Permatex rust treatment? Experience?
Discussion in 'The Garage' started by henrymartin, Oct 3, 2011.
  1. henrymartin
    henrymartin Mr. Tourguide no more.
    Sep 11, 2010
    3,853
    South of the Great North Woods
    I have a couple of spots I cannot really get to (frame points where metal overlaps, or inside a U-shaped bracket) to remove all the rust. Is the Permatex Rust treatment just a snake oil, or does it actually perform. I've seen it convert rust to a black surface, but is it permanent, or will it just continue rusting?
    Thanks for any opinions/experiences
  2. henrymartin
    Sep 11, 2010
    3,853
    I can't believe no one here used it.
  3. Tepi
    Tepi Been here awhile
    Feb 15, 2011
    544
    Helsinki/Heinola Finland
    Its same as annitrol, etc. Basically phosphoric acid which turns the iron oxide into iron phosphate. The surface it leaves behind is sorta like parkerizing, yes it will resist rusting, but its not "rust proof".
  4. sideshow
    sideshow debaser
    Aug 29, 2005
    2,778
    Waukesha (the only one)
    It works but like with any chemical treatment, it's all about prep.
    You have to brush off as much rust as possible, get the surface as clean as you can. Wire brushes, sandpaper, anything to get off what is loose or has started the corrosion. Loose rust that's flaking, or metal that is rusting through will have little hope. Surface rust is the best application for it.
    It works well on sheetmetal surfaces. I've used it on a truck's fender and it stood untreated beyond the Rust Treatment application for 2 Wisconsin (salty) winters. Considering the exploding rust problems on the Jeep Comanches, it's enough to convince me to buy stock in Permatex. :lol3
    For your application of rougher underbody nooks and crannies, I'd suggest looking into the POR15 products. They have a thicker coating made for the underpinnings of vehicles. Popular in this neck of the rust belt among car-guys for painting frames that have surface rusted during their project's build.
  5. henrymartin
    Sep 11, 2010
    3,853
    I figured it would work on the surface rust of the frame, then primed and painted properly.
    So, the results are good if it is covered with paint?
  6. groundrules
    groundrules Long timer
    Aug 3, 2007
    2,845
    Oh hiya
    I have, but not quite in the application that you are intending. I did it on a bicycle frame, and then I painted over it. I was told that this product would be a suitable primer as well. I used a brass wire wheel on my dremel for prep.
    Before:
    After:
    I don't think I took any pictures of these particular parts after I put on the touch up paint.
  7. henrymartin
    Sep 11, 2010
    3,853
    So, how did it hold up after you put on the touch-up paint? And, for how long?
  8. 9secondsflat
    9secondsflat Been here awhile
    Oct 4, 2011
    272
    RI
    I have used POR15...works fantastic
    #8
  9. groundrules
    Aug 3, 2007
    2,845
    Oh hiya
    Well, it's only been about six months since I did it and this bike lives indoors, so it might not be the most fair test. But it's holding up just fine. I didn't intend for this project to be a perfect restoration, just wanted to prevent surface rust from becoming worse or a structural problem. With that goal in mind, I think this worked out quite well and actually looks pretty damn good.
    #9
  10. Hipster
    Hipster Long timer
    Aug 31, 2004
    2,677
    Mpls, Mn.
    I've used it on the door panels of my '97 truck and it held up pretty well. I think your your application it should work great.
    #10
  11. P B G
    P B G Long timer
    Mar 7, 2008
    10,001
    Greater Chicago
    #11
