PNW Flea Market
Discussion in 'Pacific Northwet - Where it's green. And wet.' started by DantesDame, Aug 25, 2008.
  1. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    4,405
    Clark Co, Wa
    I've got 2, probably 3 Arai helmet bags for you. Message me.
  2. TCSmith
    TCSmith Adventurer
    Jul 16, 2009
    28
    Sammamish, WA
    For Sale: 2015 Triumph Tiger 800 XCX
    Seattle, WA
    Inmate price: $6,800
    Adventure-ready 2015 Tiger 800 XCX. The very best of the middle weight adventurer bikes. This Tiger has devoured everything from sand, gravel, snow, and pavement without a hitch. A few cosmetic battle scars (see photo). This is no garage queen but has been meticulously maintained with all factory recommended services up to date. Full 30k service performed by Cascade Moto in Portland. All service records available.
    This bike comes with a strong pedigree. I am the second owner. First owner purchased the bike from Cascade Moto in Portland, OR and customized it for serious touring with an Arrow exhaust, Touratech suspension, and more (full list below). It's seen the back roads and trails of California, Nevada, Utah, Oregon, Washington, and is ready for more.
    Mileage: 35,273
    Accessories:
    Touratech Adjustable Suspension (installed by Konflict Motorsports & Suspension)
    Arrow slip on exhaust and fuel map
    Fastway Adventure Foldable Pegs
    Factory heated grips
    Alt Rider brake plate
    Barkbuster hand guards
    Touratech headlight guard
    Touratech handlebar risers
    ADV Rider Marketplace ad:
    https://advrider.com/f/threads/2015-triumph-tiger-800-xcx.1461153/
  3. Cycle_Path
    Cycle_Path Been here awhile
    Jan 1, 2012
    858
    North Bend, wa
    72616D8A-F969-4AB5-A37F-800413DCDAB8.jpeg Have a new baja no pinch tool if someone is interested. $80. Located in north bend-sold!!!!!!!!
  4. TheMuffinMan
    TheMuffinMan Forest Ranger Magnet
    Mar 31, 2010
    9,462
    Coeur d'Alene, ID
    ****SOLD****
    Selling my 2003 DL1000 V-Strom. Located in Coeur d'Alene Idaho but bike is still titled in Colorado where I recently moved from. $2000. 68,839 miles going up slightly as I commute to work on it. Clear title in hand.
    Extras:
    Happy-Trail SU racks and Owhyee 9" hard cases powder coated black and Locks keyed alike.
    Jessie top box - fits most L helmets and smaller.
    Aftermarket aluminum skid plate - beefy, unknown brand.
    Givi Crash Bars
    SV Racing Parts Super Brace (fork brace)
    2" Extended stainless braided brake, and clutch lines
    Stainless braided rear brake line
    2" Pivoting rox risers
    Mirror extenders
    1" RAM mount on top of steering stem - great for mounting GPS
    Voltmeter (reads 0.4v low due to wire run length from the cockpit to the battery)
    Shindengen Series MOSFET regulator w/Eastern Beaver wiring harness with a relayed 12v fan for extra cooling in slow traffic.
    Headlight cutoff switch w/eastern beaver wiring harness and relay kit
    Heated grips (needs new switch)
    Switched fuse block under seat
    Dynojet PC-V
    Sasquatch re-valved and resprung rear shock setup for a 225 lb rider.
    Straight rate fork springs setup for 225 lb rider
    LED brake light
    WORKS clutch basket upgrade
    Zero Gravity Sport Touring smoked whindscreen (cut down stock also available)
    OEM Center stand (not installed on the bike)
    Unswitched 12v SAE battery tender pigtail
    Recent Maintenance:
    New clutch slave 8000 miles ago
    New linkage bearings 3000 miles ago
    Stator rotor magnets fixed 4000 miles ago
    New aftermarket stator 4000 miles ago with the rewound stock stator in a parts bin.
    Front wheel welded and trued after a crack was found by Woody's Wheel Works in Denver, CO.
    New front wheel bearings 3,000 miles ago
    New chain and sprockets 8,000 miles ago (+2 tooth rear) cruises at 75-80+ very nicely.
    Valves last checked at 60k miles all within spec
    Needs:
    Could use a throttle body sync.
    Air filter changed 3,000 miles ago
    Could use an oil change within 1000 miles or so.
    The PCV map could be tuned for better performance but it's good enough. Fuel mileage is 40-43mpg on average.
    Tires are cupped a bit and need to be replaced soonish (I have brand new set of Dunlop Trailmax Mission waiting installed. You can take the tires for an extra $150 (the pair were $331 from RMATVMC).
    Steering head bearings need to be tightened.
    L hand bar-end weight fell off a few thousand miles ago on a super washboarded out road.
    Some cosmetic issues but nothing major, commensurate with the mileage. It's not a garage queen.
    The bike runs great! It's well used but it's a great bike with plenty of life left.
    Pictures to follow.
    IMG_20200809_182502.jpg MVIMG_20200809_182405.jpg IMG_20200809_182320.jpg IMG_20200809_182314.jpg
    OR_Rider likes this.
  5. TheMuffinMan
    Mar 31, 2010
    9,462
    Coeur d'Alene, ID
  6. Motofett
    Motofett Adventurer
    Nov 8, 2019
    18
    Woodland wa
    Great running bike, with lots of upgrades, heated grips, abs, Mr. Ed's moto seat, Ortlieb saddle bags, BMW top hard bag, 2 spare windshields, fresh oil change, new iridium spark plug, new O2 sensor, new fuel filter..ready for years of fun..Think of it as a KLR but good. 50 hp and a few lbs lighter and low seat height
    68k miles
    Asking 3k located in woodland wa 20200808_151842.jpg 20200807_164138.jpg 20200806_154158.jpg 20200805_180231.jpg 20200805_180224.jpg 20200805_180219.jpg
  7. Motofett
    Motofett Adventurer
    Nov 8, 2019
    18
    Woodland wa
    2001 BMW F650 GS ADVENTURE
    ASKING 3K
    located in woodland wa 20200808_151842.jpg 20200807_164138.jpg 20200806_154158.jpg 20200805_180231.jpg 20200805_180224.jpg 20200805_180216.jpg
    shrubitup likes this.
  8. Motofett
    Motofett Adventurer
    Nov 8, 2019
    18
    Woodland wa
  9. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,534
    north of seattle
    FS Fastenal organizer
    34 wide
    42 tall
    12 deep
    real solid unit
    $30
    located in the Bothell, Lynnwood area
  10. FLYING EYEBALL
    Mar 18, 2008
    12,534
    north of seattle
    FS Torin Big Red stools
    2 brand new in the Box
    $30 for the pair
    In the Bothell, Lynnwood area.
    Guano11 likes this.
  11. FLYING EYEBALL
    Mar 18, 2008
    12,534
    north of seattle
    FS Gearwrench metric ratcheting wrenches 10,12,13,14,15
    $50 for the 3 sets
    Watercat likes this.
  12. Sedro Tom
    Sedro Tom No hurry, no worry Supporter
    Jul 9, 2008
    2,990
    NW WA.
    SOLD--SOLD--SOLD
    Heavy-duty bike or motorcycle carrier designed to carry 250 lbs. with ramp, the width of carrier rail is 5 in.length of carrier rail is 62 in. , length of the ramp is 60 in. Made for scooter 250LB. max. Would work fora small motorcycle, trials bike, or as a gear hauler.
    [​IMG][​IMG][​IMG]
    $ 80
  13. soyanarchisto
    soyanarchisto Long timer Supporter
    Sep 1, 2005
    6,758
    Sunny PDX
    gone
    Baroquenride likes this.
  14. DHedeen
    DHedeen n00b
    Aug 11, 2020
    1
    Beaverton
    I am interested in looking at your BMW, Do you have time this week in the evening? My email is dan_hedeen@yahoo.com if you could send me your contact information. I will be coming from Portland.
    Dan
  15. Motofett
    Motofett Adventurer
    Nov 8, 2019
    18
    Woodland wa
    Messaged your email
  16. Motofett
    Motofett Adventurer
    Nov 8, 2019
    18
    Woodland wa
    Messaged your email
  17. Stinky
    Stinky Team Hematoma
    Mar 12, 2006
    564
    NW WA
    Gerbing Heated Gloves- WOMEN's size L. Dudes need not apply unless they're buying for a woman. They ain't gonna fit your nasty man hands.
    Used twice and in like new condition. $75 and local pickup in the Mount Vernon area. PM if interested.
  18. One Fat Roach
    One Fat Roach honey badger
    Mar 23, 2013
    2,326
    Washington
    Looking for some used boots, youth 6 or 7. Within an hour of Marysville. Driving to Gifford this weekend so could pickup along the I-5 corridor friday evening or sunday afternoon as well. PM me with anything you need gone
  19. RCTID
    RCTID Been here awhile
    Oct 16, 2012
    230
    Beaverton, or
    Sold
    2016 Starcraft AR ONE 17XTH toyhauler (21' overall length)
    Meticulously cleaned and maintained.
    This is the model with the queen tipout bed(and standard front bunks) which is very hard to find.
    Excellent small toy hauler for those of us who dont like big giant campers.
    -Will sleep up to 6 adults - Queen size tipout, full size lower bunk, single on top bunk, and couch folds flat.
    -New this summer - Dual 6V battery setup and Renogy 200W solar kit - Ive camped for almost a week in partial overcast and stayed at about 12.5-13 volts the entire time. Great for dry camping.
    -All 3 tires are nearly new
    -Dual propane tanks
    -Electric tongue jack
    -Electric awning
    -Will fit 3 dirtbikes or one quad(maybe a bike too - ive never hauled a quad in it)
    -Rooftop air conditioner
    -dvd/cd player with interior speakers
    -Full bathroom with shower
  20. Teufel Hunden
    Teufel Hunden Cannon Cocker
    May 7, 2019
    185
    PNW
    Bought a GSA. Looking to sell or trade my '17 1290 SAR. Prefer to trade for a KTM 350 or 500 exc or Husqvarna Fe 350 or 501. I will consider other trades for a plated dirtbike. Asking $11.5k. PM for details.
    soyanarchisto likes this.
