1. eNewsletter Sign Up
Perun rack 790 R
Discussion in 'Parallel World (790/890)' started by AKA HAL, Feb 8, 2020.
  1. KTM Freak
    KTM Freak Disgruntle Dirt Biker Supporter
    Sep 5, 2010
    64
    The Salad Bowl-Salinas, CA
    I’m running a Perun rack along with a Giant Loop Coyote and still have room for a dry duffle if needed.
    #21
  2. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    5,761
    Star Tannery, VA
    I was looking at this gif just now and recalled that I tried a few different combos of the spacers supplied when I installed mine. I ended up with the rack somewhere between the two height levels shown above. It did require cutting a bit off the long front bolts though. Ah well, I never have been all that good at following directions... LOL
    Tried to capture a photo with a similar angle for comparison.
    #22
    EvilSteve and TrailTrauma like this.
  3. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    2,858
    Protestlandia, OR
    Hey @Perun; I have one of your excellent racks that fit my 2018 690 Enduro. Will that same rack fit the 790? If so, do I need some additional hardware?
    #23
  4. Hornblower
    Hornblower Adventurer
    Nov 7, 2019
    96
    Clemmons, NC
    #24
  5. JohnRansom
    JohnRansom Been here awhile
    Apr 22, 2014
    118
    No. UT
    I also have the Perun rack, but did not eliminate the grab handles. On a longer solo ride I totally would, but my wife rides with me sometimes.
    #25
  6. JohnRansom
    Apr 22, 2014
    118
    No. UT
    Here is my top box solution. Im waiting for better weather to get more storage. It is a 26 inch Rigid toolbox bolted to the perun rack.
    With the car seat cushion strapped in place, the wife reports that the bike is much more comfortable.
    Edit- the box is 40 bucks and the back rest was a gift from a time when I jacked up my back. So total cost with the perun rack is right around 200. An incredible deal considering the cost of legit top boxes.
    #26
    JP4 and TrailTrauma like this.
  7. Perun
    Perun Been here awhile Super Supporter
    Mar 3, 2011
    770
    Belgrade, Serbia
    Hi! Nope, won't fit, very different racks/bikes. Thanks for 'excellent'! ;)
    #27
    BobcatSig likes this.
  8. Phil/TX
    Phil/TX Phil/TX
    Jul 24, 2004
    76
    image.jpg I dropped my bike in the driveway, landed on the Perun rack, and no damage, the rack was bent but not broken, saved the bike. After I ordered a new one my friend straightened it, so I painted it, and have it for sale, $100, plus shipping.
    #28
    Perun likes this.
  9. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    4,217
    Portland, Oregon
    Dang. My new one arrives Monday. Someone is going to get a deal.
    #29
  10. windblown101
    May 17, 2010
    5,761
    Star Tannery, VA
    That was an unlucky hit! No passenger pegs or did the rack hit a retaining wall on the way down?
    #30
    TrailTrauma likes this.
  11. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    5,034
    Ontario .. Superior
    Now that I think about it...bike usually hits the bar end first, then the tank bulbs. A number of times I have dropped my bike the wheels were up in the air, bar ends buried in dirt 4" and resting on the lower tank. Don't remember ever striking my rear rack area.
    The lovely thing about the bike resting on the lower tank, is it acts as an awesome point to rotate the bike (especially on hills where you want to be lifting the bike while standing UPHILL) so you can get it into an optimal lifting position. Other bikes I've had where I had to drop them to drag them under a chain between properties in the woods etc have been a bit more of a drag; literally. ;)
    #31
  12. Phil/TX
    Phil/TX Phil/TX
    Jul 24, 2004
    76
    The rack hit on concrete the handle bars on the grass.
    #32
  13. AKA HAL
    AKA HAL workin' on the noob thing
    Jun 6, 2006
    277
    Jacksonville, OR
    Just installed it. I've got a 2020 bike, and had to deviate from the directions on the website a little. Installing w/o subplate, w/o grab handles, I was bottoming out the M8x55 in the back, so used the M8x45 instead and it worked great.
    #33
  14. svneko
    svneko Adventurer
    Dec 12, 2011
    96
  15. Perun
    Mar 3, 2011
    770
    Belgrade, Serbia
    You did well, I just updated instructions.
    I hope all is well with the rack. If not, I would appreciate letting me know what's wrong, so I can sort it out.
    #35
  16. svneko
    svneko Adventurer
    Dec 12, 2011
    96
    Nothing wrong at all. From what I saw, it is top notch quality just like everyone says. I am just doing something different.
    #36
    Perun likes this.
  17. Kaoslash
    Kaoslash Adventurer
    Mar 19, 2019
    31
    France
    Is the rack compatible with the touratech adapter for top box ?
    #37
  18. Perun
    Mar 3, 2011
    770
    Belgrade, Serbia
    No, but it can be adapted. You would need to enlarge rear holes from 7 to 9 mm and to drill front holes.
    #38
    cwk and Kaoslash like this.
  19. V1Vr
    V1Vr just an average Joe
    Feb 9, 2008
    114
    49.2N 122.5W
    :super
    By the looks of it I ended up with pretty much the same thing. I used the middle sized spacer at the back and the tallest combined with the shortest on the front. I had to shim the back end by about 2mm to keep the rack off the tail plastic and the front by roughly 4mm to keep the rack perpendicular to the spacers so the bolt heads would have no angular shear force on them. I had to shorten the 75mm bolts slightly to avoid bottoming out.
    Perun did a fantastic job on this rack. I don’t think I’ve seen another that is as compatible with as many top boxes as this, nor as versatile. Attention to detail is outstanding as well. Not a sharp edge to be found anywhere on the rack. As someone wrote above, installation instructions and the blog found on Perun’s website leave no stone unturned. :super Perun.
    I think it’s sacrilegious to have a box like this on this bike but it comes in handy for urban riding/commuting when I need semi secure storage. The fact that I had the box from a previous bike factored into it as well. Mounting holes were perfect and the box is on and off in seconds.
    #39
    Flatroads, Perun, CaseyB and 2 others like this.
  20. MeVoGTC
    MeVoGTC Adventurer
    Nov 18, 2019
    79
    Maryland
    Did the rack come GIVI ready? I’m in the same boat with the same box....but haven’t figured what rack or if I would just sell the Givi and start over...
    #40
