Project Hand Banana
Discussion in 'Some Assembly Required' started by madrider5150, Nov 7, 2016.
  1. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,318
    PNW
    I have a 3/16" tap I will run in each of the bolts and I should be able to use something to measure bolt depth, these are new OEM headbolts, I still have my old ones as well to measure against.
    Thanks, sometimes life just gets you down and usually wrenching is enjoyable, get some satisfaction of doing the job yourself and other times it just gets frustrating and yesterday it just got to me...
  2. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,716
    Alaska
    Hey, it happens. You'll get it figured out.
    madrider5150 likes this.
  3. madrider5150
    Oct 15, 2013
    1,318
    PNW
    So I talked to Alex at hammer performance this morning about the problem and theories of what the issue is. Through our discussion I mentioned I had replaced my headbolts with colony, not OEM. So try that first and had success using both long original headbolts. The rear worked just fine so never considered that? Just happy as hell I hit spec and can proceed with confidence. Rockerboxes on
    Apologies for my previous adolescent outburst lol
    JagLite, Bowler and AK650 like this.
  4. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    13,285
    Orange County, CA
    Aftermarket parts strike again.
    smolt, JagLite and AK650 like this.
  5. madrider5150
    Oct 15, 2013
    1,318
    PNW
    Slightly different tolerances or what I don't understand it..
    I would have bought OEM originally but didn't know about ronnies. Someone referenced them on here for a part, it might have been you VI, thank you or thanks to whoever it was...
    villageidiot and AK650 like this.
  6. AK650
    Jun 26, 2013
    1,716
    Alaska
    Glad you got it figured out!:thumb
    madrider5150 and villageidiot like this.
  7. tinwelp
    tinwelp Professional Idiot
    Dec 5, 2010
    723
    Deepest Southern France
    Brilliant! You should have mentioned the aftermarket parts though; it's an obvious place to look first.
    Glad you got it all sorted... now go and ride, erm, madly!!
    Cheers... Paul
  8. madrider5150
    Oct 15, 2013
    1,318
    PNW
  9. madrider5150
    Oct 15, 2013
    1,318
    PNW
    Sounds like the front piston doesn't have compression or rings got screwy? All seemed to go together okay .. I don't know
  10. villageidiot
    Apr 29, 2010
    13,285
    Orange County, CA
    You’re havin a rough go with this thing. Is there anyone in the area (xlforum etc etc) that can give ya a helps?
  11. madrider5150
    Oct 15, 2013
    1,318
    PNW
    I think I gotta find somebody local to take a glance at it. Guess I shouldn't be surprised the way I had to muck about with the front cylinder and I don't know how much you can play with it and still have compression? Maybe try and get a new close out 1250 from hammer and start over? Lol
  12. villageidiot
    Apr 29, 2010
    13,285
    Orange County, CA
    It’s not terribly hard to break a ring. But that sounds more lifter/rocker in the short video.
    I wish ya luck.
  13. madrider5150
    Oct 15, 2013
    1,318
    PNW
    Thanks I'll need it ha.
    Brand new s&s premium lifters in there, pretty sure I installed them right. Maybe a rocker issue too I don't know but front cylinder wasn't firing or lost compression, something..
  14. villageidiot
    Apr 29, 2010
    13,285
    Orange County, CA
    did the lifters pump up with oil? Did ya soak em? I dunno what the protocol is on a sportster but on a small block I soak em overnite.
  15. madrider5150
    Oct 15, 2013
    1,318
    PNW
    I soaked them overnight although it was 1040 not 2050, didn't think that would matter. Didn't really get check them, just dropped them in but seemed pumped up installing everything
    villageidiot likes this.
  16. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,314
    mena, Ar
    Slide the top rocker box off and check to see how much play is in the pushrod. There shouldn’t be any play, but should have so much pressure that you cannot spin the push rod. This should be done with both valves closed. Could be that the lifter didn’t pump up but this should tell ya. I had that one time on a sporty. Doesn’t take much to clog one and stop the oil flow.its hard to tell in that closed space where sound bounces around but it doesn’t sound like piston issue.
    Typically parts store will have tool loan program where you can get a compression testor and run a test on front and rear cylinder. That will tell you if you have a ring problem.
    villageidiot, AK650 and madrider5150 like this.
  17. madrider5150
    Oct 15, 2013
    1,318
    PNW
    Yes, I do have a compression testor.. kinda forgot that would be the first thing to check before pulling everything apart! Thanks
    johnwesley, villageidiot and AK650 like this.
  18. madrider5150
    Oct 15, 2013
    1,318
    PNW
  19. AK650
    Jun 26, 2013
    1,716
    Alaska
    I'd still do a compression test. Always a good idea after a top end(or cam chest) is put back together. Takes no time at all, and very telling, if something ain't right.
  20. madrider5150
    Oct 15, 2013
    1,318
    PNW
