Project Hand Banana
Discussion in 'Some Assembly Required' started by madrider5150, Nov 7, 2016.
  1. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,464
    PNW
    Well the shop is only a couple miles away so I'm going to ride it there but we just got a few inches of snow last night. It'll likely be a couple weeks before I get it in there, wait until after the holidays.
    #61
    AK650 likes this.
  2. madrider5150
    Oct 15, 2013
    1,464
    PNW
    I was thinking the same thing but spent a good amount of time putting coats on and letting them cure. I guess spray paint ain't gonna get much better/tougher regardless
    #62
    villageidiot likes this.
  3. madrider5150
    Oct 15, 2013
    1,464
    PNW
    Got some snowy two wheel action in on the bicycle this morning. Mountain biking is my first love and I commuted year round on this bicycle for almost 3 years. On my third drivetrain; cassettes, chainrings, chain, second bottom bracket. It's the bicycle version of how I want my motorcycle basically; comfy, reliable and capable of doing long distance heavily loaded as well as lower speed technical riding.
    #63
    AK650 and villageidiot like this.
  4. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    2,550
    Alaska
    :thumb
    #64
  5. madrider5150
    Oct 15, 2013
    1,464
    PNW
    With as bad as my spray job turned out on the rear fender I'm thinking I should just take the tank somewhere to be sprayed professionally. Its a pain getting it all prepped which it is right now so feel like might as well..
    #65
  6. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    17,340
    Orange County, CA
    My tins are getting powdercoated.
    I’ll strip the paint with paint/epoxy remover, that way the powdercoater doesn’t have to blast em as gnarly.
    The powder will be nice, easy, and cheap(ish)
    #66
    madrider5150 likes this.
  7. madrider5150
    Oct 15, 2013
    1,464
    PNW
    I asked about getting my tank powder coated and got a negative response.. I'll have to check with the powder coaters in town here.
    What color you going with?
    #67
  8. villageidiot
    Apr 29, 2010
    17,340
    Orange County, CA
    Dunno yet
    In regard to negative response....... not sure why. I’ve had many gas tanks powder coated. In this case my tank is brand new, no fumes, no gas. But in the past I just flush out really good with water, then stick an acetylin torch in there, usually get a little POOF from residual vapor, and then I dry it very well, stick it in the sun, heat gun etc etc.
    The powder coater plugs all the holes wicked good, and then bam.
    #68
    AK650 and madrider5150 like this.
  9. madrider5150
    Oct 15, 2013
    1,464
    PNW
    Kickstand now needs another 5ish inches and I now have 10-11" of ground clearance
    #69
    CopyCat likes this.
  10. villageidiot
    Apr 29, 2010
    17,340
    Orange County, CA
    thats a whole lot of shocks right there!
    #70
  11. madrider5150
    Oct 15, 2013
    1,464
    PNW
    Oh yeah probably too much but I'm in too deep
    #71
  12. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    827
    behind the cheddar curtain
    They look great! I especially like the Heim ends. Those were 17's, right? DO they have the compression and rebound adjusters? I can't get an answer from Nitron whether they can even build me a set, kind of irritating.
    #72
  13. villageidiot
    Apr 29, 2010
    17,340
    Orange County, CA
    to me they appear to have compression and rebound dampening clickers. one on the top, and one on the bottom of the shaft.
    #73
    CopyCat likes this.
  14. madrider5150
    Oct 15, 2013
    1,464
    PNW
    They are 17.5" although I did ask for 16.5-17" and blue springs.. I'm still happy with them. They look great fit up nicely with my hard bags and look like they will with my exhaust as well.
    #74
    CopyCat likes this.
  15. madrider5150
    Oct 15, 2013
    1,464
    PNW
    One concern is that my chain is too short/tight and will prevent full shock travel. I may just need to order a new one and might as well go with new sprockets as well. I think I'm running 24/51 and want to try 24/55 anyway.
    #75
  16. madrider5150
    Oct 15, 2013
    1,464
    PNW
    Its hard to tell in the pictures but I think the drill got off enough into the head.. damn. Will get an easy out tomorrow and hopefully get the stud out, see how much damage I've done.
    #76
  17. fast1075
    fast1075 Not a Lemming
    Dec 28, 2013
    2,007
    Flaw'da
    Might be time to take it to a machine shop with an EDM before you kill it.
    #77
  18. villageidiot
    Apr 29, 2010
    17,340
    Orange County, CA
    This.
    #78
  19. villageidiot
    Apr 29, 2010
    17,340
    Orange County, CA
    EDM that thing out. If you need a recommendation let me know. I got a guy I drive past daily.
    #79
    madrider5150 and AK650 like this.
  20. madrider5150
    Oct 15, 2013
    1,464
    PNW
    What is edm? I did use a jig designed for this, it was off Ebay but still. Should I not even try with the easy out?
    #80
