Playing with the chair
Discussion in 'New Zealand' started by Box'a'bits, Aug 29, 2015.
  1. Te Hopo
    Te Hopo Nomad
    Sep 25, 2007
    2,429
    Marlborough, New Zealand
    So maybe another cast wheel instead aye?
    At least this happened with just some bits and pieces in the chair instead of Mandy, not the sort of thing thing to encourage confidence
    #81
  2. Underground
    Underground unbefuckingbelievable
    Jul 29, 2008
    494
    French Pass New Zealand
    Or maybe a rear wheel, shorter fatter spokes because of the bigger diameter of the cush drive hub and the drive torque?
    #82
  3. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    4,329
    Wellington, New Zealand
    11 & 1/2hr round trip (including 2 fuel stops & a 1/2 hr lunch break at 4.00pm) to pick up the offending item, now safely tucked away in my garage....
    That is blue tint on the screen. It was pretty shitty weather...The Subaru achieved a new low of 5.27kms / litre of fuel. Heavy car transporter trailer, ramps that fold straight up into the air, & massive winds.
    #83
  4. Muzz67
    Muzz67 Unadventurous
    Dec 6, 2013
    776
    Brightwater,New Zealand!
    Hope you wasn't texting while driving,,,
    #84
  5. bart-nz
    bart-nz Been here awhile
    Dec 7, 2008
    983
    New Zealand
    So that’s about 19 litres/ 100 km? Boxer engine I take it? Legend...
    #85
  6. Padmei
    Padmei enamoured
    Mar 12, 2008
    4,113
    Nelson New Zealand
    Would you consider arrying a spare wheel with you ? i think I've seen a few on hakks.
    #86
  7. Box'a'bits
    Sep 26, 2008
    4,329
    Some sidecars are set up so that all of the wheels are the same size. But this one has different sizes tyres all round, albeit that the BMW is on 18" wheels. Ideally I'd replace the sidecar wheel with an 18" BMW cast wheel. But that would require considerable modification to the guards, axle etc to achieve.
    I'll probably replace the sidecar wheel this time with a 17" cast one, which should just fit under the existing guard.
    I have a spare for the rear on the tug, to accomodate muddy conditions. At the moment the chair frame isn't set up to take a spare though.
    #87
  8. Manakau.KTM
    Manakau.KTM Been here awhile
    Mar 3, 2012
    857
    Horowhenua NZ
    Could look like something out of Hogan's Heroes
    #88
  9. Padmei
    Padmei enamoured
    Mar 12, 2008
    4,113
    Nelson New Zealand
    I know nuffing!!
    #89
  10. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,537
    New Zealand
    My Ural/VW had a Jupiter chair, not the same wheel as the Ural, but still built for purpose. My JB chair had a Jawa wheel, which is a bit strange as they were built using a BMC 1100 trailing arm, hub and wheel, I remember seeing the prototype chassis being built. Mine was the first JB chair sold, and the customer specified a spoked wheel, I got it at a couple of years old. Another couple of sidecars with trailer hubs and Mini wheels. You really need something built for side thrusts.
    The JB child/adult chair and Jawa wheel you can hardly see. Eldest daughter at a few weeks old....we are all still alive despite living dangerously. The shed is still there, I'd like to think the other stuff is still out there somewhere.
    #90
  11. Mark_S
    Mark_S Fair Weather Faggot
    Jun 13, 2007
    2,652
    Kapiti NZ
    so no camping trip this weekend?
    #91
  12. Box'a'bits
    Sep 26, 2008
    4,329
    Yup, still going. Just on Gus. You keen for a spin?
    #92
  13. Mark_S
    Jun 13, 2007
    2,652
    Kapiti NZ
    have you already gone?
    I was planning going for a ride on Sunday - prolly popping in and seeing how heathens spend their holiday time
    #93
  14. Box'a'bits
    Sep 26, 2008
    4,329
    Replacement sidecar wheel, 250/16 (front wheel). 100/90 16 front tyre(?). Fairly cheap. Looks strong enough.
    It's from a ('88?) Honda VFR400 NC24, so contemporary with the sidecar at least :eek7, albeit not quite in the same performance ball park. Comes with an old Metzler, so no need to get anything in (yet) to fit. Don't need to run anything aggressive on the sidecar wheel. Just something round & black. Tyres may be an issue in a few years, but...
    Runs 20x42x12 bearings, so off Monday to get a new 20mm axle put in the sidecar swing arm to replace the (known to be weak) current 15mm one, as well at to get new 12mm bushes made up so I can fit the progressive shocks I bought a few weeks ago.
    I wanted a 17" cast wheel, but had issues getting an appropriate one with enough meat in the hub to allow the bigger axle.
    So are you saying you won't want it back after I've finished improving it for you?
    #94
    Te Hopo likes this.
  15. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,246
    I used a Suzuki FXR150 17" rear wheel on my side car.... I replaced the 17mm bearings with 3/4" (19.05mm)
    straight swap no machineing needed....
    #95
  16. Left Testicle
    Left Testicle Been here awhile
    Jun 14, 2013
    446
    New Zealand
    I think the thread of this should be changed to eg. "Glutton for punishment". Anyone else got some suggestions. 'once bitten twice shy. '
    #96
  17. Box'a'bits
    Sep 26, 2008
    4,329
    Did look at an RG150 rear....
    #97
  18. Manakau.KTM
    Mar 3, 2012
    857
    Horowhenua NZ
    I have some spare wheelie bins for soaking the willow
    #98
  19. Box'a'bits
    Sep 26, 2008
    4,329
    Your photo went away...
    Progress on the chair. Collected the new axle. Stepped 25mm & 20mm. Press fit into the swing arm, but with a nyloc nut on the inboard end as a 'belt & braces' locator. Much sturdier than the weedy 15mm it replaced. BTW that was bent...
    The wheel has been milled out to take the 25mm ID bearings on the swing arm side, & 20mm on the outside. The bearings are 6005 (25x47x12) & 6004's (20x42x12) respectively. The wheel needs a clean & repaint. It's been powder coated before & that's starting to bubble.
    The new wheel looks nice on the new spindle, but maybe has been spaced slightly too far out on the axle for the existing guard. I may need to have this tweaked.
    I seem to have fallen in with the progressive shocks (412s). These don't fit into the swing arm because:
    1. The shock base is too fat. I might have managed around this but:
    2. The bottom shock mount pivot point is offset for the Hardley swing arm shock mount.
    Boo. I'll need to rethink this.
    By the way, to keep his wife happy, some plonker has sold front & rear GS wheels on Trademe to pay for some of this.
    #99
    Te Hopo likes this.
  20. Underground
    Jul 29, 2008
    494
    From the looks of that serious engineering upgrade I am seeing off roading in your future.
    kiwibul likes this.
