Phone or GPS Unit?
Discussion in 'GPS 101 - Which GPS For Me' started by kderacing, Mar 2, 2019.
  1. flamingm0e
    flamingm0e Long timer Supporter
    Feb 21, 2017
    2,884
    Oklahoma
    I have devices going back 10 years. Some of them get updates. Some of them don't. When a developer decides to stop supporting a particular OS level, you don't get updates for that app. Just because it works today doesn't mean it will work tomorrow. It all depends on the developer and the app. I have less of a concern of the OS, though, and more about the hardware specs.
    If that device had 3+ GB of RAM, and 32GB of onboard storage (hell, 16 would be ok with expandable storage via SDCard), and a higher resolution, I could probably live with Android 6 for a couple of years.
    ohgood likes this.
  2. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,493
    NYC
    at this price ($150 shipped) id be ok buying a new one evertime they bumpbed the specs and they OS version :)
  3. PineLaneRider
    PineLaneRider Long timer
    Dec 25, 2016
    1,458
    Between Michaux and Tuscarora State Forests
    My daily use DFP has 3GB RAM and 32GB storage. I also have a 32GB SD card mounted.
    My GPS only DFP has 2GB RAM and 32GB storage. I have a 64GB SD card mounted for maps, music, and podcasts.
    Not sure of the resolution, but know it's better than my eyes can see...
  4. flamingm0e
    Feb 21, 2017
    2,884
    Oklahoma
    It's 1920x1080.
  5. worwig
    worwig Long timer
    Nov 30, 2009
    2,075
    Hog Mountain
    Too bad my overpriced Garmin devices all failed in some way, I might still be using them. But my phones just work and tend to be more rugged.
  6. Vanilo Petrucci
    Vanilo Petrucci Adventurer
    May 31, 2019
    61
    Belgium
    Just to be clear, because there seem to be different opinions on this: whenever a dedicated GPS device (such as Garmins and the lot) has satellite coverage, a smartphone with GPS function has the same, right?
    Let's not take ruggedness, battery life, ease of use, readability,... into account for a moment;
    it's not that riding in the Sahara desert with an iPhone or Kyocera for GPS is more prone to loss of satellite signal than a Zumo or other, thus inducing higher risk of getting lost?
  7. flamingm0e
    Feb 21, 2017
    2,884
    Oklahoma
    They all use the same satellites.
  8. worwig
    worwig Long timer
    Nov 30, 2009
    2,075
    Hog Mountain
    Yes, phones have GPS hardware. In fact, phones are usually made to be world wide. So by law in some countries a phone will use GPS and GLONASS satellites for location. Everybody benefits from the added satellites. That gives you a lot of satellites, and great accuracy. The same may or may not be true of a stand alone GPS.
    Where the issue comes in, is because it is so easy to pull up an online map like Google on the phone. And why not, they work well, and provide a lot of information. But you need to be on a cell (or wifi) to keep getting the maps as you move. But it is easy to install maps like OSMand beforehand and then not need the cell/internet connection.
  9. ohgood
    Sep 21, 2010
    10,245
    alabama
    record a track- that way no matter what map you've installed beforehand (or neglected to), you'll have a track and not be lost.
    the reception of gps signals is only reception. it's not two way communication line a cellular signal. that why smartphones have the OPTION of doing extra stuff, whereas the stand alone units don't. both the stand alone units and phones/computers/tablets wait and listen for the exact same gps pings. those points have very simple data that the phones/stand-alones use to determine location themselves:
    satellite location
    time of transmission
    the phone/gps uses that time-stamped ping, from multiple sources, to figure out where you are. all the cool math happens on the phone/gps so unless you are carrying a nice big backpack antenna, you'll not see a difference between them.
    one side note:
    if you're using Android, turn off "high accuracy"and change it to "device only"or "gps only". you'll save a ton of battery life and get better location info at the same time, all while not sending your location info to Google ;-)
    RTWstare likes this.
  10. Vanilo Petrucci
    May 31, 2019
    61
    Belgium
    OK, thanks all! Glad I can take that off my list.
    ohgood likes this.
  11. Vanilo Petrucci
    May 31, 2019
    61
    Belgium
    "record a track- that way no matter what map you've installed beforehand (or neglected to), you'll have a track and not be lost."
    That is actually good advice, never thought of it, thanks!
    "one side note:
    if you're using Android, turn off "high accuracy"and change it to "device only"or "gps only". you'll save a ton of battery life and get better location info at the same time, all while not sending your location info to Google ;-)"
    And this... Will try it next time around!
    ohgood likes this.
  12. Am.E
    Am.E Been here awhile
    Jan 4, 2012
    448
    NCNC
    FYI these settings are removed in the android 9 update. I discovered many complaints when googling how to set my new android 9 device to "gps only," and realized I couldn't, which is why I couldn't find those settings in the first place.
  13. flamingm0e
    Feb 21, 2017
    2,884
    Oklahoma
    They aren't removed. Just renamed.
    On one of my devices it's under
    Security and location
    Location
    Google location accuracy
    Turn it off and it will use GPS only.
    RTWstare, ohgood, jasiu and 2 others like this.
  14. ohgood
    Sep 21, 2010
    10,245
    alabama
    the simple stuff, like recording a track, is easy to neglect, while all this high flying map wizardry is happening.
    the Garmin guys figured out this was a good idea a long time ago, and turn on track recording by default when powered on
  15. jasiu
    jasiu Been here awhile
    May 6, 2015
    205
    Toronto, Ontario
    Looks like on different devices the option is call/access differently. On Samsung Galaxy S9+ with Android 9 the option can be turn off by:
    1. Biometrics and security
    2. Under Privacy click Location
    3. Under Location services click Google Location Accuracy
    4. Turn OFF Improve Location Accuracy
    ohgood, Got_Carbs? and flamingm0e like this.
  16. ohgood
    Sep 21, 2010
    10,245
    alabama
    they really want your location info for Live Traffic, Ads, and stuff ;-)
    robSTv and Albie like this.
  17. Ogre_fl
    Ogre_fl Long timer
    Oct 13, 2004
    5,276
    Cook Bayou, FL
    On my Galaxy S8 and J3 with Android 9 they dont have an option that cuts out the Mobile network (Ie Google).
    I only have the option to toggle WIFI and Bluetooth.
    My S8 looses GPS signal a lot.
    I dont use the J3 enough to know.
    So to answer the question if my S8 works as well as my Garmins, the answer is NO!!!
  18. PineLaneRider
    Dec 25, 2016
    1,458
    On my S8 it is just as @ohgood shows. I think you need to go one level deeper. Scroll down from "Improve Accuracy" to "Google Location Accuracy". That is where you can turn off the cell, wifi, and BT.
    ohgood and Ogre_fl like this.
  19. ohgood
    Sep 21, 2010
    10,245
    alabama
    when you find the settings that turn off cellular/wifi/Bluetooth/Google-reports and switches to GPS only, it will be much better.
    also, battery saving needs to be turned off, both system wide and application optimization.
    it wasn't like this on older android versions, they're trying really hard to convince people to
    a) report everything to google
    b) let the operating system control everything
    find the settings, and change them
  20. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    36,382
    Land of Endless Summer.
    Did you ever get GPS Status from the playstore, it sounds like your ephemeris data is jacked, I have literally a fleet of Samsungs from the S5 to S9+ and have never had an issue with GPS reception unless I was in a tunnel.
    Now as to your issues with the accuracy settings, you DO indeed have the option, I will show you with screenies from my android 9 device. They buried the shit out of it.
    From Biometrics and Security on the settings page Screenshot_20200229-094800_Settings.jpg
    Long press location
    From here your workflow forks
    Improve Accuracy allows you to toggle the wifi/bluetooth, you found that right?
    NOW tap Google Location History, which should look like this
    That is the toogle that you seek.
    Then go here https://play.google.com/store/apps/details?id=com.eclipsim.gpsstatus2&hl=en and download that, update your GPS cloud location, and make sure that you are receiving as many satellites as you should be.
    fierstf and ohgood like this.
