Portable mini crane
Discussion in 'Equipment' started by Stroked 550, Jan 15, 2020.
  1. Stroked 550
    Stroked 550 Dirt Nut
    Nov 24, 2009
    1,993
    Outhere
    I find myself doing projects by myself where I need to lift heavy items out in different areas.
    It cannot be something that is attached to the truck
    A come along wont work either as I dont always have an anchor point above me
    What kind of portable lift system do you recommend?
  2. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    6,200
    Maine
    Depends on the access, angles, and floor space.
    Do you have enough space for a rolling gantry?
    Would an engine lift work?
    I've used both and each works in some situations that the other won't.
    EDIT: I built a gantry for a project. It wasn't a rolling gantry.
    SmittyBlackstone likes this.
  3. Stroked 550
    Nov 24, 2009
    1,993
    Outhere
    I like the idea of a gantry but I need this for mobile work
    this is something that I need to use out in the field and be truck deployable
    it would be great if it had some decent tires on it so I can roll it around in varying terrain
    An engine lift would work in some situations but not in others, as I have to lift items off of a much higher level then what an engine hoist is capable of
  4. SmittyBlackstone
    SmittyBlackstone Been here awhile
    Mar 3, 2015
    715
    Westchster County, NY
    There is a type of gantry that attaches to a receiver tow hitch. It has two other legs. Don't remember where I saw it.
    Stroked 550 likes this.
  5. Grinnin
    Dec 10, 2005
    6,200
    Maine
    I've also built tripods and attached a chain hoist at the top. Could be made to fold. It's more compact and lighter than a gantry, but limits the length it can span.
    SmittyBlackstone and Stroked 550 like this.
  6. Stroked 550
    Nov 24, 2009
    1,993
    Outhere
  7. SmittyBlackstone
    Mar 3, 2015
    715
    That is like the item I saw, except that there were two stabilizer legs on what would be the drivers side of the upright to stabilize fore/aft movement.
  8. squish
    squish Out of the office.
    Dec 4, 2003
    8,895
    Where the Ghetto meets the sea.
    Etrailer sells the
    MaxxTow Hydraulic Pickup Truck Crane for 2" Hitches - 1,000 lbs
    Its like a davit for your truck. It is the one mentioed above or like it.
    #8
