"Poor Man" - Phone/GPS Cradle + Mount KIT - Show your project
Discussion in 'GPS 101 - Which GPS For Me' started by ygal, Jun 22, 2017.
  1. ygal
    ygal Adventurer
    Jul 21, 2014
    63
    South New Jersey - Not far from Philadelphia
    I was looking around this site, trying to find information / examples of non-standard (out of the box), phone or GPS cradles and while was able to find here or there, some pictures / examples - I thought it may be good idea to start a new discussion, in which readers will be able to present their projects and share their ideas / direction how to build a cradle that fit their unit.
    So let me start with my work (I assume it will help if people will use the following template) :
    Phone / GPS Model: Kyocera DuraForce XD + Protech Case (Great information about this phone in the following discussion : http://advrider.com/index.php?threads/ultra-rugged-kyocera-phones-gps-smartphones-my-guide.1206076/)
    Material used: Bought few pieces of aluminum parts in Lowes (Deck Connectors) + Ram mount ball (which I disassembled from a Garmin cradle) + Motorcycle Ram mount kit
    Cost:
    ~$10 (for the Aluminum parts - I have used for the cradle)
    Tools: Vise to bend the Aluminum (building the cradle - Could actuality do it in the store :) ) + Drill + Metal saw
    Difficulty: Easy, As much as I am non technical guy, I worked on it ~ 2 hours, mostly as I didn't planned the work before, just tried to build it on the fly
    Remarks: Still need to install the charger which I'm planning to do using a Pogo connectors (See the link about this phone - seems that it is not difficult to install the right charging to the connectors on the back of the phone)
    Pictures:
    Material - After bending.
    Kit after finishing the assembly :
    20170620_143317.jpg 20170621_164041.jpg 20170621_164058.jpg 20170621_164105.jpg
    ohgood likes this.
  2. ygal
    ygal Adventurer
    Jul 21, 2014
    63
    20170621_164122.jpg 20170621_164233.jpg 20170621_164311.jpg 20170621_164329.jpg
    ohgood likes this.
  3. ygal
    ygal Adventurer
    Jul 21, 2014
    63
    Access to the charging connectors
    ohgood likes this.
  4. ygal
    ygal Adventurer
    Jul 21, 2014
    63
    20170621_164757.jpg 20170621_164811.jpg 20170621_165123.jpg Full access to the phone Buttons
    ohgood likes this.
  5. ygal
    ygal Adventurer
    Jul 21, 2014
    63
    Installed on my Motorcycle :
    20170622_135825.jpg 20170622_135839.jpg 20170622_140315.jpg 20170622_140337.jpg
    ohgood likes this.
  6. ygal
    ygal Adventurer
    Jul 21, 2014
    63
  7. cyberdos
    cyberdos Easy Bonus Loop ♦♦
    Sep 2, 2005
    48,517
    Queen Creek, AZ
    :lurk
  8. cyberdos
    Sep 2, 2005
    48,517
    Queen Creek, AZ
    so...for those that don't mind
    heavy duty velcro works fantastic to keep these units put. Simply place a strip or two on the back side of the phone like so (don't have the cradle with me to show strips on it):
    It makes a huge difference and you barely need anything on the sides to keep it in place.
    #8
    ohgood likes this.
  9. DaMonk45
    DaMonk45 I B Da Monk
    Apr 26, 2009
    3,161
    Texas
    careful which velcro you use...if you use the industrial stuff you may never get your phone lose.
    #9
    ohgood likes this.
  10. BigChuck
    BigChuck Been here awhile
    Dec 28, 2014
    278
    Gloucester, Va
    #10
    ohgood, Suncoaster and ygal like this.
  11. Suncoaster
    Suncoaster Long timer Supporter
    Jul 7, 2015
    1,277
    Where the girls are green and the grass is pretty.
    A couple of brackets ($5) an old handlebar, a hacksaw, some paint and a $6 ebay GPS case:
    With "Glove Mode" turned on, the touchscreen on the 6" Asus mobile works with gloves through the clear plastic of the case.
    [​IMG][​IMG][​IMG]
    #11
  12. cyberdos
    Sep 2, 2005
    48,517
    Queen Creek, AZ
    perfect! :lol3
    yep. Just one little strip of this stuff and it will hold on TIGHT!!
    #12
  13. ohgood
    Sep 21, 2010
    10,030
    alabama
    I really like the mounts that will flex when I crash. I happened across the page advertising Finn bike mounts, but the shipping wouldn't make it in time for the ride I was taking... then I found this site
    http://www.dotmana.com/weblog/2014/09/dirt-cheap-diy-smartphone-bike-mount/
    and cut an inner tube to their pattern.
    it worked great, and I made a bunch of the, used them on hundreds of miles if single track, DS rides, and some street.
    I caved in a few weeks ago and bought another style from amazon
    https://www.amazon.com/gp/aw/d/B01N...amObsidian&dpPl=1&dpID=41fHry2w3IL&ref=plSrch
    that I like even better. it uses a belt/latch to secure the mount to the bars, and regular old loops for the phone. this is a lot faster/easier to swap between bikes, and you can leave the phone in the mount for pictures, just undo the belt and go do whatever.
    #13
    ygal likes this.
  14. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,167
    Portugal
    A bit off-topic but in the DIY Spirit, some of the GPSPHONES have external power connections, so you will might want to make some kind of power connector.
    My casio commando has external power pads on the side
    I used pogo pins on my casio commando , I got a bag with 100 units from eBay for 1 or 2€ but I got the very small ones 1.3mm I think . So I solder them together in pairs then push them thought a piece of plastic Then solder a blob so the pins won't get pushed back when inserting the phone in the mount. Solder the wires to the pogo pins and cover with heat shrink tubbing
    IMG_20170628_135803.jpg IMG_20170628_135812.jpg IMG_20170628_135839.jpg IMG_20170628_135851.jpg
    The power supply is glued to the back of the mount, so if I need to move it to another bike, i just have to disconnect and unplug one single unit
    #14
  15. Bighammer49686
    Bighammer49686 Been here awhile
    Mar 7, 2018
    200
    Traverse City, Michigan
    I was just going to buy a 2nd case for my phone (~$5 on Amazon) then mount it to the bike. Pop the hone out and into the one on the bike when I ride. Easy.
    #15
  16. dcwn.45
    dcwn.45 Frozen Rider
    Oct 20, 2006
    846
    St Paul,Mn
    I have an Otterbox case for my iPhone , it came with a belt holster.
    I cut off the belt clip, and glued a Ram ball to the back [using Goop adhesive] and I can switch it easily between 2 bikes and my truck.
    been working great for a couple years now.[​IMG]
    #16
  17. HKGuns
    HKGuns Been here awhile
    Apr 4, 2018
    247
    Bora Bora
    I picked this up on Amazon and bought several of the elastic straps as extra security. This is well made, bolts to the handle bars and rotates for landscape viewing. There is even a nipple in the allen head screw so you need a special allen head wrench to get it off the bike.
    This seems quite well thought out and executed.
    [​IMG] [​IMG]
    #17
