicer took 3 or 4 days to ship. It's here and all's well, but communication goes along way even if it's to politely explain that I can piss off:lol3
    Great product, and constructive criticism is all. File this where you see fit.
    Cheers:thumb
  8. srob3
    srob3 Grasshopper
    Oct 13, 2008
    50
    East Tn
    image.jpg I have used the perfect squeeze for about a year, functions well. I want to put it on the ural but the speedo is hard to work around. Do you have mounting suggestion?
    Sid
  9. Fosters
    Fosters Loner
    Nov 6, 2010
    381
    florida
    Ram ball mounted to handlebars left or right of speedo add 1” ram couple and mount up perfect squeeze
    WVhillbilly and JohnnyWaffles like this.
  10. DockingPilot
    DockingPilot Hooked Up and Hard Over
    Mar 24, 2004
    11,461
    Andover, N.J.
    Anyone else having trouble viewing their phone while in the Buzz Kill ?
    Mine wobbles so much Iit makes being able to navigate on the phone nearly impossible.
  11. TrailDust&SaddleLthr
    TrailDust&SaddleLthr Been here awhile
    Nov 18, 2008
    630
    Southern Idaho, along the Oregon Trail
    Zero issue for me!
  12. DockingPilot
    Mar 24, 2004
    11,461
    Andover, N.J.
    Thats good to hear.
    What phone you using and off road ?
  13. Tortuga353
    Tortuga353 Been here awhile Supporter
    May 2, 2017
    307
    I actually think mine is easier to read with the buzzkill. I used it without and my phone was basically blurry it was wiggling so much. The buzzkill seems to slow it down or absorb that motion to make a clearer image. Go pro to ram ball mount on with an XS Max for me. Better on or off-road.
    ** The go pro ram ball has some play so maybe that is a factor that helps since it is not as ridged like most mounts.
  14. Brutalguyracing
    Brutalguyracing Long timer
    May 15, 2013
    3,249
    Long Island New York
    What thread pitch are the bolts for the buzzkill mount
    I can say they are not 5x.08 x10
    Anyone
    Wish they would of come with 8 bolts to mount it
  15. Mondo-Hondo
    Jun 20, 2013
    275
    Bozeman, Montana
    The mounting holes are 10-32 thread. We supply two bolts for use with the diamond ram balls we sell. You can use the rectangular 4-hole ram balls but 4 bolts is overkill for mounting.
  16. Brutalguyracing
    May 15, 2013
    3,249
    Thank you
    Trying it with a good unit
  17. levain
    Oct 29, 2005
    10,003
    Charlotte, Vt
    Anybody using the juicer with a Galaxy S7 Active?
    Normally, I have to have the phone just so to miss the buttons on the mounting pegs. The juicer works great to keep the phone charged, but the only location has the power button fully depressed and under pressure from the arms on the mount. I don't know if this is going to cause any long term damage to the phone. @CoastieAM @Mondo-Hondo
  18. Tijuana_Taxi
    Tijuana_Taxi Been here awhile Supporter
    Jun 20, 2009
    808
    Boise,Idaho
    Would moving one of phone grabbing pegs to one of the open holes work? I had to do that with the Juicer for my old Motorola so it didn't push on the buttons.
    levain and Fosters like this.
  19. levain
    Oct 29, 2005
    10,003
    Charlotte, Vt
    Thank you for not making me feel like a complete idiot:lol3 IMG_20190629_073836.jpg IMG_20190629_073841.jpg
    Tijuana_Taxi likes this.
  20. CoastieAM
    Sep 7, 2012
    184
    NoVA
    BigMac75, levain and Fosters like this.
