Project Ascot: Getting dirty with a 1983 Honda VT500FT
Discussion in 'Old's Cool' started by TwinDuro, Feb 27, 2016.
  1. TwinDuro
    TwinDuro Befuddled Adventurer
    Jun 10, 2007
    527
    Pac Nor-Wet, WA
    Here are a few more picture of the odd looking (damaged) starter clutch outer shell:
    As well as the mating surface on the back of the flywheel which we’ll polish out a little before reassembly:
    You can see where the rollers moved back and forth over the years. At this point, since we couldn’t move forward until new parts arrive (we have a new roller, plunger, spring kit and side cover gasket in hand but no bolts or starter clutch) we had ourselves a delicous stout from local brewery Cloudburst and moved onto a fun little project which was mounting a headlight guard Jerkhead got.
    The Emgo headlight bucket and H4 headlight we had replaced the original square unit with had very large 10 or 12mm captured nuts which we never used, instead opting to use the original headlight bolts with the factory nuts/wiring harness looms for inside the hesdlight. This posed a bit of a problem because to install the headlight guard there would be no easy way to hold these loose nuts on the inside of the bucket with the headlight already installed. We could have sourced larger bolts, but that would have required boring out a bunch of things and would’ve created a domino affect. Instead we decided to bust out the welder and just weld some captive 8mm nuts on the end of the larger nuts already welded inside of the housing. Excuse my welds, they’re certainly not the best I’ve ever done but they’re functional and no one will ever see them, except everyone who reads this thread
    Blue light time is always fun time! Public service announcement! Wear PPE unlike the dummy you see here. I really need to invest in another nomex welding shirt. I lost a few arm hairs in the process:
    With that out of the way on both sides we tweaked the mounting brackets for the guard with a few thoughtful bends and slotted it over the housing. Fits like a dream and looks good! We know this is more for style then actually taking a large rock roost into the center of the headlight, but it couldn’t hurt...
    That’s all for last night. Once we get more parts in we’ll finish the starter clutch rebuild and start in on the final front suspension assembly.
    Cheers Inmates and I hope you’re staying safe and sane in these interesting times!
    #81
  2. kenstone
    kenstone worn out
    Mar 3, 2013
    1,946
    Boysee
    Nice work :clap
    I broke one of the headlight ears off of the top triple tree in a crash riding in snow.
    I bought these cheap headlight ears and mounted a round headlight I had in "spare parts" :D
    Just another option...
    :lol3
    #82
    TwinDuro likes this.
  3. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    5,917
    Durham, NC
    FYI, if the starter clutch has been slipping, you likely need to replace the rollers and the gear as well. If there are ANY marks on them, the gear is suspect. If you can feel the marks, the gear is junk. In any case, don't reuse the rollers, even if they look okay. Especially don't use them if they have flat spots.
    Charles.
    #83
  4. TwinDuro
    Jun 10, 2007
    527
    Pac Nor-Wet, WA
    Thanks @kenstone and @ChopperCharles!
    That headlight setup looks good Ken! The ‘ol Shascot is looking good too!
    Copy that and thanks for the info Charles! We’ve got new rollers, springs and plungers and thankfully the gear still looks really good! The surface the rollers contact is smooth as glass and doesn’t have any marks and there’s just a slight rubbing mark on back of the gear from the bolts, but it’s smooth. Running my fingernail over everything, I can’t feel any thing that’s suspect. I’ll post a picture when we get back on it.
    Like you mentioned, we won’t be reusing the old rollers but the old rollers looked good, smooth and no hurts or marks.
    #84
  5. XVII_
    XVII_ n00b
    Jun 7, 2020
    6
    Long Beach, CA
    Hey guys sorry to hijack this thread. New rider here and my first ride is an '83 Vt500ft. I've been having some trouble with my bike overheating, I have replaced the thermostat and flushed the radiator. the fans work and I just go the carbs cleaned, but I still have that little over heating problem. Not too bad but it gets closer to the top of the gauge then I'd care for
    #85
  6. meehowski
    meehowski n00b
    Mar 14, 2020
    3
    ottawa, canada
    What is the last time head gasket was changed?
    #86
  7. XVII_
    XVII_ n00b
    Jun 7, 2020
    6
    Long Beach, CA
    I'm not sure. As far as I know the only work that has been done on the motorcycle has not been on the engine. Just the petcock, carbs, radiator and that's about
    #87
  8. thumpism
    thumpism Between bikes
    Dec 16, 2005
    6,899
    Richmond, Virginia
  9. ChopperCharles
    Jun 7, 2006
    5,917
    Durham, NC
    Override the fan switch. Does the temperature stay in a more normal range? If so, then you need a new switch. Very, very common problem for 1980s water-cooled Hondas.
    Charles.
    #89
  10. Tytan
    Tytan Been here awhile
    Jan 12, 2015
    713
    The Wet Left Coast
    #90
  11. XVII_
    XVII_ n00b
    Jun 7, 2020
    6
    Long Beach, CA
    How do I override the fan switch?
    #91
  12. Tytan
    Jan 12, 2015
    713
    The Wet Left Coast
    The temp switch is in the bottom of the radiator pull the wiring connector off the switch short the wires together and the fan should run. The wires for the fan and switch run up the frame on the right side of the rad and connect by the rad cap under the plastic cover in front of the gas tank you could also short the switch here if it's easier. If the switch is defective you don't need an oem Honda one I think some Nissans use the same switch.
    #92
  13. XVII_
    XVII_ n00b
    Jun 7, 2020
    6
    Long Beach, CA
    I'll get to it once I have a chance, thank you very much
    #93
    kenstone likes this.
  14. kenstone
    kenstone worn out
    Mar 3, 2013
    1,946
    Boysee
    Those switches are all over Amazon and at different temps too.
    I added a fan and switch to a dirt bike that didn't have either.
    Hose clamp is holding a ground wire, I later switched the switch out to one with 2 leads.
    Sorry for the bloviation and posting unrelated info,
    :lol3
    #94
  15. AZ Bill
    AZ Bill Adventurer
    Sep 27, 2020
    20
    Prescott, Arizona
    I just bought an '84 VT500 Ascot. I've coveted them for a while and finally caught up with a good one at a fair price.
    After finding nearly nothing in terms of forum activity relating to these bikes I was happy to find this long running thread !!!!
    My scooter will be strictly a pavement creature devoted to back roads and enjoying the scenery. I do most all my own work and love modding and mild customizing.
    #95
    TwinDuro and kenstone like this.
  16. aptbldr
    aptbldr easy rider
    Apr 20, 2009
    1,577
    Upstate South Carolina, USA
    It ain't heavy, it's my Ascot. :-)
    All Honda-ness aside; my Ascot's sharp looks, size, and six-speed transmission didn't compensate for a general sense of too-heavy for a five-hundred.
    #96
  17. AZ Bill
    AZ Bill Adventurer
    Sep 27, 2020
    20
    Prescott, Arizona
    I suppose it's a bit heavy but so far when riding my sense is that the weight bias is fairly low. My KLR is about the same weight but it feels very top-heavy.
    #97
  18. 380Viking
    380Viking Adventurer
    Apr 7, 2011
    67
    We have two VT Ascots I have fixed up in the last 5 or so years, they are great bikes, one of Honda's best and that is high praise! Range is short as the tank is barely over 2 gallons and the seat is not good for long miles, but they are a very fun bike to ride and surprisingly fast. They share many parts with the Shadow which is a big help too. I have learned a lot and will share if you need some input.
    #98
  19. AZ Bill
    AZ Bill Adventurer
    Sep 27, 2020
    20
    Prescott, Arizona
    IMG_3642.jpeg Thanks 380Viking. My VT is pretty solid (at the moment) for a 36 year old scooter. I'm sure I'll have some questions as I go through the first few weeks of shake-down.
    #99
    Scoozi, TwinDuro and kenstone like this.
  20. SlipChip
    SlipChip Adventure Commuter
    Nov 28, 2006
    5,391
    East of CleveOh
    Nice round headlight conversion!
