Playing with the chair
Discussion in 'New Zealand' started by Box'a'bits, Aug 29, 2015.
  1. ztaj
    ztaj jatz
    Jul 22, 2008
    1,341
    Nelson-ish New Zealand
    I thought it'd be a couple of hours, I'll give it 2:15, I don't want to rush :D
  2. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    4,432
    Wellington, New Zealand
    REPLACEMENT BRAKE LINES:
    The stock BMW R80 mono (TIC) brake lines are routed as:
    • A single brake line from the brake master cylinder down to behind the right fork leg:
    • A steel line from the back of the fork to the right front caliper:
    • A steel line that loops from the right front caliper to the left front caliper. This runs under the front guard, & when new sits in an indent in the front guard, just in front of the fork brace.
    To change tyres, both calipers need to removed & the lines spread. Over time this distorts them. My concern with the loop line has always been the potential for this to be taken out by larger road debris. As it happens, the line has distorted on the tug, & worn. You can see the split in the line in the attached photo. Fortunately this occurred in the garage, when I was changing tyres.
    I have replaced all of the lines with new stainless brake lines. They are in the front of the wheel because the guy that made them up was concerned at the routing to get them behind the forks. I’ve made up some brackets to stop the lines from fouling on the gaiters.
    The front tyre has been changed from a Mitas H06 350/18 (which I found good) to a Shinko (Golden Boy) SR 244, 350/18. Purchased on Tme for $10, new. Looking for better front end grip in loose stuff. Looks like it'll wear flat, which is good for sidecar stability. I'm staying with the front guard & brace combo for now.
    Te Hopo likes this.
  3. Box'a'bits
    Sep 26, 2008
    4,432
    Found over on the Hacks forum. Well worth a watch...
    Those WWII bikes are getting up there in price, so there is a fair dollar value being thrashed in this video
    Night Falcon likes this.
  4. Box'a'bits
    Sep 26, 2008
    4,432
    So I've started cleaning the sidecar up for my brother wedding.
    Painted the rear mudguard. That'd suffered from years of wear under the seat. Once the stickers came off, & I sanded it back, it came up really well with some Duplicolor bumper paint.
    Also painted the starter cover & the airbox. The timing chest will need to wait until I've got in gaskets.
    The headers had developed some holes from wear & rust. Yesterday I attempted patch weld these using pipe off my old RS (40mm over 38mm pipe). What is it about exhaust welding that causes the weld to break thru into the pipe you are welding just as you finish the last weld? Not proud of the repair, but it's only temporary anyway.
    The headers looked a little sooty, but the spark plug says the bike is running right.
    The headers needed painting (the chrome was shot years ago). Good job Mandy was dress shopping with Katherine. What funny smell dear? Must be that soup I made you.
    https://goo.gl/photos/Q5EzCBnErVkkLqBA9
    And the award for the over use of silicon in the worst possible places goes to...
    The head gasket & pushrod seals on the right side had been leaking enough to annoy me, so I have replaced them. There was red silicon everywhere when I pulled the heads & barrels down. I don't recommend the over use of RTV, & certainly not on the pushrod seals. I am concerned that that goop may have gone thru the oil passages.
    A light smear on the base of the barrels is fine.
    The good news is the barrels looked nice. The valves aren't recessed (but I didn't pull the valves to look at guide clearances). The pushrod tubes look to be good stainless ones under all the goop. The cam followers surfaces looked good. But a peer down at the cam showed faces that looked like they may be a little pitted.
    I haven't done the left side. Not leaking as much, & I need new barrel & stud o'rings, & another head gasket.
    The exhaust has been a pain to seal up, in part because of where I've put the patch. We'll see how that goes. I have gooped the left header / collector box joint with hi-temp RTV to help that seal.
    Te Hopo likes this.
  5. Padmei
    Padmei enamoured
    Mar 12, 2008
    4,114
    Nelson New Zealand
    Worried she may be looking over your shoulder???:lol3
    Nice oven BTW
  6. Box'a'bits
    Sep 26, 2008
    4,432
    Yes.
  7. Muzz67
    Muzz67 Unadventurous
    Dec 6, 2013
    907
    Brightwater,New Zealand!
    Don't get caught with engine parts in the dish-washer.
    That doesn't end well..........
  8. innathyzit
    innathyzit AKA Woodman
    Dec 30, 2008
    2,627
    Nelson NZ
    or using the oven to heat up cases so the bearings can come out easier.
  9. wairau
    wairau get in behind!
    Mar 29, 2011
    3,771
    Urenui, Taranaki
    or using the measuring bowl to pour out 200ml of 2 stroke.
    that doesnt end well either.
  10. dazzadm
    dazzadm Long timer
    Jun 7, 2014
    1,707
    Gumboot Capital, NZ
    Or buying another bike with out asking first....
    That's still not going well :dirtdog:(
    Te Hopo, wairau and Box'a'bits like this.
  11. Voltaire
    Voltaire Titanium and Ceramic Hipster
    Jun 4, 2011
    2,590
    Auckland,New Zealand
    Doing that to a poor old WW2 bike is a bit harsh, I thought that's what Urals, Cossacks and Dneprs were for.
  12. bart-nz
    bart-nz Been here awhile
    Dec 7, 2008
    987
    New Zealand
    We've got the same oven. New bottom element turned up last week, which I ordered in NOVEMBER!!!
  13. innathyzit
    Dec 30, 2008
    2,627
    Nelson NZ
    The bottom element in my oven failed 5-6 years ago. Did you know you can still cook a roast on grill?
  14. Box'a'bits
    Sep 26, 2008
    4,432
    We're doing most of our roasts on the BBQ anyway. All it needs is a still-ish day. The gas seems to keep it moister.
    So did it go out for a frame straighten, or has that been re-prioritized...
    Doing an oil change with the roasting dish doesn't do a fledging relationship much good either (tried that in the early years). I did try to explain that it'd be all good after a thorough wash.
  15. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,856
    New Zealand
    So you had some left over after the last pushrod tube repair?...?:-)
  16. dazzadm
    dazzadm Long timer
    Jun 7, 2014
    1,707
    Gumboot Capital, NZ
    Should be going up for frame straightening this week. I got a front wheel from UK so the build has started...
  17. Box'a'bits
    Sep 26, 2008
    4,432
    Yup, scraped it off the pushrod seals, barrel & engine case & reassigned it. Recycling at it's best. :eek7
  18. Box'a'bits
    Sep 26, 2008
    4,432
    A couple of photos from my bro's wedding over the weekend...
    Te Hopo likes this.
  19. Mark_S
    Mark_S Fair Weather Faggot
    Jun 13, 2007
    2,657
    Kapiti NZ
    they both look resigned to their fate....
  20. Box'a'bits
    Sep 26, 2008
    4,432
    Took a bridesmaid for a spin in the chair, down a hill to a paddocked area where they were to take more photos. Took the opportunity to do a few donuts & fly the chair with her in it. I noticed she wasn't keen to have another go when it was time to go back up the hill...Not sure why :hmmmmm.
    There were a few off these there, wanting to eat the bridal bouquets, which provided additional entertainment.
