1. Livestream NOW at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
Post Apocalyptic ZL ,ZOMBIE....
Discussion in 'Some Assembly Required' started by BigFatAl, Apr 11, 2020.
  1. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    I’ve been wanting to build a Mad Max Bike since I first saw the movie many years ago.
    I acquired a 1996 ZL600 in a trade about 4 years ago and it’s pretty much just sat in my garage for a couple years needing some attention.Well now because of things going on in our crazy world I’m off until the end of June at least ( school bus driver) so now is the time to build my post apocalyptic bike !!
    Wooohooo here I go !!!.
    Got the bike on the lift,cleaned the carbs and gave it a go,it ran but not good so some re jetting is in order.
    Traxx, davide, ZachM1 and 1 other person like this.
  2. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    I guess I should get this out of the way right now.
    MOST of the “add on’s” on this bike are for looks/effects,it’s not going to be ridden long distance!.
    Ok so I started stripping it down starting from the rear.Its a solo bike so I cut the stock seat in half,not sure I like it but I can change it later.I also cut off the frame behind the shocks.
    davide and Traxx like this.
  3. HapHazard
    HapHazard Waiting for Gudenov
    Dec 30, 2009
    5,145
    Central CT
    Just a couple thoughts that maybe helpful, or just annoying.:D
    On CV carbs, there are tiny holes in the carb throat "roofs" that sometimes get plugged with crud & overlooked. A high "E" guitar string works well to poke them clean.
    I dunno about the Kaw, but on other carbed 4's, pod filters have never run satisfactorily for me. The stock air box straightens the flow out and works mo' betta' through the whole rpm range.
    Best of luck with the project - it must sure beat chauffeuring the 'lil darlin's around...:lol3
  4. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Thanks for the info,one carb is squirting gas out the air cleaner so there’s a full carb tear down coming in the next couple days.
    The air box was cracked and not really any good.
  5. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Took the carbs apart,cleaned and checked and now it runs MUCH better.
    Now if I could figure out how to post a video !!
  6. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
  7. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Sissy bar done
    Headlight guard is almost done,just needs mounts.
    Fast Idle likes this.
  8. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    2,979
    The Great Land
    #8
    DKCJ, BigFatAl and villageidiot like this.
  9. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    It’s 28” ..
    #9
  10. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Front headlight guard/rack is done.
    #10
  11. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    #11
  12. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Front signals are mounted.
    #12
  13. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Rear is done !!.
    #13
  14. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,648
    Almost done.
    #14
